Old 09-01-2013, 02:59 PM   #1359
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by xxscaxx View Post
Can the ACT full face clutch be used with the stock flywheel? Not a fan of the noise from the lightened flywheels.
I know I've seen kits come with a normal steel flywheel, not a lighter aluminum one.
Sent from...somewhere?
Old 09-01-2013, 03:03 PM   #1360
xxscaxx
Drives: 2013 SWP BRZ
Thinking about it, IIRC I saw two options, clutch kit and clutch kit w/ lightened flywheel.
EDIT: Yep. the reg flywheel is 11.8 pounds, the lightened is 10.5. Wonder what the stock flywheel weighs.
xxscaxx is offline   Reply With Quote
Old 09-01-2013, 03:04 PM   #1361
FA20Club.com
Drives: 2013 White Out FR-S
wont work on oem flywheel been there done that
FA20Club.com is offline   Reply With Quote
The Following User Says Thank You to FA20Club.com For This Useful Post:
xxscaxx (09-01-2013)
Old 09-01-2013, 03:06 PM   #1362
xxscaxx
Have you used there "regular" flywheel and lightened one as well? Do they make a lot of noise?
Old 09-01-2013, 03:19 PM   #1363
FA20Club.com
they make 2 flywheels both are lightened one is just 2 lbs less than the other
Old 09-01-2013, 03:20 PM   #1364
xxscaxx
ah okay. Which have you used, and if both which do you prefer?
Old 09-01-2013, 08:43 PM   #1365
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
who makes two flywheels CM or ACT?
448hpsti is offline   Reply With Quote
Old 09-01-2013, 08:54 PM   #1366
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
if you match the kits identical such as compound and full face or puck spung or unsprung they wll react the same. CM have always been pricier compared to spec, ACT,Competition etc
I swear we just had this exact conversation on Weds this week. I'm leaning towards the CM setup with the heavier of the two lightweight flywheels.
David, I could feel what you're talking about in Tuts car just as a passenger. If I wanted a car more for track than street I think I'd go 6 puck but on the streets the CM seems a little more civilized.
Gem, are you still on stock clutch???
chadstyle is offline   Reply With Quote
The Following User Says Thank You to chadstyle For This Useful Post:
Sportsguy83 (09-01-2013)
Old 09-01-2013, 09:03 PM   #1367
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
ACT makes two.
Old 09-01-2013, 09:04 PM   #1368
Sportsguy83
Drives: Limited BRZ
Once I'm tuned hopefully and fingers crossed in about a week, I'll take you for a ride.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
chadstyle (09-01-2013)
Old 09-01-2013, 09:21 PM   #1369
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Yes stock clutch, but its gotten ridiculously soft to depress, tho no slippage that I can "tell" but it does feel a bit vague around redline of late, so I am sure its-a-comin
Old 09-01-2013, 09:28 PM   #1370
chadstyle
chadstyle's Avatar
I honest feel like my clutch is softer too but no slippage yet. You are making far more power than I am so I don't expect my clutch to slip at all but the lighter feeling is odd.
I'm trying to fix all the weak links before going FI...we'll see how that works out ha!
Old 09-03-2013, 08:09 PM   #1371
swift996
swift996's Avatar
On the topic of boost, below are a few plots with the provided 75mm pulley and my 3-bar MAP sensor reading.
Set up - Perrin Cold-Air Intake, FA20Club EL Header (catted), 2.5" Perrin over-pipe, FA20Club resonated front-pipe, stock cat-back.
A log from my track session (filtered to WOT) running E85:
Here is a log I sent to my tuner today with some three pulls on 93. Not sure how EcuTek adjusts the bar reading, I'm definitely not running 1.6 bar, perhaps that -1?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
Sonolin (09-03-2013)
Old 09-03-2013, 08:17 PM   #1372
FA20Club.com
ecu reads absolute pressure so yes subtract 1.0 bar equates to .6 bar
swift996 (09-03-2013)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
