Old 02-18-2015, 01:04 PM   #1359
ShoShin
ShoShin's Avatar
Drives: WRB Premium
Thanks for your input! Just curious--Why not CST?
Originally Posted by tahdizzle View Post
Spherical Bushings put you in the SM class.
RE11-A tires i feel are good as a multi-purpose tire. I wanted to buy r1r in 235/40/17, but they didn't get the 200tw in time.
ShoShin is offline   Reply With Quote
Old 02-18-2015, 01:07 PM   #1360
vroom4
You can get the Solo rulebook via google and see what each class allows. PS. Its CSP not CST.
vroom4 is offline   Reply With Quote
Old 02-18-2015, 01:16 PM   #1361
ShoShin
ShoShin's Avatar
Drives: WRB Premium
see below
Originally Posted by 2superblus View Post
RE11a's are slow plenty of new tires on the market as of March.
This is what makes your car not STX legal " SPL Rear Lower Control Arms - Spherical Bushings"
Are they spherical Bearings in it or Rubber Bushings?
Old 02-18-2015, 01:34 PM   #1362
conedodging
conedodging's Avatar
Drives: '14 BRZ
Here's the relevant Street Prepared entry that says those aren't legal. You're in violation of two separate parts, more metal than stock, and change in bushing type.
15.8.C
Suspension bushings may be replaced with bushings of any materials (except metal) as long as they fit in the original location. Offset bushings may be used. In a replacement bushing the amount of metal relative to the amount of non-metallic material may not be increased. This does not authorize a change in type of bushing (for example ball and socket replacing a cylindrical bushing) or use of a bushing with an angled hole whose direction differs from that of the original bushing. If the standard bushing accommodated multi-axis motion via compliance of the component material(s), the replacement bushing may not be changed to accommodate such motion via change in bushing type, for example to a spherical bearing or similar component involving internal moving parts.
conedodging is offline   Reply With Quote
Old 02-18-2015, 04:13 PM   #1363
whataboutbob
AutoX-10/10ths every run
SM (Street Modified) is the national class the SPL LCAs put you into...CST (California Street Touring) is a local class that allows you to run spherical bearings.
If you participate in any national level events, you'll need to read the rules, but you're definitely not STX with the SPL LCAs, which are an SM part.
Build thread:Here
Old 02-18-2015, 10:51 PM   #1364
chriskory
Drives: 1991 honda civic si
I have a question for those running aggressive alignments, like -3.25 camber and .2 toe out.
Do you keep those settings while daily driving, or mark the locations on your camber plates and turnbuckles then change at an event and change back before you drive home?
Seems some of the alignment settings in this thread would wipe out a tire within a month.
chriskory is offline   Reply With Quote
Old 02-18-2015, 11:23 PM   #1365
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
Do you really need toe out for this car, though?
I'd leave it, just because of how inaccurate it can be with just sliding it even if you mark it.
tigermack is offline   Reply With Quote
Old 02-19-2015, 12:41 AM   #1366
was385
Drives: MT WRB BRZ Limited, 2007 911s
I also DD my car with a recently long highway commute and ran-3.2 up front, about-2 rear with just a bit of toe out up front and have no camber wear on my ZIIs after a full season. I'm sure the toe increased wear a bit but nothing crazy.
was385 is offline   Reply With Quote
Old 02-19-2015, 09:02 PM   #1367
conedodging
Drives: '14 BRZ
Whee!
Old 02-20-2015, 12:32 AM   #1368
cactus
cactus's Avatar
Drives: 13 SWP BRZ
Originally Posted by conedodging View Post
Whee!
They came in a box?
cactus is offline   Reply With Quote
Old 02-20-2015, 01:39 AM   #1369
conedodging
Drives: '14 BRZ
Originally Posted by cactus View Post
They came in a box?
Yup, that's how FRSport decided to ship them. Weird and a bit wasteful, but oh well.
Old 02-20-2015, 01:40 AM   #1370
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
So, I can't decide on a header...
I would ask over in the Engine section, but I figured I would ask here cause this is where it actually matters.
I'm going to pick up an OFT for the tune, but I just can't decide on a header for STX. Suggestions?
Kostamojen is offline   Reply With Quote
Old 02-20-2015, 08:12 AM   #1371
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
I've looked a lot into it...I decided I wanted a catted header because I'm 30 and wear a shirt and tie to work and I wanted EL because it's a Scion not a Subaru (yes, I'm still hung up on that) and I hate the Subaru rumble.
I decided on the P&L or JDL, whichever I can find used for a good price...still looking though...
Header is a lot of personal preference. They make noise. And with this car you have the distinct choice of being able to choose the smooth rasp of the EL or the lumpy Boxer Rumble of the UEL. I know there's a lot of threads out there about which yields more power, but it also seems you can get just as much power out of either one with the correct tuning. For STX you gotta have a cat, but it's your choice if you want it in the header or in the front pipe.
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 02-20-2015, 12:37 PM   #1372
Kostamojen
I've done multiple headers before on my N/A Imprezas so I'm familiar with the noise, mostly concerned about power delivery and bang for the buck and curious what other STX folks went with.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
