Old 03-04-2016, 01:48 AM   #13679
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
just installed my bride bucket seat - i like how its centered to the steering wheel
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZtoni For This Useful Post:
austinbrz (03-05-2016), Drakiv (03-04-2016)
Old 03-04-2016, 02:52 AM   #13680
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
need pics of this
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 03-04-2016, 03:11 AM   #13681
YXEBears
bearded god
Drives: 2016 Silverado (bye bye BRZ)
installed BlackVue DR650 2 channel dash cam system
YXEBears is offline   Reply With Quote
The Following User Says Thank You to YXEBears For This Useful Post:
Old 03-04-2016, 03:26 AM   #13682
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
Finished installing my Pioneer AVH-x8500BHS in my '16 BRZ - even got the OEM reverse cam working finally.
treminaor is offline   Reply With Quote
Old 03-04-2016, 03:47 AM   #13683
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Where did you find a trim ring for the '16, or did you make your own?
sly is offline   Reply With Quote
Old 03-04-2016, 02:12 PM   #13684
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Originally Posted by Drakiv View Post
need pics of this
ill take some tonight im at work right now
Flex Fuel Turbo BRZ
Old 03-04-2016, 05:54 PM   #13685
JohnBgon
JohnBgon's Avatar
Drives: 2016 BRZ Lim. DGM MT
Pics? I'm also curious about the dash trim you used around the receiver.
Does the OEM USB or Aux ports still work?
JohnBgon is offline   Reply With Quote
Old 03-04-2016, 06:58 PM   #13686
mixedjuice
Drives: 2015 BRZ - sold & 2014 Legacy Sport
JUST SOLD THE BRZ. I am most likely gonna be banned from the site. Love the car and the online community. But unfortunately the RWD was just a want and not a need being from Alaska. So I can bet you all know what is next?!? BRZ owner for life.
mixedjuice is offline   Reply With Quote
Old 03-04-2016, 07:09 PM   #13687
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Sucks to hear that you had to give up the BRZ; and quite honestly given your location/climate, it's understandable. No one would hold that against you. Priorities always first.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
The Following User Says Thank You to DaJo For This Useful Post:
mixedjuice (03-05-2016)
Old 03-04-2016, 11:07 PM   #13688
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
@Drakiv
i need someone to take pics of my car i suck at pictures haha
Flex Fuel Turbo BRZ
The Following User Says Thank You to BRZtoni For This Useful Post:
Drakiv (03-05-2016)
Old 03-05-2016, 12:19 AM   #13689
treminaor
"DGM BRZ"
treminaor's Avatar
Nope. There's currently no adapter on the market to make it work with the '16 harness. The AX-TOYUSB-1/2 will NOT work with a 2016 starlink Subaru.
I used the existing one for people with the square dashboard holes, so there's some gaps. It looks acceptable for the time being until someone releases ones made for the new dash style.
You don't need the dash kit to mount your radio to the car, so don't waste your money on it unless you don't mind the look.
Existing radio guides for the 2013-2015 BRZ will tell you to wire the blue power antenna wire on the Toyota Metra 70-1761 to your blue/white remote power (System Remote Blue/White on Pioneer decks) to turn on the door speaker amps. This is incorrect for 2016 models. You need to wire your blue/white remote power wire to the 9th pin (Brown wire) of the 28 pin data harness, which is the 3rd wire harness coming out of the car. This harness is for the backup camera, the integrated mic, the door amp power, and more.
For the reverse camera to work you need a voltage regulator to step down the 12v power from the car harness to 6v, the required voltage for the OEM rear view camera. I suggest buying this: [ame="http://www.amazon.com/gp/product/B00CGQRIFG"]Amazon.com: DROK® Waterproof High Efficiency Car Power Converter DC12V to 6V/3A Step Down Voltage Module 9-22V to 6V Power Supply: Electronics[/ame]
Splice into your 12V accessory power wire to the red 12v INPUT wire of the regulator and wire the black ground wire to the black INPUT ground wire on the regulator. Wire the yellow 6v OUTPUT wire of the regulator to pin 11 of the 28 pin harness (this will power on the OEM camera). Wire the black OUTPUT ground wire to pin 22 of the harness (camera ground).
I removed the prewired RCA plug with pins on it from the useless AX-TOYCAM2 harness I had laying around... if you don't have that harness just cut up any old RCA cable and separate the copper ground from the signal wire inside of it. The signal wire is your + (pin 12) and the ground is your - (pin 13) - plug them into their respective holes on the 28 pin harness. I then plugged the other end of the RCA cable into the rear camera input of my Pioneer AVH-x8500BHS. Remember to go into your settings and change the Camera from "Off" to "Battery" (not "Ground"), and set the camera to NTSC under "Video Signal Options"
The Following 2 Users Say Thank You to treminaor For This Useful Post:
JohnBgon (03-05-2016), Pointmutation (03-23-2016)
Old 03-05-2016, 08:39 AM   #13690
Talus1
Talus1's Avatar
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
Anything worth doing is worth doing twice...
Talus1 is offline   Reply With Quote
Old 03-05-2016, 09:38 PM   #13691
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I test-fitted my new wheels and tires two weekends ago. Back on winters for the next few weeks, but then they go back on, along with coilovers/camber plates/LCAs. I'm excited!!!
Stang70Fastback is offline   Reply With Quote
The Following 3 Users Say Thank You to Stang70Fastback For This Useful Post:
BRZtoni (03-06-2016), DGMlJDlBRZ (03-05-2016), ShadowReaper (03-07-2016)
Old 03-05-2016, 10:18 PM   #13692
pmcoffee
drained a tail light, and resealed using Gorilla Gaskets and 3M goop. drove 3 miles in dry weather with no condensation. working so far......
pmcoffee is offline   Reply With Quote
