Old 12-04-2018, 03:36 PM   #1345
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
Originally Posted by Cosworth_0686 View Post
What did you get? I've got a 2017 and ran into the same issue.
Also, upon fitting the cold air pipe, it seems that it won't line up with the mounting point at the back of the IC core. There doesn't seem to be any room to push it down for the hole to line up, as it'd hit the intake runners. The short end of the 90° is connected down at the throttle body. Could this fastener have been welded on too high?
The GDI driver box also seems to be twisted out away from the engine at the top end by the supplied spacer (20045323); it still bolts up, but seems to be under more stress than it really should be. Any thoughts?
I think you may have the elbow on the wrong way round? as there's a short leg and a long leg. you need to have the short leg onto the throttle body
Matt@Cosworth is offline   Reply With Quote
Old 12-05-2018, 12:45 PM   #1346
gtengr
Drives: 2017 BRZ
Originally Posted by sly View Post
Be sure to check your air cleaner for overtightness. Step 1 is to see if your cat has any answers. Together we determined that the problem was the hose clamp was too tight and it had deformed the air cleaner box. If you overtighten the clamp, it will deform the plastic and you will get a leak. I took a plastic funnel and a heat gun and warmed my air filter box and pressed the funnel down into the opening to round it back out. Then be sure to reattach the clamp just so it's snug but not tight.
I've attached a few pics. The roundness still looks ok. There might be sealing issues with the way the factory airbox connection has a discontinuous lip around the perimeter. That combined with the short coupler hose and slightly misaligned connection makes for a sketchy fit. I could see from earlier pics that I had the hose clamp right on top of that lip, if not a little to the wrong side of it. I ordered the 6" coupler (below) so I can comfortably position the clamp behind that lip instead of on top of it.
Also, I'm going to use less torque when reinstalling the factory airbox bolts as they have a bushing and over-tightening limits their effectiveness. The airbox needs to be able to vibrate with the engine some to reduce the stress on the airbox coupler connection.
Originally Posted by BoostTheBrz View Post
Thanks for the link! Just ordered one.
gtengr is offline   Reply With Quote
Old 12-07-2018, 10:54 AM   #1347
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Anyone know if there is a warranty on the exhaust? I just noticed that one of my exhaust tips has a small crack in it. Take it up with Nameless or Cosworth? Can you repair stainless?
For anyone running the Cosworth exhaust, I would recommend cleaning the tips regularly with chrome polish to keep any surface rust off of them. Left unchecked, the rust will eat through the tips.
As for the supercharger, still working good. Very smooth and solid feeling.
sly is offline   Reply With Quote
Old 12-07-2018, 01:02 PM   #1348
Matt@Cosworth
Hello
I'd get in touch with Nameless, see what they say
but yes you can weld repair the tips and then re-polish
Old 12-09-2018, 09:24 AM   #1349
Cosworth_0686
Drives: Cosworth ('17 BRZ, '76 Vega)
My stage 2 kit didn't come with a thermostat, and I bought a different exhaust kit, so I didn't get it there either. What would you guys suggest I get that would be equivalent to the one that's supposed to be installed with this kit?
Cosworth_0686 is offline   Reply With Quote
Old 12-09-2018, 10:14 AM   #1350
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
If you don't plan to track your car, you will fine without the thermostat. If you MUST have one, you could find a Cosworth or Mishimoto. I believe those are the only ones available.
MS, CSCS, TSAC-F, CPT
Old 12-09-2018, 12:02 PM   #1351
sly
sly's Avatar
I would recommend putting in the thermostat. You may get spark knock without it.
http://www.glracingshop.com/index.ph...duct&id_lang=5
https://rallispec.com/eng_the_cos42811.html
https://store.worksmotorsports.com/C...1-20042811.htm (might call them. listed for 999.00. Probably should be 99.90)
Old 12-09-2018, 04:54 PM   #1352
Matt@Cosworth
yes if you're running our tune you should have the thermostat as the spark maps were set with it.
plus its about 5-7 bhp who doesn't want that?
Old 12-09-2018, 05:43 PM   #1353
Cosworth_0686
It Runs!!!
[ame]https://www.youtube.com/watch?v=1miPs-_M2OE[/ame]
It runs!!! Finally got things together to the point where it runs! Still need to order/install the correct thermostat, but that should be easy enough once it's here.
When initially trying to fill the coolant reservoir, hardly any would actually flow in, and I had to pull the reservoir up a couple of inches so that the fluid could get past whatever high point was preventing it from getting to the pump. Also, the throttle body seemed to be making a weird sound while the car was powered on, but not running.
[ame]https://www.youtube.com/watch?v=2tekU0pRE-Y[/ame]
Now to figure out what the check engine light is complaining about >_<
Old 12-09-2018, 06:43 PM   #1354
gtengr
Drives: 2017 BRZ
When initially trying to fill the coolant reservoir, hardly any would actually flow in, and I had to pull the reservoir up a couple of inches so that the fluid could get past whatever high point was preventing it from getting to the pump.-
Squeezing the hoses helped out a lot with the initial fill and bleed.
That's strange about the throttle body, not sure it's concerning though.
Old 12-09-2018, 07:02 PM   #1355
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Please update us about your car because you are another person that I know that has a 2017+. Are you running stock exhaust?
Thanks!
botbs is offline   Reply With Quote
Old 12-09-2018, 07:37 PM   #1356
Cosworth_0686
Nope, I installed https://www.ft86speedfactory.com/spe...rage-1400.html a few months ago. I know the UEL header will sacrifice a few hp compared to an equal-length header, but it sounds awesome and adds a bit more of that Subie feel to it, I feel.
Old 12-09-2018, 09:25 PM   #1357
Cosworth_0686
P0102: Mass or Volume Air Flow Circuit Low Input
P0108: Manifold Absolute Pressure/Barometric Pressure Circuit High Input
It was my understanding that the 2017+ manuals had a different filter which was supposed to be a higher-flowing one, though I was still planning on getting one of these before driving the car around: http://www.ft86speedfactory.com/blit...17-brz-86.html
Seems it's time to go around and check for air leaks and re-triple-check that all the cables are fully connected.
Should this one perform similar to the Cosworth thermostat? It looks like they both open at 76C. http://www.ft86speedfactory.com/mish...stat-1025.html
Old 12-09-2018, 10:06 PM   #1358
botbs
botbs's Avatar
Great, will try the cat-back first and if it doesn't work then go for header. Still waiting for my cat-back to arrive.
Thanks!
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
