Old 12-16-2014, 03:11 AM   #1345
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
Originally Posted by DesertFrs View Post
I would compare it to the GT2860RS in spec wise not the same but closely with the AVO coming up on top in power. Their has been two AVO kits in SoCal including mine that make 419whp and 356wtq at peak 16 psi on the 3" exhaust. Although trying to keep the top end from tappering to 14psi from 6700 to redline was a bit hard, with the stock air box limiting the turbo. I might be wrong in comparing these to turbos but Paul ( @AVOturboworld ) can correct me if I am wrong. With the billet wheel offered in the Stg 2 it should help the top end a bit to give you more power. I highly suggest getting an Intake to allow the turbo to breath better to yield better results. I can't wait to get my new dyno tune in the upcoming months from ( @DeliciousTuning ).
Wow! 419 whp from the AVO Kit...that is mad
Aren't you afraid of killing your transmission?
Toyota GT86, Leather, JBL-Sound, Aero-Kit, inferno orange
MODS |O.Z Leggera 18 x 8,5|Front:Tarox B32|Rear:OEM+EBC GreenStuff|Braided Lines|Milltek CAT-Back & Overpipe|Motiv Concepts catted Frontpipe| AVO Turbo|AVO breather tank|Mishimoto Oilcooler|Exedy Stage 1 Clutch|BeatSonic Sharkfin|TRD Ducktail|TRD Aero cover|Valenti blinker
Flasher is offline   Reply With Quote
Old 12-16-2014, 09:53 AM   #1346
robr
Drives: 2013 FRS, with boost by ATS Racing
Another ~400rwhp AVO kit confirmation in TX. 398hp/322tq at 1 bar on E85. AVO kit and Perrin intake IIRC. Pretty sure it was a 3" exhaust, but I forget. His torque curve was the deciding factor to turn my boost up finally (not an AVO kit).
When this AVO kit owner came in and said he was expecting around 400rwhp we were all pretty skeptical since the other AVO kits we've gotten in were pump fuel and stock fuel pump. Didn't think the turbo had it in it, but it certainly does.
robr is offline   Reply With Quote
Old 12-16-2014, 11:47 AM   #1347
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
No sir! I drove on the 16psi map for 5k miles daily with no issues. I even did 13 passes at the local drag strip. Had issues with oil getting to hot in the tranny and trying to keep traction through 3rd gear. But that was it.
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
Old 12-16-2014, 08:10 PM   #1348
kbogarto
Drives: 2013 BRZ limited WRB
Installed my kit his past weekend. How much oil from the breather tube that connects to the AVO oil reservoir gets into the intake? How important is it to have this connected to a catch can?
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 12-17-2014, 07:34 AM   #1349
Flasher
Smartass
Flasher's Avatar
If you're going to track this kit, or at least keep the revs over 5k for an extended period of time, your oil reservoir will overfill and splash excessing oil into the intake tube. I had this problem, when I was tracking the first time. I've installed the AVO breather tank and now it's gone.
Besides: a catch can is already in NA applications a good idea, since the FA20 has quite a lot of blowby.
Old 12-17-2014, 01:44 PM   #1350
MidnightRunner
MidnightRunner's Avatar
Hey everyone, quick question:
Is anyone having an issue with the stock bov for around $120? I looked, but there is no info in it anywhere. I'm assuming it's full recirculation, but I'm curious if anyone is having issues with boost leaking. I'm trying to see the advantage in getting the adjustable BOV for around $250. Vta is not an advantage.
Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Old 12-17-2014, 09:37 PM   #1351
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yes that bov is fully recirculating. It's a Bosch type, very similar (if not identical) to the OEM Mitsubishi Evo valves.
Fizz is offline   Reply With Quote
Old 12-17-2014, 09:43 PM   #1352
kbogarto
If you don't care about venting to atmosphere I would go with the standard BOV and save the money.
Old 12-18-2014, 04:22 PM   #1353
Astroboy
Astroboy's Avatar
Drives: None
AVO Turbo Kit Owners Topic
Has anybody else encountered oil leaks with this kit? I've encountered minor oil leaks from behind cam plate, cam plate cover that's under the ecu and above the turbo heat shield, and also around the oil pan :[
I'm not blaming it on the kit or anything, I am just curious if anybody else encountered this. I did recently changed my oil to a 5w30.. Maybe that could be the cause?
Astroboy is offline   Reply With Quote
Old 12-18-2014, 07:37 PM   #1354
DesertFrs
DesertFrs's Avatar
I haven't had any leaks as of yet. I'm at 20k miles and 18k with the turbo and haven't had an issue. I'm still using 0W-20 with my 400+hp application. I dont see any reason why to go to something thicker just yet. From my understanding theirs not enough clearences to go with something thicker either without experiencing sometype of issues. Again if you have a good oil that keeps its visocity levels at high temps then you should have no issues with 0w-20. I use Purol as my choice of motor lubricants.
Old 12-18-2014, 11:06 PM   #1355
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Damn who tuned that?
Whatabouteggs is offline   Reply With Quote
Old 12-18-2014, 11:40 PM   #1356
robr
ATS Racing in Denton.
Old 12-20-2014, 08:52 PM   #1357
humpre
Drives: 2013 DGM BRZ
Couldn't be happier with it, its tons of fun and tuned tremendously well!
humpre is offline   Reply With Quote
Old 12-22-2014, 12:51 PM   #1358
Whatabouteggs
[Citation Needed]
Graphs? Graph graphs?
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
