#13441 | |
Drives: 2019 Toyota 86 TRD SE
bumped, also will be adding a SARD STYLE spoiler/wing for sale, painted raven black, price $300. will upload pic asap.
#13442 |
I will have the following for sale. It will be off the car Friday.
Custom exhaust from the FP back. Consists of Stock FP with the stock Resonator removed and an ultra quiet Vibrant resonator welded in with a MXP-SP catback. To get good fitment I had the shop weld the mid pipe to the FP. the muffler section has a v-band style connector. Local pickup only in socal at 92551. 375$ firm price. Pictures will be available Friday.
2013 Series 10 FRS #553
#13443 | |
Bump! Prices lowered!!!! |
#13444 | |
Bumped, updated new added and sold item
#13445 |
Drives: 13 BRZ
Complete FA20 engine with no problems. Removed from running car for an LS swap. 2013 with 62k miles. The recall work had not been performed on this engine. $2000.
#13446 |
Drives: 89 240sx hatch and 2013 Frs
Hello I’m selling real 5x100 18x9.5 +38 rays gramlight 57dr eternal blue pearl .
There are perfect spec for stock body frs Brz 2 of 4 wheels have some rash ( there’s pictures) kumo 245-40-r18 ( 7/10 ) Asking $1400 obo Pick up only . I’m located in Long Beach Ca |
#13447 |
Perfectly Balanced...
Drives: '13 FRS & '13 BRZ
I have two FA20s, one assembled long block, other is disassembled with both heads. Both are blown, if you can make heads out of tails or just need parts, let me know... take them both for $1,200
Sent from my SM-N986U using Tapatalk |
#13449 |
Drives: Friggin Really Sweet
WTS 2013 Stock rear bumper + exhaust
WTS 2013 Stock rear bumper(firestorm) + exhaust
Sold off the car and have these remaining spare parts. Pickup will be @ Murrieta. Zipcode: 92563 |
#13450 |
Drives: red frs
So. Cal 2013 FRS FOR SALE
SOLD
2013 SCION FRS Automatic With Paddle Shifters 170,000 FREEWAY MILES Runs Strong Drive to LA from S. OC Had to go Electric Why I'm selling Tags good till May 2022 (Smog check in May with Tune) Airaid 510-307 Intake Swift springs on stock shocks Vishnu Openflash Tuning Tablet with stage 2 tune installed OEM Audio Plus Reference 500 stereo system installed clear tom's taillights LED Headlight Bulbs Cat back Exhaust (No Name Copy of DC Canisters) Cross Drilled and Slotted Rotors New 18 Inch Rims and Tires (New Goodyear Eagles) INCLUDED EXTRAS Stock exhaust Stock intake Stock rims and tires (new) Stock Front Headlights Carbon fiber look rear wing lip [ATTACH][ATTACH][ATTACH][ATTACH][ATTACH][ATTACH] Last edited by jbetanc; 11-21-2021 at 05:55 PM. Reason: SOLD |
#13451 |
Drives: red frs
FOR SALE BLITZ DAMPER ZZ-R COILOVERS
like new $600.00
FEATURES A single mono tube shock absorber is adopted for all lineup 32 way adjustable damper rates Ideal for both street or circuit use. A large 44mm diameter piston is used (Some vehicles area excluded) This damper can be overhauled to maintain prime condition. STRUCTURE A single mono tube design is adopted for the complete range. A large 44mm diameter low friction piston control initial damping, allowing a comfortable ride but a great driving response. DRIVABILITY AND COMFORT A 32 way damping rate is incorporated into both shock absorbers. With such a wide range of adjustable, driving performance and ride comfort are maintained at the highest level, even at low speed. Spring rate is setup for each vehicle. A comfortable ride can be achieved with the height adjustment function which allows enough stroke for any driving conditions. STYLING The spring sheet and upper mounts are finished in a red alumite. The brackets are finished in a classy matt black. The height adjustment function is shown in millimeters, allowing a wide range of setting to suit any driving conditions. SETTING Preload adjustment of the spring and the height can be adjusted separately. A variety of damping rates can be achieved through simple adjustment. Camber adjustment allows alignment to be set to personal preference. DURABILITY The cylinder case is finished in a black chrome overlay and the bracket is finished in a special point to improve durability and anti-corrosion. Last edited by jbetanc; 12-11-2021 at 03:40 PM. Reason: pics, lower price, lower price |
#13452 |
$20! Take it off my hands!
#13453 |
Drives: 2019 6MT on CSG flex A w/SX2s
FS: Mishimoto sound-tube delete
Original thread:
https://www.ft86club.com/forums/show...02#post3485002 New, open package. $5 picked up in 90232. $10 shipped. |
#13454 |
FS: Grimspeed lightweight crank pulley
Price reduction (hence re-post)
Original thread: https://www.ft86club.com/forums/showthread.php?t=147371 $60 picked up in 90232 $72 shipped. |
Tags |
caliusedpartsstore, downs, lowering springs, rsr, selling, shift knob for sale, side marker, socal, spoiler, trd |
Looking for another Local FRS/BRZ! | XR4OUTCAST | Mid-Atlantic | 18 | 11-09-2012 02:20 PM |
Anyone local with aftermarket exhaust yet? | Areddi | Mid-Atlantic | 20 | 09-13-2012 07:40 PM |
Local Classifieds? | Hanakuso | Site Announcements / Questions / Issues | 1 | 08-15-2012 02:09 PM |
BRZ at Local Atlanta dealer! | subatoy | Southeast | 2 | 03-02-2012 03:08 PM |
calling ya local dealer | Slide | AUSTRALIA | 147 | 12-30-2011 01:10 AM |
