05-31-2016, 02:28 PM | #1331 | |
Drives: 2013 Black BRZ Limited
The Following User Says Thank You to taiguy For This Useful Post: | 86Tony (06-06-2016) |
05-31-2016, 04:21 PM | #1332 | |
1337
Drives: 2013 BRZ WRB S/C
We're both of the gaskets wet or just the passenger side? If they are both wet, could it be just blowby? Was only one injector dirty on the passenger side? |
05-31-2016, 04:43 PM | #1333 |
05-31-2016, 05:01 PM | #1334 |
Drives: 2016 Oceanic, "base" model
I searched on "IS300" and "lower gears" but found nothing.
Did anyone install the lower gears from an M/T, LSD, IS300 after installing this? If so, did you get better mileage? |
05-31-2016, 07:51 PM | #1335 | |
1337
06-01-2016, 12:10 PM | #1336 | |
Drives: 2013 Subaru BRZ
51-4223 For future part numbers you can also reference Pages 3-7 of the installation notebook. Each part included in the kit will have designated "P/N." In the above case see: PG. 3, Bag #4, Item 6. Please let our tech dept. know of the torn o-rings and we should be able to mail replacements right out. |
06-02-2016, 12:04 PM | #1337 | |
Drives: Scion FR-S (Hot Lava)
From the picture, it seems like there might be some tearing on one of your seals. Somewhat hard to tell if it's damage or grime from just the picture. Edelbrock suggests using lubrication on these to keep from folding or tearing during installation. |
06-02-2016, 01:29 PM | #1338 |
Drives: 14 BSP Edelbrock BRZ
That looks like casting flash that just has oil on it.
Sent from my Nexus 6 using Tapatalk |
06-02-2016, 07:23 PM | #1339 | |
http://www.ft86club.com/forums/showp...&postcount=749 Not definitively saying this is the reason for his problems, but just something to look out for in future installs. |
06-02-2016, 07:40 PM | #1340 |
Nice catch, that does look like exactly the same place that got snagged on the other install.
The Following User Says Thank You to toast For This Useful Post: | Nitro22 (06-02-2016) |
06-02-2016, 09:20 PM | #1341 |
Have a whole (small) tub of silicone grease dedicated to putting the new gaskets in. Will probably be a project for next week, I'm still rushing to get motorcycles prepped for the weekend.
06-05-2016, 01:07 AM | #1342 |
e85!
Drives: 2013 Scion FR-S M/T
This may pertain to you since you have similar idle issues, and CEL codes as I did relating to a vacuum leak. My vacuum leak was coming from the actuator that sits under the driver side of the Edelbrock supercharger housing. Every time I sprayed it with the car on and at idle, it bogged down and stalled out. Huge shoutout to Topher from Edelbrock for helping me get the replacement asap. Same day as I called Edelbrock, Topher shipped out a new actuator and it arrived 2 days later. I replaced the actuator, spray tested the new one, and engine idle remains constant. Cleared the code and I'm good to go. Idle is back to normal after testing and no longer jumping or stalling out. Haven't popped a code since. Again, thank you Edelbrock for the quick response and awesome customer service.
Scion FR-S M/T | HRI Tuned - AMS Catted Header - DW 700cc injectors - DW 265lph Fuel Pump - MotoEast Flex Fuel Kit - Greddy Evolution GT Catback Exhaust - Exedy Stage 2 Clutch - Edelbrock Supercharger
The Following 3 Users Say Thank You to EJ. For This Useful Post: |
06-05-2016, 12:43 PM | #1343 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
^also, I've been told by Edelbrock to never actuate that by hand since you can accidentally tear the rubber diaphragm inside.
The Following User Says Thank You to BigFatFlip For This Useful Post: | EJ. (06-06-2016) |
06-06-2016, 12:02 AM | #1344 | |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
