Old 04-28-2014, 04:44 PM   #1331
sprintamx
Where/how are you measuring ride height? Sorry if its been asked/answered before.
sprintamx is offline   Reply With Quote
Old 04-28-2014, 04:45 PM   #1332
fz6r
Drives: 13 10 series FRS
Originally Posted by Racecomp Engineering View Post
Need to know the spring rates and drop.
- Andy
Drop - Front: -35mm, Rear: -35mm
Rates: - Front: 3.26kg/mm(183lb/in), Rear - 3.94kg/mm(220lb/in)
fz6r is offline   Reply With Quote
Old 04-28-2014, 05:20 PM   #1333
Best to measure from center of wheel hub to edge of fender.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
sprintamx (04-28-2014)
Old 04-28-2014, 05:22 PM   #1334
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
That's a bit more toe than I'd like. I generally like zero in front and a tiny bit of rear toe in. Rear is driver preference IMO....some like a more loose car and will run a little toe out.
More negative camber up front would be ideal for the track. And slightly less in the rear, but it would be good to know your spring rates.
- Andy
Thanks! It's Tein Street Flex standard spring rate.
I am debating lowering the rear a bit to lessen the camber and push the fronts a bit more to 3.0 at the track.
GTHachiRoku is offline   Reply With Quote
Old 04-28-2014, 05:25 PM   #1335
That's very soft, especially with a 35mm drop.
- Andy
Old 04-28-2014, 05:29 PM   #1336
Lowering the rear ride height? That will increase rear negative camber.
You can also change handling balance a little with rake if you like.
- Andy
Old 04-28-2014, 05:59 PM   #1337
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Right now I'm running -3.5 degrees of camber up front with RCE Tarmac springs and koni yellows. And about -2.1 degrees of camber in the rear. Stock sway bars ect. In autocross this setup is great. Just grips everywhere. However I will say it lost its fun factor for daily driving. Its so grippy in the front and the rear now its hard to slide the car around like it did stock. I have to drive it really stupid on the street to slide it at all and thats not something I'm willing to do. I miss sliding it around at 10 or 15mph like it was nothing.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
CSG Mike (04-29-2014)
Old 04-28-2014, 07:02 PM   #1338
GTHachiRoku
Big in Japan
Drives: turBRZ
- Andy
Yeah sorry, I meant raising it a bit on the rear.
Ride height is about 24.5" floor to top on fender front and 25" on back.
This is the specs I used to adjust the coils before installation.
Old 04-28-2014, 07:24 PM   #1339
Malt
Drives: 2015 WRX
Do you remember what the ride height was before your coil installation? I've been looking for this info everywhere and cant find it.
Malt is offline   Reply With Quote
Old 04-28-2014, 07:37 PM   #1340
FastWhite
Drives: Subaru BRZ Limited M/T
Just installed some Koni's on the car with the stock springs. I got ~14" front and ~14.5" at the rear. There still settling
FastWhite is offline   Reply With Quote
The Following User Says Thank You to FastWhite For This Useful Post:
Malt (04-28-2014)
Old 04-28-2014, 07:40 PM   #1341
Malt
Drives: 2015 WRX
that's measured from where to where? I'm guessing the hub to top of wheel arch?
Old 04-28-2014, 07:42 PM   #1342
FastWhite
Correct, center of wheel hub to the wheel arch.
Malt (04-28-2014)
Old 04-28-2014, 08:11 PM   #1343
sprintamx
Before installing my coil-overs, stock height was 14.5 inches from the center of the hub to the center of the fenders F&R. BRZ limited, mounted on 225/45 17.
Old 04-29-2014, 12:11 AM   #1344
fz6r
- Andy
Is that a bad thing?
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
