Old 04-28-2014, 11:20 AM   #1317
Racecomp Engineering
RCE or HVT plates should do the trick as well. A good quality plate is a little more expensive, but will last longer they'll have a high quality spherical bearing.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Malt (04-28-2014)
Old 04-28-2014, 11:32 AM   #1318
Teo
Teo's Avatar
Since I now shifted to better tires, I run Neova Ad08r 215-45-17 I want to have a good setup for trackday use.
I have Tein Street flex
Can you please suggest me camber and toe, and most important (for me), can you please suggest me ride height? that won't kill me on speedbumps
Thanks
Teo is offline   Reply With Quote
Old 04-28-2014, 11:32 AM   #1319
gramicci101
Off Topic
Also, some plates will raise or lower the car, so you should watch out for that when you're shopping.
Old 04-28-2014, 02:08 PM   #1320
wparsons
wparsons's Avatar
- Andy
Will the RCE or HVT plates work with stock struts and stock diameter springs? From what I've seen, most only work with coilovers
flickr
Old 04-28-2014, 02:22 PM   #1321
wparsons
wparsons's Avatar
Thanks
Within ~1" of stock is good, definitely no lower than 1.5" unless you plan to add more parts to correct the roll centers.
flickr
Old 04-28-2014, 03:37 PM   #1322
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
@RacecompEngineering @CSGMike
I'm planning on getting LCAs but for the time being setup like this on Tein coilovers and 17x9 wheels on 245/40 RE11A tires.
I'll have to measure when I get home, but the drop is somewhere in the 1-1.5" range I think.
Do you think this will be OK for at least a couple track days? Any recommendations?
GTHachiRoku is offline   Reply With Quote
Old 04-28-2014, 04:08 PM   #1323
fz6r
Drives: 13 10 series FRS
Originally Posted by Malt View Post
You'll need something to get your camber and toe back to reasonable levels with a 1"+ drop. Bushings are not necessary but obviously have the upsides and downsides. Be prepared to spend $$$ if those bushings need to be pressed in and out if you don't have a means to do it yourself.
So the set up I'm looking at is Koni Yellows with Mann Engineering lowering springs and SPC rear lower control arms. Do you think this will be a good set up? I'm running Enkei Kojin wheels 17x9 ET 42 up front and 45 in the rear with a 245/40-17 tire.
fz6r is offline   Reply With Quote
Old 04-28-2014, 04:13 PM   #1324
Those 2 will work.
- Andy
wparsons (04-28-2014)
Old 04-28-2014, 04:17 PM   #1325
That's a bit more toe than I'd like. I generally like zero in front and a tiny bit of rear toe in. Rear is driver preference IMO....some like a more loose car and will run a little toe out.
More negative camber up front would be ideal for the track. And slightly less in the rear, but it would be good to know your spring rates.
- Andy
Old 04-28-2014, 04:18 PM   #1326
Malt
Drives: 2015 WRX
I can't comment on the wheels as I'm running stock rims and have no idea about their fitment. I can only assume you arrived that those offsets due to research on these forums.
As for the rear LCA's, I plan on using those exact arms if I can't get my camber fixed with my rear camber bolts and replacing the toe arms. If you don't mind spending another $200 that may or may not be necessary, I'd recommend getting the SPC toe arms as well. They are much easier to adjust, have a much larger range than the factory solution, and if you get everything installed and go to get an alignment and they can't get your camber dialed in due to toe issues (like I'm facing right now), that means you'll have to buy them anyway and pay for a second alignment. They are "cheap enough" to where I wouldn't want to risk it knowing what I know now.
Malt is offline   Reply With Quote
Old 04-28-2014, 04:19 PM   #1327
wparsons
wparsons's Avatar
Those 2 will work.
- Andy
Great, thanks Andy!
Any thoughts on slotting the stock struts and running the offest bolts still? I know the TII's come slotted stock (wish I had the budget for those this year, but it was those and no events or springs and money for events ), but typically they would be run with the stock upper bolt.
flickr
Old 04-28-2014, 04:26 PM   #1328
Thanks
-3 front camber, -2 rear. 0 toe front. Rear toe depends on driver. A little bit of toe in is good for stability, a little bit of toe out if you want more oversteer. This is a good start...you may like a little more camber.
30mm to 40mm ride height is good.
- Andy
Old 04-28-2014, 04:29 PM   #1329
Need to know the spring rates and drop.
- Andy
Old 04-28-2014, 04:33 PM   #1330
Great, thanks Andy!
Done right it has some advantages. I'm just always worried about it not being done correctly.
You would probably use the OEM bolt if you did it.
- Andy
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
