Sam Strano
Old 07-22-2014, 02:50 PM   #1317
automatic
Drives: WRB BRZ
Shock tuning question:
I'm running Koni Yellows and I'm still trying to figure out the adjustment settings.
Last event, I ran an event on an oval track and the surface was almost completely free of bumps.
My fronts were set to 1/4 turn to stiff
Rears were 1/2 turn to stiff.
Assuming a perfectly smooth surface, would it have been beneficial to turn the fronts up to fill stiff to have quick rebound for this course?
Would it be beneficial to turn the fronts to full stiff in general assuming a perfectly smooth surface?
There were 2 slalom sections that I felt I was losing time on but I did not want to make an adjustment because competition was so close.
I'm on the bottom (blue car):
[ame="https://www.youtube.com/watch?v=NRbjF2sWSqg"]July 20, 2014: CASC Event #4 Kawartha Downs Serge vs Frankie - YouTube[/ame]
automatic is offline   Reply With Quote
Old 07-22-2014, 06:15 PM   #1318
Jawnathin
Drives: Toyobaru FRZ
Originally Posted by 7thgear View Post
so after 4 events on the recently installed strano bar, I think it's too thick
while the car is now ultra stable and confidence inspiring, especially at higher speeds, it seems to have no character in the tighter sections.
but I'm wondering whether to chalk that up to the bar, my 235 tires on oem wheels (such wide R1Rs do feel sluggish in really tight sections), or just driving style, maybe I need to throw the car more into such corners.
any thoughts?
First autocross with the Strano bar this past weekend. Coupled with Konis and 225 MPSS. Still waiting for my RS3s to show up. Anyway, the car felt pretty good. Stable when I drove neatly, tossable when I throw/chuck it around. But it was a higher speed event without much slow speed stuff.
Will have a tighter autocross this weekend that should test the front tires/grip, will provide some more feedback on the Strano bar then. Will still be on the same Koni/MPSS setup.
Jawnathin is offline   Reply With Quote
Old 07-22-2014, 06:38 PM   #1319
vroom4
Gosh, some of you guys didnt get any mileage out of your Z2 or you're deffinition of dead is way different than mine. We have 200+ runs on our Z2 and 7000 street miles. They still have 30% or so left before I designate them as fun run only.
vroom4 is offline   Reply With Quote
Old 07-22-2014, 09:39 PM   #1320
Biggins
Drives: Yes
My ZIIs are at the wear bars and have been for months, and they're still pretty fast. I don't run them often at events anymore, but they have 180 runs with 6k street miles. They definitely last longer than hankooks and yokohamas.
Biggins is offline   Reply With Quote
Old 07-26-2014, 03:29 PM   #1321
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
Tire comparisons
There was a discussion in another thread where I asked how to compare tires. The response was...
your placement on the totem pole is generally a good indicator of your car setup, especially if you have other experienced competitors always coming out, so the difference between your time and theirs could be an indicator of improvement.
So I did some analysis of Twins that run in the same groups I do. Here are the results.
The calculation is PAX time based (to be able to compare STX and CS in the same chart). Then divide each driver's time by the smallest time to get a factor above the fastest PAX time (i.e. bigger factor is slower driver). As you can see, I improved enormously compared to the group by changing from Prius Specials (orange circle) to Hankook R-S3s (blue circle).
CS John is the benchmark because he is always the fastest of this group of cars (yes, all three dots are 1.00), but STX Chris is also very consistent over these three events.
This just shows how much a tire change can improve your relative results. I still have a long way to go.
If anyone sees any flaws in my analysis, let me know. I can modify it I suppose before I get too deep, but I intend to continue updating this as the season progresses.
For those of you outside of Texas, be advised that it has been VERY HOT at all of these events, so your results may be different on cooler tracks with different tires.
Cheers,
Last edited by bimmer635csi; 08-11-2014 at 11:08 PM. Reason: Organized Dropbox better for future use
bimmer635csi is offline   Reply With Quote
Old 07-26-2014, 11:25 PM   #1322
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Cheers,
I guess my question would be, how experienced of an autocross driver are you and how long have you been autocrossing this specific car? Because going from the OE tires to the Hankooks would be a big difference, but getting 3 more drives in the car would also show a big improvement.
DylanFRS is offline   Reply With Quote
Old 07-27-2014, 08:43 AM   #1323
bimmer635csi
I've been autocrossing over 2 years. Probably 30 events or so. Most of that has been in a VW GTI, 3 events in the FR-S and 6 in a BMW 330Ci.
You bring up valid points. But the only way to do this test correctly would be to have a robot driver that could do everything exactly the same in every car on each tire. We can't afford to do that, so this is the best I can do with the given budget and information.
Cheers,
The Following User Says Thank You to bimmer635csi For This Useful Post:
DylanFRS (07-27-2014)
Old 07-27-2014, 11:45 AM   #1324
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
I've been out of the loop with the new street classes, but are 04 STi wheels allowed in CS? I know Stock class allowed a difference in offset with non-OEM wheels. Does this apply to C Street? My motivation to going with 04 STi wheels is the weight savings & looks over the OEM wheels.
Edit: nvm I just saw the 1st post "Stock sized wheels within 6mm offset". Thanks!
Edit #2: ah crap. I thought the 04 wheels were 7" wide, but they are. 7.5".
iLuveKetchup is offline   Reply With Quote
Old 07-27-2014, 12:27 PM   #1325
bimmer635csi
This year, you are allowed to go +/- 1" in diameter though, so they don't have to be "stock size", and the +/- 6mm offset rule was actually a typo and should be +/-7mm now. This was because SCCA finally realized that nobody measures offset in inches anymore.
Old 07-27-2014, 12:29 PM   #1326
iLuveKetchup
Drives: EFF JAY
Yes that's right. Not too much benefit with +diameter on a BRZ though.
Old 07-28-2014, 12:50 PM   #1327
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
too complicated
simply log the raw time difference between yourself and the regular folk that come out to your events
doesn't even have to be the same car or class, just people who are on street tires and that are always coming out.
soon enough you'll have some nice data to work with
Old 07-28-2014, 01:05 PM   #1328
bimmer635csi
too complicated
I'll look into that. I have the raw data already to do my calculations above, so it should be fairly straight forward.
My thinking for comparing FR-S/BRZ cars only was to eliminate the courses that favor power over momentum & vice-versa. Again, only my thinking, but it seemed like if a course was a straight shoot out and back, that might favor the easy-button 370Zs, but if the next course was a 50-ish second course with an average speed of 10 mph, that might favor the twins more. By comparing twins only, that "course favoring factor" is not an issue (or so I thought).
Let me see what else I can cook up tonight (other than chicken that has been in the fridge too long) and see what I can come up with.
Thanks for the input.
Cheers,
Old 07-28-2014, 05:29 PM   #1329
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
For the best of both worlds, use the raw data, normalize it to 60 seconds, then see what your delta is compared to your competitors.
neurokinetik is offline   Reply With Quote
Old 07-28-2014, 05:30 PM   #1330
vroom4
Less calculating, more driving. When you take top PAX'd time of day, then you can worry about calculating.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
