#1317 |
Drives: Toyota 86 GTS
No real updates on when this kit will return for anyone wondering.
I contacted them about a week ago basically saying they were my first option but I’ve been waiting over a year and whether it’s worth holding out for them if it’s to return within the next few months or go with something else and the response I got was basically still they have no updates on when the kit will return OR the price… Them mentioning price was interesting as I never mentioned that in my email, hopefully if there is a price increase it won’t be too significant as the kit was already fairly expensive even to local Aus buyers. Wonder how it’ll compare to the Edelbrock as I believe Harrops kit with no tune was 8.7K AUD before it was removed, and Edelbrock with no tune currently is about 9.4K- 10.5K AUD (if you can even find someone with it in stock) |
#1318 |
Drives: Toyota 86 GTS 2019
I finally found a supercharger kit for my car, second hand. Got pretty lucky as it was removed by Harrop. I reached out to them and they offered support even though I was not their client then. Great company.
Car got its last tune yesterday (85mm pulley, E85 only). Now patiently waiting for the first track day of 2023 https://imgur.com/Ri7Z0na She seems to be quite thirsty now, so I'll see you soon at the E85 pump at the Gabba Grumpy Snapper... |
#1319 |
At the track
Drives: '14 FRS - Former e92 M3
If anyone in here is looking, I have a used kit off of my car that was rebuilt by Harrop and never reinstalled. I am planning on posting it in the classifieds next week.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
#1320 | |
#1321 |
Drives: GT86. Soon...
Hello all - from Melbourne, Australia!
I thought you guys may find this interesting, regarding the Harrop Supercharger. I was curious myself for future purchases and asked if they have an update on this as there are quite a few people interested on the status. They responded with the message below : Rest assured, we definitely will be bringing back the FA20 supercharger kit. The current hold is related to a revision for the new FA24 kit. To confirm, we plan to have the supercharger kit re-release for previous FA20 and new FA24 in the coming months with pricing TBC. So, we just need to be patient it seems Still no release date yet except for itbeing re-released "in the coming months." Minor recent update, thought I'd share. -YakuzaMoon |
#1322 |
Hey all,
Recently acquired a Harrop SC that was never installed. I have a 16 FRS and it was my understanding that the kit was selected for a 17+, so the front of my OE 2016 Airbox would not fit and I need a 2017+ front airbox, NBD. Id rather acquire new gaskets for the manifold and throttle body, but because of the +17 airbox I'm questioning part # selection. Can anyone help me a bit? Don't know if the Harrop SC was based on 13-16 or if they revised it at all to accommodate 17+ Manifold Gaskets 13-16: 14035AA610 17+: 14035AA720 Throttle Body Gaskets: 13-16: 16175AA420 17+: 16175AA520 And while we're at it. Any other gaskets that should be looked at. I'd rather not swap over gaskets from existing system. I like new Thanks
Kyle H. - #89 STX
#1323 | |
Drives: Q5 + BRZ + M796
#1324 |
To follow up, encountering an issue.
Kit I purchased was 2017+, and naturally when I initially fit my 2016 front side of the airbox it did not fit. Thinking the design of the new 2017+ manual airboxes were indeed drastically different (considering part# revision) I ordered one of those. I'm still not getting anywhere close to the spring clip or bottom mold detents of where this thing should be lining up. So of course I tried to fit the 2016 Box. It "fits" but the bottom molds are definitely stressed to fit into the "female" portion on the lower intake filter box. With some massaging the male/female can mate so to speak but they're slightly angled. Everything can bolt up and seal but just want to make sure this is normal and/or I need a different box? (honestly not sure what other one even exists). See the pictures to hopefully describe what I mean.
Kyle H. - #89 STX
#1325 |
That is a little strange.
Mine, and other Harrops I've seen from different years all seem to fit pretty easily. I guess the obvious first question is, is the filter the correct version and is it "seated" correctly? |
#1326 | |
Non-strain, the plastic tabs do not line up properly. Which hopefully I showed in the pictures where one tab is lined up the other does not correctly align
Kyle H. - #89 STX
#1327 | |
Master Collaborator
Same issue here on a 2015. I just bent them in a bit to make it all piece together. I'm wondering if the OEM AUS spec. air boxes are slightly different than the NA spec. cars. One other thing I will address while I'm here: Several pages back, someone decided to further explain some of the issues that they ran into concerning the differences they found when attempting the install themselves versus what is officially explained in the installation manual for an AUS spec (right-hand drive) car, and mentioned that the tool supplied to bend the A/C line was not needed due to the difference where the A/C lines enter the firewall. I am here to say that this is not true. The tool needs to be used on left-hand drive models as well. If you don't bend the line just slightly, the rubber section of the A/C suction hose will chaffe against that little "tit" sticking out on the driver's side of the blower manifold, which will eventually chaffe a hole in your A/C hose, as well as rub the powder coating off of the manifold at the point of contact. Since this line is so close to the clutch cylinder, failing to do this before setting the supercharger in place will make it nearly impossible to get any tools in there to bend it, which I am currently having to deal with. You'll see in the picture above that the A/C hose is touching the "tit" that I am speaking of. I currently have a piece of scrap PVC hose cut to wrap around my A/C line at that spot temporarily to keep from damaging the A/C hose, but again, as I said, this will not protect the manifold powder coating. If I zip tie it away from the manifold to the strut brace when it is reinstalled, it will look amateurish at best. It only needs to be bent between 5 and 10 degrees, but it DOES need to be done after you remove the OEM intake manifold and when you have plenty of working room. Hope this helps someone in the future.
#1328 |
Hi Guys,
I had my first track day since I installed the supercharger on my car. I was wondering what IATs other people are seeing / are to be expected? This is my IATs for my last session of the day Out 58°C Lap 1 74°C Lap 2 80°C Lap 3 86°C Lap 4 92°C Lap 5 94°C Lap 6 96°C In 82°C I am in Brisbane Australia, ambient Temperature was 30+°C at that time. My car has Verus hood vents. Thank you! |
#1329 | |
#1330 | |
Were you out at Willowbank, and do you know what the actual temps were on the track? |
| JDL turbo kit owners thread | yomny | Forced Induction | 1352 | 01-08-2025 04:20 AM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 01:18 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
| Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 02:50 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
