Old 03-07-2014, 10:45 AM   #1303
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by ecko04 View Post
Your statement is incorrect.
A 3" charge pipe for this car was only done so one could run a MAF based tune only. That was way before EcuTek updated their racerom to include speed density.
Now with speed density, there is absolutely no need for a 3" charge pipe and the better tuning option would be one that is MAF based for light and partial throttle conditions and switches to speed density when you put your foot down.
Hmmm. Debating putting off my install more for this now
@jamesm will this make ur life easier when tuning is the real question?
lbroskee is offline   Reply With Quote
Old 03-07-2014, 10:50 AM   #1304
jamesm
the newer fa20club kits comes with a revised MAF tube that doesn't have the issues the older ones had. i've tuned both, and i can say the improvement is massive. if you bought your kit recently, chances are you have the new one. it's quite easy to tell, if you send me a pic i can let you know for sure which one you have.
Old 03-07-2014, 10:54 AM   #1305
lbroskee
lbroskee's Avatar
I got it in January so I'm 99% sure i dont (kit isn't stored at my house
Old 03-07-2014, 10:59 AM   #1306
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
FA20Club Turbo Kit Owners Topic
Take some pics
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 03-07-2014, 11:02 AM   #1307
jamesm
that's a completely different design than any of the three revisions i've seen. the first one had the MAF all crooked and in the bend, it was horrible. then the second (which a lot of people have, revision was made early on) has the maf placed further back towards the throttle body in the same are. it's perfectly fine, better than most actually but there was still room for improvement. the third revision my friend just got in the mail a couple days ago has the maf flange between the bend and the blow-off valve. i've never seen one like the images ecko posted. did that come from fa20club?
Old 03-07-2014, 11:13 AM   #1308
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Yes, it's a design I helped Toni with.
Old 03-07-2014, 11:14 AM   #1309
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
The reason I came up with this as opposed to the MAF flange between the bend and blow-off valve was due to Full Blown. Their initial setup with the MAF placed between a bend and blow-off valve caused instability with the MAF and the BOV would open, sometimes, at idle. Some guys had to run stiffer springs due to this.
The guys I use for tuning saw the two 45 degree angles with the MAF between them as a problem. This was proven when my fuel trims with the cruise control set would greatly fluctuate. It took a lot of logging and tweaks to get it resolved. On the dyno WOT pulls would read different g/s due to air that would move around the MAF as opposed to through. This was a problem that presented itself even more during cruising as the air could hit a bend and find its way around the MAF instead of thru it.
Ditching the 3" diameter in favor of 2.75" and going with a single 90 creates a smoother flow. Furthermore, the intercooler plumbing tapers down to 2.75" anyway so sticking with 2.75" all the way through made sense.
Old 03-07-2014, 11:30 AM   #1310
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Interesting... Mine is real close to the throttle body but after a slight bend.
pixel67 is offline   Reply With Quote
Old 03-07-2014, 11:32 AM   #1311
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
^ that's the same as I have. Not the greatest by any stretch of the imagination.
Old 03-07-2014, 11:33 AM   #1312
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
No 2 fa20 kits are created equal
Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Hawaiian (04-24-2014)
Old 03-07-2014, 11:42 AM   #1313
jamesm
i've tuned many FA20Club kits with this MAF tube design, this is the second version. it works perfectly fine, in fact my base map is usually within 3-5% just flashing it on using this tube. the new ones are better, but this one if perfectly serviceable. takes a little more effort to get dialed in if you don't already have a good base map, but it can be done (and once it's done, they're fairly repeatable from kit to kit).
The Following User Says Thank You to jamesm For This Useful Post:
pixel67 (03-07-2014)
Old 03-07-2014, 11:43 AM   #1314
pixel67
pixel67's Avatar
Lucky me... Hopefully Bill can tune with this thing. Its starting to feel like "The Money Pit".
The Following User Says Thank You to pixel67 For This Useful Post:
ecko04 (03-07-2014)
Old 03-07-2014, 11:53 AM   #1315
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
It's ok. It's not that it won't work or can't work, it just takes time to get dialed in. A lot of time, probably more than a single dyno session can do. Make sure you have a cable and dongle so you can log and have periodic updates performed until it's fully dialed in. That's the best way that I found that worked.
Old 03-07-2014, 11:54 AM   #1316
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
More pics of the new piping
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
