05-26-2014, 11:57 PM | #1303 |
Off Topic
Replace the mirror with a tablet and a rear view camera?
05-27-2014, 12:00 AM | #1304 |
05-27-2014, 12:07 AM | #1305 | |
Drives: 2013 WRB BRZ Limited
Sent from my Nexus 5 using Tapatalk |
05-27-2014, 02:14 AM | #1306 |
great question. i dont have an answer though. on a miata, a 225 on a 9" rim is about as fast as you can get on a road course. 205 on an 8" rim is faster at wsir for slower miatas. i dont know how that data translates to a much bigger car but i imagine a pyrometer and a couple sets of wheels would help figure it out. im not fast enough to need that info. i only cooked my 205 re11 on 7" rims once but i think it was my driving. i havent driven in the heat since the original azenis was new.
if i ever feel that im faster than my miata (or just get bored of it or if i decide to make my brz cool anyways) ill probably just copy the csg car. im trusting you to do all the heavy lifting. |
The Following User Says Thank You to fatoni For This Useful Post: | kavanagh (05-27-2014) |
05-27-2014, 02:48 AM | #1307 |
Drives: gt86...among others
Hey Mike,
Our car is developing a push on a mid-speed righthand sweeper and a righthand 90. Not sure if this is a tire issue or set-up. Last 2 races were run on Toyo R1R (Treadwear 140) and Maxxis RC-1 (Treadwear 100) both 235/40/17 Set-up Ohlin DFV's 550lb springs front 3/20 stiffness 500lb springs rear 5/20 stiffness LF camber= 3*12' RF camber= 2*30' Rear camber= 2*15' OE front swaybar Disconnected rear swaybar 3mm toe out front 2mm toe in rear Ride Heights (from ground to fender) LF 64.5cm RF 65.5cm LR 66.5cm RR 67cm Weights(with driver) Total= 2830 Left%= 52.05 Front%= 56.86 Cross% (RF-LR)= 49.21 Tire temps LF= 98, 88, 80 (Outside, Middle, Inside) LR= 80,80,80 RF= 90,80,81 (Inside, Middle, Outside) RR= 72,72,73 Any ideas? Do you think we need to stiffen the front or try to transfer more weight to the rear of the car?
racing gods live deep in corners
05-27-2014, 04:18 AM | #1308 | |
Keep in mind, aero and rolling resistance are a larger factor for the FRS/BRZ, than miatas. Now I'm curious as to what your handle is on the other forums... |
The Following User Says Thank You to CSG Mike For This Useful Post: | ayau (05-27-2014) |
05-27-2014, 04:28 AM | #1309 | |
Your static load balance is way off. Assuming motion ratios of 0.95 front, and 0.75 rear, look at this ratio: Front effective spring = 550 Rear effective spring = 500 * 0.75 = 375 Front effective spring % = 59.45 Rear effective spring % = 40.54 Keep in mind that motion ratio in the rear is probably lower than 0.75, so my numbers are off. Now add the fact that you're adding MORE spring to the front with the front sway, and no rear sway, and you're overloading the fronts, causing the fronts to always wash out before the rears, short of a massive driving error or forcing the rear to come out. Now, because you have this static understeer, you're trying to fix it by adding front toe-out, which helps initial turn-in, but hurts static grip, making the front understeer even more. The rear toe-in, I'd guess, is to help stabilize the car, because any oversteer that occurs with your current setup is violent. Proposed Solution: Increase front camber to -3.4 on BOTH sides, and increase rear camber to -2.35. Your inside pyrometer readings are higher because you have too much toe. Soften your front springs, or add rear springs, and re-connect that rear sway bar. Then, zero out your toe, front and rear. The car will be "looser", but far more progressive. If it's too loose, then add 1/16" total toe-in. If it's still too loose for your taste, then add more rear camber. |
The Following User Says Thank You to CSG Mike For This Useful Post: | SirBrass (05-27-2014) |
05-27-2014, 08:02 AM | #1310 | |
Greatly appreciated. We'll give it a shot and let you know the results. Next race will be mid June. For reference:
05-27-2014, 12:14 PM | #1311 |
can you explain what you mean by that? oh and im fatoni everywhere i think. this has been by far my most active forum since its a new car and there has been a lot of learning.
05-27-2014, 01:20 PM | #1312 |
Master Troll
Drives: 2013 BRZ Limited
So i've been looking into a competition seat due to a need for about 2" of headroom with my helmet on and I like the Sparco Evo 3 seat. Has anyone found alot of headroom with any particular aftermarket seat? I would like it to have provisions for anti-sub belts as I plan to cage and harness as well. I looked in the interior forum and didnt find much help.
05-27-2014, 01:32 PM | #1313 | |
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
05-27-2014, 01:33 PM | #1314 | |
i'm sorry, what?
Drives: Canada
actually it depends on where the car sits, and is around 0.8-0.82 according to my measurements from OEM height through 30mm of compression see my notes starting on post 120 and on http://www.ft86club.com/forums/showt...t=26661&page=6
The Following User Says Thank You to 7thgear For This Useful Post: | CSG Mike (05-27-2014) |
05-27-2014, 01:38 PM | #1315 | |
The FRS/BRZ can "tuck in" the wheels for better aero, without giving up any motion ratio or tire width. Also, we have more tire options. Different tires make a HUGE difference depending on the track. Stock tires will show a 15 mph differential at ACS Roval, versus sticky 255 tires on low offset wheels. |
05-27-2014, 01:39 PM | #1316 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | 7thgear (05-27-2014) |
Similar Threads | ||||
Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 07:48 AM |
Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 09:54 AM |
