Old 08-09-2018, 05:10 AM   #1289
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
[ame]https://www.youtube.com/watch?v=LWcGJTd1fI4[/ame]
The Following User Says Thank You to nikitopo For This Useful Post:
krayzie (08-09-2018)
Old 08-09-2018, 07:34 AM   #1290
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I Googled their Cliche Corner and it's right by Fogolars Country Club at Lower Baseline Road in Oakville. Not sure where the other roads they filmed are.
Never occurred to me that Oakville and Milton have a lot of curvy roads.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
nikitopo (08-09-2018)
Old 08-09-2018, 09:56 AM   #1291
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Let's see now how Subaru will react ...
Old 08-09-2018, 10:55 AM   #1292
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Originally Posted by nikitopo View Post
These guys are hilarious - just the right blend of humour and seriousness to keep things interesting.
One of them actually had a cameo in one of Dezoris/Savagegeeseseses' videos.
daiheadjai is offline   Reply With Quote
The Following User Says Thank You to daiheadjai For This Useful Post:
Old 08-09-2018, 02:43 PM   #1293
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Local(ish) dealer is offering me an '18 GT for $22K (MSRP $31.5K). Wife is car-blocking right now, though. Gotta convince her it's worth it...
kmbkk is offline   Reply With Quote
Old 08-09-2018, 03:26 PM   #1294
Sasquachulator
Pavement Grey
They'll do something like Subaru BRZ TS RA spec A type G.
Recaro racing seats, even bigger rear spoiler, lightweight alloys, Alcantara everywhere replacing the leather/leathery stuff.
Rear seat delete, more suspension tweaks. Its now harder and stiffer!
And have the same 205hp!
The Following 5 Users Say Thank You to Sasquachulator For This Useful Post:
chaoskaze (08-09-2018), daiheadjai (08-09-2018), StraightOuttaCanadaEh (08-09-2018), SuperTom (08-09-2018), WolfpackS2k (08-13-2018)
Old 08-09-2018, 04:20 PM   #1295
krayzie
Drive From Home
krayzie's Avatar
The 86/BRZ isn't Subaru's own car like the WRX STI, the Toyota gods would have to approve first.
Subaru of course have much more important things to tend to.
[ame]https://www.youtube.com/watch?v=K3oRjv88GBQ[/ame]
Old 08-09-2018, 05:18 PM   #1296
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
^^ That STI is riced out with like $5 double sided tape on parts you'd find in autozone.
15 red pin stripes on the exterior, tacked on trims, and piano black everywhere inside the car... vomit. Subaru is trying too hard in the areas where it really doesn't need to.
TylerLieberman is offline   Reply With Quote
The Following 3 Users Say Thank You to TylerLieberman For This Useful Post:
JeremyR (08-09-2018), krayzie (08-09-2018), SuperTom (08-09-2018)
Old 08-09-2018, 06:19 PM   #1297
LancePower
Drives: 2020 BRZ tS
I had heard of the Straight Pipes before, but had never seen one of their videos until this.
Now it all makes sense, they chose the name because they are so overtly homosexual....................riiiiiiight?
LancePower is offline   Reply With Quote
Old 08-10-2018, 01:43 AM   #1298
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by TylerLieberman View Post
Pistons, rods, cams, valves, springs, retainers have all been changed on the new engine. As has the intake/manifold and exhaust manifold
It's not a question of matching the ND2, it's a question of getting close for less money. Slightly lighter rods and pistons are always a nice to have but chances are the engine isn't going to blow up if you don't swap them out.
To get the higher rpms safely the valve springs should probably be swapped out, and while you're at it, the cams might as well be swapped out too. That should pick up a decent chunk of the power difference.
Again, if the ND1s drop in price fast enough, this could be a cheap, fun project.
Old 08-10-2018, 03:06 AM   #1299
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I can assume that there is more bureaucracy to make decisions and have an agreement between the two companies. It has been like this in the past too. However, the BRZ has been at the center of their evolution with an influence on the rest of their model line maybe even more than the WRX or STI. For example, the lower center of gravity in the new global platform is based on what they learnt from the BRZ. Same can be said about the current WRX and STI models where there wasn't much change from the previous model, apart from the improved steering and the new WRX engine which came again directly from the BRZ. The new FA24 engine in the Ascent model belongs again to the same family of engines starting with the one of the BRZ. Overall, I believe that Subaru has a great benefit from this collaboration and given the improvement of the Mazda engine (*) they'll have to provide an answer.
(*) Not a direct competitor, but these two cars have been compared heavily in the past by journalists and even by the manufacturers.
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
krayzie (08-10-2018), WolfpackS2k (08-13-2018)
Old 08-10-2018, 03:31 AM   #1300
TylerLieberman
Drives: '24 GR86
Double post
Old 08-10-2018, 03:33 AM   #1301
TylerLieberman
Drives: '24 GR86
I never said anything about matching cars. You mentioned the changes that were on the new engine, and I simply elaborated further on what all was actually done.
The ND2 is basically a slightly dialed back version of the BBR 200 package from the factory.
http://www.bbrgti.com/product/bbr-mx-5-nd-super-200/
Realistically, getting an ND1 to ND2 power levels will run about $1500 or so, excluding the valvetrain; which is pretty cheap at the end of the day.
Guess it just depends on what you’re wanting to do. To some (myself included) the 2019 is worth the wait and sticker price. Though I’m still not 100% if that’s what I’m going to do
2018s are going for like 8k off MSRP right now. So if somebody is on the fence and wants to get a great deal, now is probably the time.
The Following 2 Users Say Thank You to TylerLieberman For This Useful Post:
funwheeldrive (08-14-2018), Vic4uf (09-02-2018)
Old 08-10-2018, 09:09 AM   #1302
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Id wait until end of winter to decide. Tuners by then will have the 19's and will see how much more they can get out of the new setup. If its not much more than modding the 18's then I'm sure there will still be some on the lots at a discount
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
funwheeldrive (08-31-2018)
WTB [FL]: Mazda Miata MX-5 03-05 and 06-08, manual transmission SteelReign Cars for Sale/Trade 5 06-22-2015 03:01 PM
2016 mazda miata (MX5) reveal 9 PM EST Ernie L Off-Topic Lounge [WARNING: NO POLITICS] 1 09-03-2014 09:41 PM
FS: Supercharged 1992 Mazda Miata *$4000 OBO* BRZZZZZZZZZZ Canada Classifieds 5 08-18-2014 05:44 PM
The Mazda 2 trully the FWD Miata NA! Tbomb 25 Other Vehicles & General Automotive Discussions 24 01-14-2013 10:30 AM
