Old 06-21-2016, 02:09 AM   #1289
fibble
Drives: 2015 86 GTS
i think you will find wayno s maps run a bit less overall timing.
check the knock correction max A tables as well as total timing is Base Timing B plus Knock Correction Max A. I think you will find wayno has shifted the amount of timing in the knock correction table
Thanks Steve.
I must confess that I just scanned the Base Timing B table and noticed the more aggressive values in the higher load / higher rpm range (compared to OFT OTS).
I just checked the Knock Correction table and see your point .
fibble is offline   Reply With Quote
Old 06-22-2016, 09:54 AM   #1290
randomthoughts
Drives: 2014 White BRZ
OFT Stage 2 UEL
Originally Posted by solidONE View Post
Doesn't look too bad aside from some minor FLKC at 6k~7k. Look like you've brought the engine up to normal operating temps. I'm sure once you've brought the oil temps up higher you may begin to see even more FLKC. Personally I'd do a LOT more logging and gather more data before making changes. I don't like to make changes base on one single pull alone. Though, if you are uncomfortable with the amount of flkc you are getting you can try pulling a bit of timing from the base ignition advance map b, subtracting 0.34* starting from 5800rpm at 1.0 load and up all the way to redline, then retest. Also, you should be logging engine loads in your logs.
I ending up purchasing a Revworks UEL header from a local forum member and installed it on the weekend and flashed using Stage 2 UEL 93 OTS tune. My logs look much better but seems to be on the rich side now.
http://datazap.me/u/randomthoughts/3...1-5-8-10-11-12
randomthoughts is offline   Reply With Quote
Old 06-22-2016, 10:00 AM   #1291
fibble
Drives: 2015 86 GTS
Hi guys,
Interested in any opinions on the logs below - I am still working through some -FLKC.
The tune is an OFT OTS Stage 1 tune (v2.076) with modifications made to timing (Base Timing B and Knock Correction Advance Max A) for Aust 98 Octane very closely aligned to Wayno's brilliant work.
A few 2nd/3rd WOT logs.
http://datazap.me/u/fibble/wot-stage...8?log=0&data=1
General driving.
http://datazap.me/u/fibble/general-d...8?log=0&data=1
Unfortunately no Knock Correction or IAM fields via OFT as I have a D00G Rom.
Thanks
Old 06-22-2016, 10:24 AM   #1292
Boomerang
86
Boomerang's Avatar
Originally Posted by fibble View Post
Hi guys,
General driving.
Thanks
dude can you send me your tuned BIN file for a try, I have D00G too with no IAM etc?
Old 06-22-2016, 03:12 PM   #1293
G-awesome
Drives: 2015 Firestorm Scion FRS
Hi guys,
General driving.
Thanks
interesting...I was experimenting with Wayno's v107 map last night by copying all his new modifications to my tune and I noticed when accelerating when driving around, there's a weird spike in commanded afr where it goes lean around 3000-4500 rpm around 0.9 to 1.0 engine load.
http://www.datazap.me/u/gawesome/201...zoom=1219-1666
It sorta does the same thing on fibble's log as well. Not too sure what's causing it....new MAF overrun settings? (I'm not too sure what that does) Care to chime in Wayno? I don't think it's a big deal considering actual AFR is trending in the right direction but that commanded AFR spike is kinda weird.
G-awesome is offline   Reply With Quote
Old 06-22-2016, 03:34 PM   #1294
Kodename47
Kodename47's Avatar
Drives: UK GT86
MAF overrun tables define the target airflow on the overrun, used to adjust engine braking. These are not active when on throttle (surprisingly).
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
G-awesome (06-22-2016)
Old 06-22-2016, 05:00 PM   #1295
phrosty
That's normal. This happens right after transition to open loop during partial throttle. Commanded AFR seems to peg to a static value that AFR doesn't follow.
Beyond seeing that pattern, I've got no clue why it happens.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
Old 06-22-2016, 05:06 PM   #1296
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Looks good. The OTS stuff from OFT typically runs a bit rich. Also considering that the IAT were at and below 68*f since the engine will tend to run richer in cooler conditions on top the the LTFT you are getting in OL. I'd just leave it alone and see what the AFR's look like after some learning and with warmer IATs. You dont want to adjust the OL fueling to suite cooler temps then to be too lean in warmer weather. With the stock MAF IAT compensation you'd want to error on the rich side so you dont go too lean in hot conditions.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
randomthoughts (06-22-2016)
Old 06-22-2016, 05:19 PM   #1297
fibble
Drives: 2015 86 GTS
Just to be clear - my logs are based on timing tables (Base Timing B and Knock Correction Advance Max A) + the timing temp compensation values (which are not currently really in play - our winter) based on Wayno's v106.
All other values (including fuelling) are OFT OTS Stg 1 v2.076.
The Following User Says Thank You to fibble For This Useful Post:
Old 06-22-2016, 08:44 PM   #1298
randomthoughts
Ok thanks I appreciate the feedback!
Old 06-24-2016, 08:48 AM   #1299
Rezi
Drives: GT86
http://datazap.me/u/rezi/230616?log=0&data=1-11
http://datazap.me/u/rezi/230616?log=1&data=1-11
Surprisingly 3 out of 4 WOT pulls are showing no sign of knock. (2nd, 3rd, 4th gear, even road, uphill etc). But on one it is showing a little of "knock".
Dont know if the AC was on when it happened.
Shouldn't it also show on the other 3 if it is "really" knocking?
And the AC compressor also definitely triggers FBKC sometimes.
AFR&Commanded AFR are looking sweet. LTFT also.
Rezi is offline   Reply With Quote
Old 06-24-2016, 02:59 PM   #1300
G-awesome
Gonna guess it could be rising ambient engine or IAT temps? If IAM is perfect and it's detecting less than a degree of random flkc here and there, the ecu doesn't pull alot of ignition timing that will impact overall power...I think? That's what I noticed on my logs.
The Following User Says Thank You to G-awesome For This Useful Post:
Rezi (06-24-2016)
Old 06-24-2016, 06:33 PM   #1301
Kodename47
Kodename47's Avatar
Drives: UK GT86
Look for common factors; intake, coolant and oil temps play a part.
Depending on settings, but usually even if IAM drops to 0.9 the timing advance loss is less than that of FLKC retard during WOT.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 3 Users Say Thank You to Kodename47 For This Useful Post:
G-awesome (06-24-2016), Rezi (06-24-2016), solidONE (06-24-2016)
Old 06-24-2016, 08:41 PM   #1302
Rezi
Drives: GT86
My IAM dropped only once at 0.98.
IAT Compensation Table is already "aggresive". But i think i i'll leave it and let the ecu handle it. If it showed flkc/fbkc constantly then i would be worried. IAT was at 95f-100f
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
