Old 04-21-2014, 04:19 PM   #1289
Racecomp Engineering
Originally Posted by BRZZZZZZZZZZ View Post
Lots of fun, but the rear is pretty snappy with the sway bar set to stiff so I brought it back down to soft. I will try to reduce the toe to 0 in the rear. Really need wider tires to take advantage of the suspension now but I don't want to go up to 17" wheels.
Sounds good. Rear toe adjustment can help with the snappiness.
- Andy
Old 04-21-2014, 04:25 PM   #1290
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Originally Posted by Racecomp Engineering View Post
Yes, the Yellows are happier with front AND rear swaybars while stock benefits a great deal with just the front bar. That's by design....we wanted the springs to be good with stock swaybars (rather than really need a front bar or stiffer front rates like every other spring). When adding bars then you need to do both.
Did you get the replacement bumpstops with your used Yellows?
16mm is the common size for a rear bar for this car. Get an adjustable and find a setting you like (probably stiff). Whiteline is good. They do make an 18mm rear but it's pretty big...
- Andy
Got the bumpstops. Haven't had any issues with travel, they ride great and eat up bumps.
I usually go for smaller swaybars than most. I found the WRX 20mm bar was the best swaybar for my GC so 16mm will probably do fine especially if its adjustable.
I was looking at those bilsteins.... almost a grand for shocks... I hope we get a nice OEM USDM upgrade we can pick from soon.
Kostamojen is offline   Reply With Quote
The Following User Says Thank You to Kostamojen For This Useful Post:
Yobiwan (05-11-2014)
Old 04-21-2014, 04:50 PM   #1291
Cool, good to hear. Yeah go with the 16mm rear and play with the adjustments.
Hopefully there will be some new shock options eventually.
- Andy
Old 04-21-2014, 07:22 PM   #1292
gramicci101
Off Topic
I found RE-11's in 245/45-16, but the magic google box says they really prefer 8" wheels. Their minimum suggested wheel width is 7.5". Beyond that, anything over 225 I was only finding in a 17 or higher.
Edit: also Nexen N3000, Falken FK451, and Yokohama AVS ES100 in 245/45-16, but those are all UHP, not EHP.
Old 04-21-2014, 07:26 PM   #1293
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I don't really think I am going to get anything wider than a 225 on a 7" wheel, the sidewalls are already pretty bulgy, and a 245 may even reduce performance if the rim is too narrow.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 04-21-2014, 09:02 PM   #1294
Kostamojen
This car doesn't NEED anything over 225 anyway...
*runs for cover*
BigFatFlip (04-21-2014)
Old 04-21-2014, 09:38 PM   #1295
toysub
Drives: DGM
Hi all,
Read through 60 pages of this great thread. Thanks for all the great info.
I don't recall seeing too much info on rear lower control arms... what makes a good design and if there are any features that are specific to various uses. So many brands out there that look slightly different, but similar. Also curious if certain construction material, steel vs aluminum, is significant.
I'm installing ST coilovers for my 235/40-18s for my daily driver (no track use), but want to keep at minimum the great handling aspects of our twins. Not sure how low the drop will be, depending on the clearance I need for some driveway entries, so I may need some camber adjustments and want to keep a balanced alignment to avoid unnecessary tire wear if possible.
Thanks in advance for any helpful comments.
toysub is offline   Reply With Quote
Old 04-21-2014, 11:28 PM   #1296
Malt
Drives: 2015 WRX
I'm finally getting around to doing something about my rear suspension and alignment issues. A couple months ago I got eccentric bolts installed in the rear LCA's instead of buying an adjustable LCA. They got the camber closer to what I wanted but were unable to get it all the way because they ran out of toe adjustment.
Currently the rear is at -2 camber of the left and -2.3 on the right with 0 toe on both sides. I'd like to get a little toe in as well as get the camber evened out at -2 on both sides, which is where my question comes in.
I think there is room for more adjustment on camber with these bolts if I could get some more toe adjustment. Would replacing the toe arms with something like SPC's adjustable toe arms finally allow me to solve the issue or should I just bite the bullet and get adjustable LCA's as well? I'd rather not get the LCA's if they are not necessary. Are the SPC's adequate toe arms or would SPL's or something of that nature be more suitable for a mostly street driven/couple track days a year BRZ? Thanks for any input.
Malt is offline   Reply With Quote
Old 04-23-2014, 12:56 AM   #1297
Kostamojen
- Andy
So did my homework... Perrin adjustable 16mm rear bar or your rear bar? I can't find anyone that sells your rear bar separately.
Old 04-23-2014, 05:17 AM   #1298
Calum
That Guy
Drives: 2013 asphalt FRS MT
You could try these. http://www.stranoparts.com/partdetai...258&ModelID=36
Sent from my samstone
Old 04-23-2014, 06:03 AM   #1299
Malt
Drives: 2015 WRX
After getting quoted ~$600 to install the whiteline upper camber bushings I've been shying away from press in bushings. I can install toe arms myself and after factoring install costs on bushings, usually end up cheaper just replacing the whole part. I wish people would make this info more known. But thank you for your help.
Sent from my SCH-R970C using Tapatalk
The Following User Says Thank You to Malt For This Useful Post:
Slick (04-23-2014)
Old 04-23-2014, 10:41 AM   #1300
Are you absolutely sure you could get the camber you need with the bolts and a toe arm? How low are you? I have no clue how much adjustment they can get you.
- Andy
Old 04-23-2014, 10:52 AM   #1301
Malt
Drives: 2015 WRX
- Andy
I'm not sure how low I am since I can't get an answer from anyone what the stock ride height is and where the measured it from. One side is sitting at -2 which if where I want to be. Granted that's with 0 toe in the rear and I'd like some toe in. The shop just said they couldn't get it any closer because they were fighting with the toe.
Old 04-23-2014, 11:25 AM   #1302
K. Not knowing much about using bolts to adjust camber in the rear and how much adjustment they have, I'd just be worried about you buying toe arms and then finding out that your camber bolts are maxed out anyway. Can you peek under and see if there is much adjustment in the bolts left?
- Andy
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
