Old 03-31-2017, 05:45 PM   #1289
richie incognito
Drives: BRZ- all the colours
I'm running 215/40 square with 17x9 rears. On stock power/bolt ons its a good setup and you can run a more aggressive offset without compromising your camber setup.
richie incognito is offline   Reply With Quote
Old 04-02-2017, 09:22 AM   #1290
Shady195
Drives: '13 10 Series FRS #1203
Originally Posted by Rougenite View Post
Yeah 245s are def overkill, but they fit the rims very nice (17x9+35) and im usually the guy that likes to keep it glued to the ground, not spinning :P
Cost for boosting with PTuning stuff
6k for the kit,
1200 for fueling MAP sensor and ECUTEK stuff
800 or so for proper gauges and mounting
Oil cooler cost (1000 for Ptuning)
$300 for radiator
$500 clutch/flywheel
1200(?) for axles
AoS (Catch can) $200 or so
XXX for tuning
It really does start to add up quickly. I do already have some of these items, but still...Ptuning is an amazing company with great service...but that $$$ hurts.
Tell me about it..
My dad asked me the other day "How much do you figure you have into that car" after he saw the superspeeders rob video regarding his buddy pouring 30k into his BRZ in stupid mods.
Not including the cost of the car, im probably 20k deep into my car ATM.. It's honestly sickening to think about.
Shady195 is offline   Reply With Quote
Old 04-02-2017, 12:49 PM   #1291
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Originally Posted by Shady195 View Post
Tell me about it..
Lol. Between 2 240s, a WRX, and the FRS, I was well over 50k in mods. Looked at my bank account and there was nowhere close to 50k in there. That was kind of a big thing to me, because you don't exactly make money and get a lot of money back when you modify cars.
Hence why I bought the STI. Almost 2 years in and between parts and services and stuff, I'm only in like $2,000. Add wheels/tires and exhaust in this summer, and the total cost will be like $5,500 and the car is basically done at that point. Modifying cars is fun but F*CK it's such a poor investment
TylerLieberman is offline   Reply With Quote
Old 04-02-2017, 01:53 PM   #1292
Shinchu
Shinchu's Avatar
Drives: 2016 FR-S Asphault MT
Word. Im running 215 45 on 17x9.5 +20 square and running stock arms it just nuzzled up in the fender, no rolling or anything. Perfect.
Fronts need camber but eh, no big deal.
I will need alignment so i will try as close to zero toe in rear with stock arms.
I do have pbm rear lowers but adjusted to stock length.
When i get it aligned i will post specs. I doubt i can get rear camber to anything less than 2 degrees though. Not without fender work.
TEAM HINGA | Shift-Lock.net | Club4AG
http://www.poweredbymax.net/
Shinchu is offline   Reply With Quote
Old 04-03-2017, 01:40 PM   #1293
MattTheGinge
MattTheGinge's Avatar
Drives: Series.Blue BRZ
Update since the megan inner tie rod install:
went to a drift event on Saturday and I have to say i could feel the difference from the stock ties, it gave me just enough more angle to power through corners on stock power, i only had a couple spins but all were due to hitting rev limit, gripping up and snapping back, none were from lack of angle. the only negative i found was when i clutch kicked at full lock i could feel the front rack kind of torquing forward, not sure if this was a result of the tie rods, lack of front sway, coils, or all of these put together. my general consensus is for $80, you really have no reason not to get these. some people may feel different about this, but for me it felt great, and i would easily do it again.
after driving with it i dont think il need any more angle on stock power, only real benefit i could see from an angle kit at this point is on borderline backwards entries, and small hairpins where i can keep them spinning, anything outside of that would just be correcting if i overcooked it. though those with pbm kit or drift knuckles might disagree,as ive only been sliding this car a couple months.
MattTheGinge is offline   Reply With Quote
Old 04-03-2017, 07:57 PM   #1294
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
Hey hey, for people with Push to Start and wanting to run a PBM Hydro Ebrake, check out the DIY I just made:
http://www.ft86club.com/forums/showthread.php?t=117177
tato.valverde is offline   Reply With Quote
Old 04-03-2017, 08:04 PM   #1295
Shinchu
Shinchu's Avatar
Angle AND hydro for a daily? Only way this can get better is chocolate covered bacon. Or... drift events in san diego would be great too.
Old 04-04-2017, 10:32 AM   #1296
Rougenite
Drives: Raven FR-S
Tell me about it..
I have nothing against the guy but it just seemed like he built the car with no clear purpose. A bunch of cash thrown at something ya know?
I was 40k into the tC, second built motor popped, thats when I got sick of it haha.
Rougenite is offline   Reply With Quote
Old 04-04-2017, 02:40 PM   #1297
allmotorrex
allmotorrex's Avatar
Drives: 08 4x4 offroad tacoma/ raven fr-s
I'm running a Continental DW 255/40 on a 17×9 +20 in the rear with -.8 camber and had to roll the fenders to stop rubbing but that's it. Before I had Federal 595s 235/40 on 17x9 +20 and didn't rub at all. This is with being lowered right at an inch.
Sent from my SM-G930V using Tapatalk
allmotorrex is offline   Reply With Quote
Old 04-04-2017, 05:13 PM   #1298
TylerLieberman
Drives: '24 GR86
Lots of people seem to mod cars like that. No real idea on what direction to go, just modding for the sake of modding.
Gotta have that forum build list as long as possible for max interweb points.
Old 04-06-2017, 01:49 PM   #1299
MattTheGinge
Im debating between the federal 595 RS-R and 595 RS-RR for the front, is the RR worth the extra ~$50 a tire, and would it be more beneficial to go with 225 in the front on stock wheels or stick with the 215? ive heard federals run a tad on the larger size, i don't really want a muffin top of a wheel if i go with the 225
Old 04-06-2017, 07:00 PM   #1300
TylerLieberman
Drives: '24 GR86
Stick with 215. They run large and you're already tight on front clearance with these cars (especially with added angle).
Regarding the difference between the R and RRs... Idk. Just get whichever. I doubt it'll make that much of a difference. I'd honestly just get the Rs myself.
Old 04-13-2017, 08:20 AM   #1301
Shady195
Yeah no kidding..
I run a 18x9.5 +35 up front. I just got my Drift knuckles setup installed and have to run a 30MM spacer for now to get the clearance I need.. even then the tires slightly rub the fender liners when turning front and back.. Looks like ill be ripping those bad boys out
When I have the cash I guess I'll need to move to a more reasonable sized wheel setup. I just hate to switch my wheels. I'm not a scene points whore but I 2 years later am still in love with how bad ass my 3DSM's look especially when drifting.
Old 04-13-2017, 01:09 PM   #1302
TylerLieberman
Drives: '24 GR86
Yeah no kidding..
Yeah...
Honestly, 17s are just plain better for these cars, especially for drifting applications
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
