Old 06-17-2016, 09:53 AM   #12937
How would the bolts secure the flange?
Not securing the flange but the body of the bushing by passing through the tube. If your tube wall is thick enough you could tap it. If not you would have to attach a bolt to give you the threaded hole.
The flange just helps support the bushing at the end of the tube.
Your tube would look like this with the bolt pushing against the bushing inside it. I would use two bolts per bushing just to make it that much more secure but you could probably get away with one.
Tcoat is offline
Old 06-17-2016, 10:13 AM   #12938
Ashikabi
Ashikabi's Avatar
That's what I was imagining but I thought it may put too much pressure on it and clamp against the guide rod.
Ashikabi is offline
Old 06-17-2016, 10:21 AM   #12939
Grind a beveled end into the bolt (not a sharp point just a taper). This will hold the bushing without misshaping it or penetrating to the shaft. There shouldn't be enough friction on the guide to pull the bushing out anyway and if there is then there is a flaw in the design that is applying lateral force.
Another option if you have the equipment is to simply run a slot up one side of the tube and use U bolts to clamp the tube onto the bushings. This is probably what I would do.
Tcoat is offline
Old 06-17-2016, 10:30 AM   #12940
Ashikabi
Ashikabi's Avatar
Slitting the carrier is an option. The guide rod won't be perfectly smooth so there will likely be wear and friction on the bearing. The split bearings... is their nominal size measured when pinched closed?
Ashikabi is offline
Old 06-17-2016, 10:33 AM   #12941
Get your rod as smooth as possible or you will just be asking for trouble. The nominal size is indeed in the closed position.
Tcoat is offline
Old 06-17-2016, 10:36 AM   #12942
Ashikabi
Ashikabi's Avatar
That's a big reason I want bearings. I don't have a good way to make it smooth. Maybe try to clamp in a lathe and run fine grit sand paper on it?
Ashikabi is offline
Old 06-17-2016, 10:39 AM   #12943
Oh dude be careful with that!
You have no dimensions on the drawing. How long and what diameter is the shaft? What material were you planning on using?
Tcoat is offline
Old 06-17-2016, 10:43 AM   #12944
Ashikabi
Ashikabi's Avatar
Probably 8ft long somewhere around 2 inch od steel. Unsure on thickness. Depends on what we have on hand. Probably .12 or .188
Ashikabi is offline
Old 06-17-2016, 11:01 AM   #12945
Oh that big a diameter may cause you some issues with the side mounted carrier. There may be to much side pressure put on it that will cause it to bind up with that much surface. Does the carrier need to be able to travel the full length? If not you could use your 2" tube as a base and run a smaller diameter smooth steel shaft for the travel section of the carriage. This will allow you to decrease the surface area and friction.
Tcoat is offline
Old 06-17-2016, 11:06 AM   #12946
Ashikabi
Ashikabi's Avatar
The guide could be smaller but I was trying to keep it simple
Ashikabi is offline
Old 06-17-2016, 11:10 AM   #12947
Oh I am all for keeping simple but sometimes we can try to be too simple and things just don't work.
If you really want to keep it simple:
Tcoat is offline
Old 06-17-2016, 11:12 AM   #12948
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Who dares me to go play in the FI subforum?
Nevermore is offline
Old 06-17-2016, 11:13 AM   #12949
And do what? I hang out there all the time but just keep my mouth shut.
Tcoat is offline
Old 06-17-2016, 11:17 AM   #12950
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I triple dog dare you to try and pretend like this thing works.
https://www.amazon.com/gp/aw/d/B0096...h7L&ref=plSrch
Andrew025 is offline
