#1275 | |
Drives: 2017 BRZ Premium
Sent from my SM-N960U using Tapatalk |
#1276 |
Are the pins in your connector secure? Unplugging and replugging may have been what solved the issue... just a thought.
#1277 | |
Drives: 2017 BRZ
That was one of my initial thought. The harness to the MAF is a bit tight, and the engine torquing on its mounts pulls on the airbox which is mounted to the chassis (another reason I want to move to CAI), so the engine could have been pulling on the connector enough to slightly unseat it or something. I fed it as much slack as I could when I re-installed the MAF. It ran fine for about 15 miles today, but I had to park it to travel for work and won't be able to mess with it again for a few more days. |
#1278 |
Sold the perrin but you may be on to something with the connector...
#1279 | |
Drives: 2016 Cosworth 2.2 BRZ
#1280 |
#1281 |
Drives: GT86
Hi Gents,
Sorry to interrupt the flow. I've posted a dyno chart in dedicated thread with graphs before, and after the installation. It showed around 285HP/ 335Nm (247lb-ft) at the engine. Stock exhaust and engine, on 102 RON fuel. What do You think, optimistic, dyno cheat, or as expected? Now only one thing is on my mind - forged con-rods and bearings, or not
#1282 |
#1283 |
Both but mostly idle. I don't want to jinx it as I haven't taken a new ECU log yet, but I let it idle for about 5 minutes and did not get a CEL. I took the throttle body, intake tube and all vacuum lines off. Notice that the throttle body was fairly black underneath. Indication of oil blowby. Only had the charger on 10,000 miles or so. Surprised there was that much. Definitely need a catch can.
I cleaned the throttle body and put hose clamps on every vacuum line at both ends. Noticed my evap hose had not been fully seated. So far no CEL. I have a dedicated thread regarding my lean conditions. Will update it later once I make a determination. |
#1284 |
Drives: GT86
#1285 | |
Drives: 2017 BRZ
#1286 | |
| The Following User Says Thank You to gahooligan For This Useful Post: | sly (11-20-2018) |
#1287 | |
Question is where to mount it. The fitted kits put the can at the back of the engine where my throttle body now is. I can't really put it near the battery because that's where the new coolant reservoir and pump are for the intercooler. Last edited by sly; 11-20-2018 at 01:49 AM. |
#1288 |
Just make new lines. Legnth doesnt matter so much... I mounted mine off the passenger strut tower.
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6036 | 11-12-2025 11:42 PM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 02:12 PM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 02:18 PM |
| Phantom FTS Electric Supercharger Owners Thread | TM | Forced Induction | 1206 | 12-15-2019 03:33 PM |
| Supercharger Kits! Vortech/Cosworth | RallySport Direct | Forced Induction | 61 | 06-29-2015 12:26 PM |
