Old 09-24-2015, 07:12 PM   #12741
bryanjuz94
Drives: 2014 Subaru BRZ
Sent from my SAMSUNG-SM-N900A using Tapatalk
bryanjuz94 is offline   Reply With Quote
Old 09-24-2015, 07:12 PM   #12742
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
Originally Posted by LWAA View Post
Improvement in what way?
What do you mean by 12V plug?
The intake sound is being channeled into the cabin. There is an opening in the passenger footwell. I plugged it with the plastic cap that was a left over when I installed my dashcam. I used the power outlet behind the glovebox and used the cap to plug the hole, a perfect fit and easily reversible.
Guru Woodman is offline   Reply With Quote
Old 09-24-2015, 07:14 PM   #12743
LWAA
Drives: Subaru BRZ
Apologies for my ignorance :-)
So less sound goes into the cabin? Does that mean more sound outside?
Sent from my iPhone
LWAA is offline   Reply With Quote
Old 09-24-2015, 07:19 PM   #12744
Guru Woodman
No problem,
Just less sound in the cabin. There is a thread about the sound generator here. I accomplished the same by just plugging it.
I drove it a while without the plug, than tried it a couple of days with the plug installed and then took the plug out it again. I definitely prefer it with the plug in the hole (and less sound in the cabin when accelerating).
Old 09-24-2015, 07:28 PM   #12745
mixedjuice
Drives: 2015 BRZ - sold & 2014 Legacy Sport
Have been researching whether to purchase wheels and tires OR a supercharger kit with the Alaska Permanent Fund that will be released to all Alaskan Residents on the first of next month.
Cosmetic or Performance...
mixedjuice is offline   Reply With Quote
Old 09-24-2015, 07:28 PM   #12746
BRZHarley
Drives: 69 Firebird, 2015 BRZ
My local mechanic installed new lug it studs and mounted and balenced the new shoes!!!
BRZHarley is offline   Reply With Quote
Old 09-24-2015, 09:28 PM   #12747
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
soup per charge ER came in. And I feel rike. https://www.youtube.com/edit?o=U&video_id=q150DnVxt5o
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Old 09-24-2015, 10:12 PM   #12748
musicman78
New to Subaru!
musicman78's Avatar
Drives: BRZ Limited
New Sidemarker LEDs and lenses
So I went and installed these. Connected right up to the existing driver side marker light wires and ground, and then one wire up to the blinker. Load resistor is built in so they work like a charm and in perfect sync with the front blinker.
The smoked color looks great with the magnetic grey color of the car as well.
musicman78 is offline   Reply With Quote
Old 09-24-2015, 10:40 PM   #12749
kberkel
kberkel's Avatar
Welp.. bought a sewing machine and expected to fail.
Butttttt.. YouTube has millions of tutorials. This was my first attempt at a french seam.
This was some cheap material at Joann Fabrics. The color is off.. and I bet UV will kill it. Indoor fabric.
Here is a much nicer marine vinyl on the left. It's blacker than the interior, but looks fantastic compared to the Joann Fabric. I only had a sample.
Working on rounded multi-pieces now.. tough. You guys should try
kberkel is offline   Reply With Quote
Old 09-25-2015, 03:21 AM   #12750
DSOmegaX
DSOmegaX's Avatar
I...parked it outside
@dsomegax.cars
Old 09-25-2015, 02:49 PM   #12751
BRZHarley
Test
Test
Fail ..... ��
Old 09-25-2015, 05:30 PM   #12752
bababooey
Drives: BRZ SWP Limited -6MT
celebrated managing not to crumple it up within first year of ownership. ordered uel header & op to get most benefit from the oft tunes.
Old 09-25-2015, 06:36 PM   #12753
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
Got my new plates
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 09-25-2015, 08:44 PM   #12754
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Gettin' ready to get ready.............
BirdTRD is offline   Reply With Quote
