Old 02-25-2019, 09:41 PM   #1261
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by zeal86 View Post
I love pearl white as well but since I want to be different, save money, and make color matching in the future easier (if needed)... I'm going to go with a non-pearl white. Plus, I may take part in the painting of my build if not all of it...so if I jack some part up... It wouldn't hurt me in the pocket book as much if I end up needing more paint and or materials.
IG @zeal.eightsix
To each their own, but my preference has always been towards vibrant whites than creamy whites. The creamy whites look perpetually dirty or like there is a layer of pee on them. Vibrant whites like I see on the Teslas are more my preference, looking clean and crisp.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
zeal86 (02-25-2019)
Old 02-25-2019, 10:07 PM   #1262
zeal86
zeal86's Avatar
Drives:
I do like brighter whites too but my engine bay will not be painted and I don't want the difference to be so evident.
IG @zeal.eightsix
zeal86 is offline   Reply With Quote
Old 02-25-2019, 11:39 PM   #1263
Irace86.2.0
IG @zeal.eightsix
Yea, I read that earlier, and it totally makes sense.
Old 02-26-2019, 07:16 AM   #1264
Ashikabi
Ashikabi's Avatar
Why not paint engine bay though? You're gonna be like 90% done painting the whole car
Old 02-26-2019, 10:19 AM   #1265
zeal86
zeal86's Avatar
Drives:
ya.. negative on pulling the engine. If it ever had to come out for whatever reason perhaps I'd repaint the whole car again.
IG @zeal.eightsix
Old 02-26-2019, 10:24 AM   #1266
zeal86
zeal86's Avatar
Drives:
@Ashikabi Hopefully in the near future I will have learned how to paint well... that way a repaint wouldn't cost so much.
IG @zeal.eightsix
Old 02-28-2019, 03:48 PM   #1267
zeal86
zeal86's Avatar
Drives:
First mock-up... still plenty of design tweaks to come... I had to start somewhere. Final part will be fiberglass and will be fastened to fenders and side skirt extensions. The shape will flow with the fender better than the pictured mock-up. Should look dope when complete.
Using matte board for the mock-up process... it's rigid yet flexible...
IG @zeal.eightsix
The Following User Says Thank You to zeal86 For This Useful Post:
DustinS (03-04-2019)
Old 03-01-2019, 11:08 PM   #1268
zeal86
zeal86's Avatar
Drives:
2 layers of fiberglass so far... I'll add one maybe 2 more on the inside once out of my mold.
[IMG]https://i.imgur.com/Tbo99Ak.jpg
[/IMG]
[IMG]https://i.imgur.com/vGRAhqz.jpg
[/IMG]
[IMG]https://i.imgur.com/dUWxb7a.jpg
[/IMG]
[IMG]https://i.imgur.com/b7v6oOh.jpg
[/IMG]
IG @zeal.eightsix
Old 03-02-2019, 04:29 PM   #1269
zeal86
zeal86's Avatar
Drives:
I still have to add 2 to 3 more layers and make the flange to will hold it to the fender (with hardware).
Shape is still a work in progress. I don't hate this form but I'm still going to try some other things...
Out of the mold
Wraps around..
Flows downward...
IG @zeal.eightsix
DustinS (03-05-2019)
Old 03-03-2019, 02:14 PM   #1270
zeal86
zeal86's Avatar
Drives:
process pics...
Molding this piece to connect to the other piece... I'll fiberglass then together... hardware will be embedded... nuts and star washers on inside of fenders.
Cut up the bolt heads for more grip...
Two layers of fiberglass on top... will be more glass once I mate the two parts together...
IG @zeal.eightsix
Old 03-05-2019, 04:18 PM   #1271
zeal86
zeal86's Avatar
Drives:
more progress from Sunday...
Rigged up for curing...
I've added some reinforcement since this pic...now I have to trim the fat! Then continue with the fiberglass layers.
IG @zeal.eightsix
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
DustinS (03-06-2019), wolffbite (03-06-2019)
Old 03-09-2019, 03:42 PM   #1272
zeal86
zeal86's Avatar
Drives:
Redo... the clamp I used to hold the two parts while bonding pulled the panel in too much...it was bowed beyond and easy fix. So I cut it and added back some fiberglass.
Once dry... I'll add more layers to the inside of the panel. Then I'll create a short lip around the edges for rigidity. I hope to have this filled, sanded, shaped, and primed soon.
IG @zeal.eightsix
DustinS (03-11-2019), Raven86Project (03-11-2019)
Old 03-25-2019, 09:34 AM   #1273
zeal86
zeal86's Avatar
Drives:
Still some work to do but I'm happy to be at this point. I'll be cleaning up some things before starting on an addition to this design... if it works for me I'll post it soon.
The panel is in place but not tightend down in all pics except for the last. This panel will connect to the 1/4" thick ABS plastic sideskirt extension.
Overall design is still fluid.
IG @zeal.eightsix
wolffbite (03-26-2019)
Old 03-25-2019, 09:46 AM   #1274
Ashikabi
Ashikabi's Avatar
Is that top edge getting blended?
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 08:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 07:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 07:34 PM
