#1261 | |
Drives: 2013 SWP BRZ
Thanks Andy, I'll give you a guys a shout soon to discuss.
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
| The Following User Says Thank You to smbstyle For This Useful Post: | Racecomp Engineering (04-18-2014) |
#1262 |
Drives: Scion FR-S Whiteout
I have 17x9 +45 RPF1, LCA and camber bolts. 225/45 tires. I had the suspension parts installed by West End and the Chris said that after the adjustment, my front tires are running very close to hitting/rubbing the OEM springs/shocks, so he was only able to set -1.25 front and -1.50 rear.
My question: would getting coils (say KW V3 or Tein SRC) require me to add a spacer (10mm)? Or will the coils themselves be enough?
2013 Scion FR-S
#1263 |
Off Topic
Getting coils should make it easier to fit wide tires, as the coils are usually a lot smaller circumference than the OEM springs.
| The Following User Says Thank You to gramicci101 For This Useful Post: | retrosmiths (04-18-2014) |
#1264 | |
Drives: gt86...among others
this board is awesome
racing gods live deep in corners
#1265 | |
Drives: 1993 Impreza w/ WRX Swap + FWD!
![]() Thats maxed out negative front camber, and rear camber obviously was not adjustable. |
#1266 |
Drives: FR-S Whiteout
The B8 seems to have a shorter total length and more damping to accommodate for shorter firmer springs, but I'm not so sure if they will lower the car any more than stock or B6. If the distance between the perch and lower mounting holes are the same, they should not lower any more even if the upper mount to perch distance is shorter. I think the vendors that have these in stock can answer this better for you.
#1267 | |
#1268 |
Yes. The whiteline bolts give a little more neg camber. The crash bolts as well but im no fan of putting too small of bolts in too big of hole. But I'm ok with these specs for my daily driver.
#1269 |
#1270 |
| The Following User Says Thank You to Kostamojen For This Useful Post: | solidONE (04-19-2014) |
#1271 |
Question for RCE:
Have you tried the Yellow springs up front with the Tarmac springs in the rear? I'm finding so far I preferred the BRZ front springs/FRS rear spring combo over the Yellows so far in terms of handling dynamics. I'm not sure what a rear sway bar will do yet, but I do want to go for the rear subframe bushings to help stabilize the rear a bit more. |
#1272 | |
Ideally you'd have a little more front camber and then I think you'd be pretty happy! Right now your alignment is very understeer oriented. - Andy |
#1273 | |
Its hard to describe it but right now the back end just feels soft and the weight transfer is slow. It could be a result of the heavy ass wheels but idk. |
#1274 |
-1.5 front camber would be about perfect for you.
Swaybars would help, or better dampers. Dampers make a pretty nice difference if you're running heavy wheels actually. - Andy |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
