Old 12-19-2015, 03:26 PM   #1261
Irace86
Drives: BRZ + Ducati M796
Originally Posted by Raceseng View Post
I'm also working on stand alone shift knobs that are stainless steel and wrapped with leather or alcantara.
Ok, it has been a month. Hit me with it! Now, I know there is this little thing called Christmas and other distractions like the Star Wars release, but you are killing me man I'm just dying to see a bad ass embossed leather knob or a leather cover
Irace86 is offline   Reply With Quote
Old 12-20-2015, 06:40 PM   #1262
2jayzee
Drives: 2015 Scion FRS
Thanks. I absolutely love it and the way it angles the gauges towards the driver its still easy to see while driving.
2jayzee is offline   Reply With Quote
Old 12-20-2015, 07:48 PM   #1263
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
TruRace is offline   Reply With Quote
Old 12-22-2015, 11:40 AM   #1264
Irace86
Also, I am surprised you don't have a matching e-brake/handbrake button. I would be very interested in a piece that goes with the shift knob and reverse lockout.
Old 12-22-2015, 12:01 PM   #1265
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
MTEC drift knob, #poser
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
Old 12-22-2015, 12:35 PM   #1266
xFury
xFury's Avatar
Drives: '16 Scion FR-S - Oceanic
What are the benefits of the heavy knobs? And I see some that says that help with cars withs short shift, how does that work also? Lol sorry, I'm still new to all this stuff.
xFury is offline   Reply With Quote
Old 12-22-2015, 01:49 PM   #1267
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
It's adding weight to one end of a stick, it's easier to gain momentum to shift it into gear.
Take a stick about 3 feet, and spin it with 1 hand, now add 1-2lbs to one end, and do the same thing, you'll see how easier it is to spin or twirl.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 12-22-2015, 03:29 PM   #1268
Irace86
I think you have the right idea, but you are saying it wrong, so let me geek out on the topic:
By adding weight to the knob it is harder to initiate a shift because the knob has a greater amount of inertia. Inertia is a description of an observation that things with mass tend to resist change, such that things at rest stay at rest and things in motion stay in motion, that is, until a force is exerted against the object. The greater the mass the greater the inertia, and thus, the greater a force has to be to alter the movement or lack of movement of that object. With that said, more mass to a knob means more static inertia.
Force equals mass times acceleration, so increasing the mass would increase the force required to initial a shift. Because a shifter is a lever, it is more correct to say that the torque (not force) would have to be greater with a larger mass because torque equals the force (or mass times acceleration) times the lever arm.
Once an object is in motion it has momentum, and because momentum equals mass times velocity, the more mass the knob has the more momentum it has. Also, the addition of velocity adds more inertia because it increases the force needed to change the objects position, so the object would have more kinetic inertia.
So why does any of this matter?
While speed of shifting is important for racing to spirited driving, a missed shift is not only bad for the car, but it hurts performance. And while there are several reasons why someone may miss their shifts, a shift that is not smooth is one of them. Adding mass to the knob can make the shift smoother because the knob in motion will have greater momentum and kinetic inertia, so the knob with be less influenced by external forces such as engine vibration or friction in the lever channel. Those external forces are more likely to cause error and an unpleasant feeling like waterskiing on choppy waters or rollerblading over a patch of asphalt vs smooth concrete.
A knob with more mass also has more static inertia, so the knob will likely vibrate less in the hand during times when someone is not shifting. I say likely because there is a possibility that the harmonics of the vibration of the car would match the mass of the knob and lead to greater vibration, but this is unlikely.
And just to use the above example, the idea SmartedPanda brings up is the idea that if you swing a tennis ball at the end of the rope on a windy day around in circles, you may see the wind contort the path of the ball, but if you used a heavier ball like a 3lb kettle ball, you will likely see far less to no effect that the wind has in altering the path of the ball. Again, because more mass means more motion which means more force is needed to change that path.
Old 12-22-2015, 04:17 PM   #1269
JRRIII
JRRIII's Avatar
Drives: Series 10 #1988
Red face
my WC Lathe Werks titanium ball
PERRIN / WC Lathe Werks / Apexi / JPM Coachworks / RMagic / Cusco / Blitz / TRD
JRRIII is offline   Reply With Quote
Old 12-24-2015, 02:44 AM   #1270
xtral
xtral's Avatar
Drives: Ford Focus 09'
Originally Posted by RallySport Direct View Post
Beatrush Duracon Shift Knob
Thanks,
Rick
what is the reverse lockout you have there ?
xtral is offline   Reply With Quote
Old 12-24-2015, 02:25 PM   #1271
Doobster
Doobster's Avatar
Drives: FRS
finally able to get this knob on
Sent from my SM-G920T using Tapatalk
Doobster is offline   Reply With Quote
Old 12-24-2015, 04:18 PM   #1272
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
Originally Posted by swarb View Post
@0351USMC What is the height of the shift knob? Looks pretty tall. Where is the top of the shift knob in relation to the clock? taller or lower?
In 1st,3rd and 5th gears its equal with the surround right below the radio. I have the kartboy shifter installed too so i'm not sure if that affects the height compared to the stock shifter.
0351USMC is offline   Reply With Quote
Old 12-24-2015, 04:33 PM   #1273
freshjuicebox
drive your dreams...
Drives: 2016 CWP BRZ
gf got me an early christmas preset. wc lathe werks ti sphere. sorry for the phone quality pictures.
www.freshjuicebox.com
|2016 CWP BRZ Premium|
freshjuicebox is offline   Reply With Quote
Old 12-27-2015, 01:26 AM   #1274
tracerit
Drives: '13 SSM BRZ Limited 6MT
hate to be the guy to ask for an ETA but I'm close to picking up an STi knob but wondering if I should hold out a bit longer or just go with it for now.
tracerit is offline   Reply With Quote
knobs
Shift Knob Jwong FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 29 12-12-2014 01:33 AM
Kartboy Shift knob Spartan65 Interior Parts (Incl. Lighting) 8 10-03-2012 06:18 PM
any other shift knob? oso_25 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-31-2012 01:38 AM
TRd Shift Knob GaN-MaN Cosmetic Modification (Interior/Exterior/Lighting) 1 07-24-2012 01:57 PM
