Northern California NorCal
finch1750, go_a_way1, undefindedt
Old 08-13-2018, 08:51 PM   #12615
Sapphireho
helmholtz resonator
Sapphireho's Avatar
Drives: '15 ultramarine
Splashing about with alcohol once back on the road will remove it along with the old gas.
Maybe that's why the sta-bil always works for me. I always have a couple cocktails before I fire up the boat.
Old 08-14-2018, 01:12 AM   #12616
Kaotic Lazagna
Drives: GR Corolla
Stop worrying? Fill up before you hard park it.
Don't over fill. Click, click, click up to the fuel neck and you'll flood the evap can.
That's bad.
edit: Fuel degradation results primarily from random atmospheric ions of one sort or another.
If the tank is full in a closed system (inoperative) for a year or two, you should be fine.
Water in the bottom of a plastic gas tank won't amount to a hill of beans.
I only do one click after the first click to verify it wasn't a false click. lol.
So you're saying to not worry about it then. Gotcha.
Old 08-14-2018, 12:45 PM   #12617
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by Kaotic Lazagna View Post
Okay, so back to worrying about condensation building up and using FS of some sort?
I guess if you're not having any issues driving your car with gas from Feb, I wouldn't worry about it. I've just been following what ever my dad told me, which is probably old information anyway lol
Originally Posted by undefindedt View Post
Well. That's why I never push my limits of my driving ability or vehicle on sections of road like that. There are too many possible variables that could make the event different from the previous time. You never know what you are going to get...
It's all in maturity level. Easier to say to "drive within your ability" now that you are older and wiser vs when you've got hormones raging in your body and friends you are trying to impress.
The Following User Says Thank You to BigFatFlip For This Useful Post:
Kaotic Lazagna (08-14-2018)
Old 08-14-2018, 12:46 PM   #12618
BigFatFlip
BigFatFlip's Avatar
So I know its just a lame advertising "holiday" but who's down to look ridiculous on Fri?
https://grassrootsmotorsports.com/ne...xHelmetsBlast1
Ultramaroon (08-15-2018)
Old 08-14-2018, 01:10 PM   #12619
Yeeeeaahhh ... the evap system prevents gasoline vapors or other gases from escaping the loop.
However, it does draw in ambient atmosphere when fuel is drawn from the tank.
H20 comes in with it however much that it doesn't go back out even harder.
There's no dry nitrogen or argon doing anything here.
That'd be more like having to add blue pee to your diesel systems to keep it running.
Observe that there is no venting in the spiffy diagram.
That would implode the gas tank by the time you used a 1/4 of the fuel.
Aircraft mfg. would be all over it if they could make it work reliably.
Still have to cup the lowest point of the fuel system to check for water before flight.
There is also no return line shown in that diagram which would provide the make up air to the tank. No implosion. The point was that yes humid air is drawn in through a solenoid valve while the car is operating but the system is closed when shut off. There is not a constant exchange of air going on that allows more moisture to enter and fuel to evaporate.
The risk of moisture in the aircraft fuel is more related to the sudden and extreme changes in temperature from climbing and the risk of even the smallest amount freezing in the lines at altitude.
That's bad.
Not sure just how much water people seem to think will condense in a 10 gallon tank even if left wide open for decades. I have heard this so many times on the internet but never even ran into a single tank in any of my old car restorations that had condensation issues. Metal tanks that sat empty for 20 years were bone dry and still perfect inside. The outside may be rotted to hell but the insides were like new.
Old 08-14-2018, 01:39 PM   #12620
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Yeah. Only pointing out a (very) tiny imprecision. 8)
A dry tank won't sweat because the temperature will equalize very quickly.
A half full vented tank will act as a cold sink and come up to temp only slowly on a hot day.
In the twins, the amount of water vapor will be minuscule and not really something to spend time or neurons over.
Until someone takes a whiz in the filler. But who would do that (sharp shufty).
Fuel is less likely to break down over a long period if the surface area is only a couple square inches in the neck as opposed to several square feet in a less than full tank.
The Following 2 Users Say Thank You to bcj For This Useful Post:
Kaotic Lazagna (08-14-2018), Tcoat (08-14-2018)
Old 08-14-2018, 02:26 PM   #12621
Yep we are on the same page.
Old 08-14-2018, 02:41 PM   #12622
spike021
spike021's Avatar
https://bringatrailer.com/listing/19...-r5-turbo-2-5/
Instagram: @spike.brz
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
BigFatFlip (08-14-2018)
Old 08-14-2018, 02:48 PM   #12623
BigFatFlip
BigFatFlip's Avatar
Ya, saw that...went for $125k
spike021 (08-14-2018)
Old 08-14-2018, 03:19 PM   #12624
spike021
spike021's Avatar
Insane! Man, I love those wheels too.
Car looks pristine.
Old 08-14-2018, 03:29 PM   #12625
spike021
spike021's Avatar
Also: https://www.facebook.com/carwavetv/v...xNzgwNzExNDEx/
Not sure if it's on Youtube, just happened to see it on Facebook.
Old 08-14-2018, 04:50 PM   #12626
Kaotic Lazagna
Drives: GR Corolla
I know at least one of you guys want an FD.
https://sfbay.craigslist.org/sby/cto...667804807.html
The Following 4 Users Say Thank You to Kaotic Lazagna For This Useful Post:
BigFatFlip (08-14-2018), Clipdat (08-15-2018), spike021 (08-14-2018), Ultramaroon (08-15-2018)
Old 08-14-2018, 04:54 PM   #12627
BigFatFlip
BigFatFlip's Avatar
That music ain't half bad either!
Do I want one? Yes
Would I own one? Nope lol
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
Kaotic Lazagna (08-14-2018), spike021 (08-14-2018)
Old 08-14-2018, 05:01 PM   #12628
Kaotic Lazagna
Drives: GR Corolla
*Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread peazs CANADA 1397 06-28-2019 12:17 PM
NorCal (Bay Area) AutoX Thread! BlaineWasHere Northern California 1399 02-08-2019 01:27 PM
Mid-Atlantic Chat Thread clevrname Mid-Atlantic 5296 08-25-2016 01:30 PM
FS: Five Axis Five:AD Aero Kit w/ Rear spoiler Whiteout - NorCal Bay Area firebert Exterior Parts (Aero, Lighting, Etc.) 13 01-08-2013 11:07 PM
NorCal Bay Area ecutek tuning AsphaltLover Southern California 0 11-11-2012 12:38 AM
