Old 04-18-2014, 12:56 AM   #1247
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Originally Posted by jdmblood View Post
hell yea lmao. Got the Tokyo drift avatar and thanks for the advid. The bilstein b6s I believe are the lowering ones.
B6 is stock replacement, B8 is the shorter bodied shock designed for use with lowering springs.
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
The Following User Says Thank You to Zach3794 For This Useful Post:
jdmblood (04-18-2014)
Old 04-18-2014, 01:22 AM   #1248
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Wink
hell yea lmao. Got the Tokyo drift avatar and thanks for the advid. The bilstein b8s I believe are the lowering ones.
fixed that for ya
The Following User Says Thank You to cdrazic93 For This Useful Post:
Old 04-18-2014, 08:30 AM   #1249
Doozer
Doozer's Avatar
Drives: gt86...among others
Hi Guys,
Been trolling for a while and slowing learning a lot.
I have a track day coming up and I'm looking for some more exit speed.
Car has:
Ohlins SIS MI20's
Rear chassis bushings
3* front camber
3mm toe-out front
3mm toe-in rear
Kumho v710 (245/40/17)
Eneki 17x8 wheels
track has high speed (180+km/h) and low speed (60-km/h) corners. suspension has gradually worked their way down to the stiffest settings.
We're experiencing 4 wheel flat slides on entry and we have to delay getting on the gas in the center because it will just break the rear free. We're getting killed on the straights because of this...
Could sway bars possibly solve this issue? If so what size is recommended? Car is still 180whp
Any help is really appreciated. Thanks folks
racing gods live deep in corners
Doozer is offline   Reply With Quote
Old 04-18-2014, 09:53 AM   #1250
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Thanks again for doing this guys!
Im looking at wheel spacers in the future - I would like to increase the track width front and rear and to bring the wheels a little more "flush" with the body. Im curious how this will affect the scrub radius and braking stability. Currently, Im looking at 20mm spacers up front and 30mm rear.
Ive read that mcpherson suspensions do well with a lot of negative scrub and Im afraid 20mm will be too much. Can you guys offer any comments or suggestions for a guy that tracks roughly two times a year and autocrosses non-competitively?
supramkivtt2jz is offline   Reply With Quote
Old 04-18-2014, 10:21 AM   #1251
Doozer
Doozer's Avatar
We've run 20mm front and 30mm rear, wheels have another 45mm offset. Car was 0.1s faster without the rear spacers but felt like ice with the fronts still in.
Didn't notice a difference in braking, but I think we lost aero with the rear wheels stickin out so far.
Tire temp variance remained constant with and without spacers but temps increased in the rear with them removed.
Without rear camber, our inside edge of rear tires are consistently 10*F hotter then the outside edge, regardless of spacers
...just one guys thoughts...
pic 1 is RF w/20mm
pic 2 is rear stance with 45mm offset wheels and 30mm spacers
The Following User Says Thank You to Doozer For This Useful Post:
supramkivtt2jz (04-18-2014)
Old 04-18-2014, 10:27 AM   #1252
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
pic 1 is RF w/20mm
thanks for the input! did the car feel stable with the front and rears? what were your times with and without spacers? can you elaborate a little more on the "ice" feeling?
Thanks!
Old 04-18-2014, 11:08 AM   #1253
Doozer
Doozer's Avatar
Thanks!
With spacers- High speed corners felt very stable
With spacers- In the low speed tight turns (like autoX) it developed a push in the front end as it was more difficult to swing the rear out on entry. To fix this "push" issue, less brake was used and a bit of a Scandinavian flick was applied to set the car up early for the corner. Using tire scrub to slow the car down just to get a better entry line.
I can't offer too much on time variance with and without spacers because at first i was on toyo 888's without them. We switched to Kumho's and spacers at the same time, and 2.3s were gained on a 3.5km track.
The "ice" feeling was experienced without the rear spacers (but front spacers still in) on high speed corners. The rear felt like it could let go at any moment. Much more steering input was required and brow sweat was increased. Low speed corners less tire scrub and sliding were required.
Again, there was a 0.1s gain with 20mm front and no rear spacers on our fastest time.
I'd wait for others to input before you make a decision, but trail and error always works too!
Good luck
Old 04-18-2014, 11:33 AM   #1254
Racecomp Engineering
Originally Posted by mrretep View Post
I plan on running 265/35/18 Hankook V12 for DD duty and 245/40/17 Hankook RS3 for track/autox.
I would use the standard 400/400 lbs/in spring rates of the T2s. That's 7 kg/mm and a good fit for street tires. You could go a little bit firmer, but I don't think that you need to unless you were using an r-comp.
- Andy
Old 04-18-2014, 11:33 AM   #1255
Hi Guys,
Car has:
Ohlins SIS MI20's
3* front camber
3mm toe-out front
3mm toe-in rear
Eneki 17x8 wheels
How much rear camber and what spring rates are you running?
Also, how's your ride height?
- Andy
Old 04-18-2014, 11:45 AM   #1256
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
- Andy
Andy do you guys sell the 570lb Eibach springs for the T2? The 400lb were great with the PSS but with r-comps now I feel as if I could use a bit stiffer spring.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 04-18-2014, 11:50 AM   #1257
Doozer
Doozer's Avatar
- Andy
Rear camber is OEM stock. Which leads me to believe that the inside rear tires are getting dragged across the track which is causing the 10*F higher temps (compared to the outer edge).
Ride height is approx 58cm front and 59cm rear.
Not sure on the spring rates, but they're 6Klbs springs. Springs are 20cm height, 9cm diameter and 1.25cm coil diameter
(Ohlins P/N 47010-15/60C 083)
Old 04-18-2014, 12:41 PM   #1258
wparsons
wparsons's Avatar
IIRC you can order the TII's with 400/400 (stock), 500/500 or 600/600.
flickr
Old 04-18-2014, 01:06 PM   #1259
We can get any rate you want.
We use Swift, Hyperco, Eibach, and KW springs.
Yes with r-comps you might want something a little firmer.
PM or call...Myles has been all over the place with KPAX recently but things should settle down soon. I'm trying to keep up with PMs in the meantime.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
smbstyle (04-18-2014)
Old 04-18-2014, 01:16 PM   #1260
Okay. Yes a front sway will help, but if you're running full stiff all around I would start by softening the rear (actually front too). If you have poor grip on entry AND can't put power down on exit then it's likely you're too stiff on dampers. Turning it down may seem counter-intuitive at the track but you'll have more grip.
I see people crank up the damper adjustment all the time to make up for springs that are too soft (which yours are in this case with those tires) and the results are not ideal....and often worse than just running the dampers set properly to match the spring rates.
Either increase spring rates to better control roll with your V710s and adjust dampers to match OR turn down your shocks now to match your springs and live with the springs being too soft.
Alternatively, front and rear swaybars could help add a little roll stiffness to make you happy but I'd still turn down the dampers a bit.
For what it's worth I don't remember the last time I've run a shock at full stiff.
- Andy
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
