#113 | ||
#114 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
#115 |
Drives: GTS 86 auto
steve99 said "Just adjust the radiator fan temps to cut in earlier takes 10 minutes"
Not sure if that will drop the engine compartment air temp unless the ambient air is very cold as the air introduced will be warm off the radiator and air-con coil. If it IS cooler then it sounds good. Can someone measure with and without fans operating and post.
GTS86 Auto (Australia)
#116 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
I doubt the fans will help. It will be pulling 200F air in and that happens to blow right on the air box. I also cant adjust my fan teml I have a hard enough time getting the car to warm up and stay that way now that I installed an oil cooler.
| Engine Dress-Up, Heat Shielding & Motor Oil products @ OAKOS.com | OAKOS Automotive | Engine, Exhaust, Bolt-Ons | 192 | 02-13-2015 01:38 PM |
| '14 FR-S OEM Air Intake System w/ K&N Filter and Zeta Performance Intake Tube | SoCalArgento | Engine, Exhaust, Bolt-Ons | 4 | 02-06-2015 10:40 PM |
| Intake tube and heat soak | mike the snake | Forced Induction | 17 | 02-05-2015 01:46 PM |
| DIY Gold Foil heat wrap intake box | autoCAR | DIY (Do-It-Yourself) Guides | 35 | 02-20-2014 02:22 PM |
| .: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. | Speed Element | Engine, Exhaust, Bolt-Ons | 14 | 05-20-2013 06:06 PM |
