View Poll Results: What Exhaust set-up should the FT come with?
Single Exhaust - 1 exit 86 36.60%
Single Exhaust - 2 exits (2 mufflers) 71 30.21%
Single Exhaust - Centre 15 6.38%
Dual Exhaust 63 26.81%
Voters: 235. You may not vote on this poll
Old 01-30-2012, 08:20 PM   #113
catharsis
Drives: honda civic si 08
Originally Posted by LSxJunkie View Post
I like what the 350Z guys do with their single exhaust and bumper tuck. It makes sense, seeing as 90% of them are still running an exhaust with a Y-Pipe after the cats. Unfortunately, they mostly have awful burnt titanium tips.
I <3 burnt tip. But I'm not digging the coffee can I want something that's a little slimmer like this
catharsis is offline   Reply With Quote
Old 02-01-2012, 06:22 PM   #114
vivix
vivix's Avatar
Drives: 2007 Focus ZX3, 1972 Buick Skylark
Duals are lame on a car like this. Itll look good with a single conversion, something like a flat black vibrant muffler at the back.
vivix is offline   Reply With Quote
Old 02-07-2012, 03:54 AM   #115
Maxim
Drives: 2010 GTI 2dr Tornado Red
There's really no point in having duals on this car...and the stock muffler set-up looks to be pretty restrictive. Lots of direction changes for the gas flow.
That being said, I will want to switch to a single pipe. High flow cats, and a nice flow through muffler. Sane diameter tip with no resonating chamber, because I do not want my car to sound like whale flatulance.
It's going to be slightly more complicated in this car though I think...I fully intend on purchasing the BRZ Limited with all the goodies, and that includes the aerodynamic underbody cover. It remains to be seen how much that will interfere with aftermarket exhaust layouts. I'd prefer not to have to cut into it to make the muffler fit, but that might be required to avoid melting a portion of it if I switch to a single side and do not use the space devoted to the muffler in the stock set-up.
I'm envisioning something similar to the silver Z car on this page...minus the coffee-can sizing of course.
Maxim is offline   Reply With Quote
Old 02-07-2012, 04:07 AM   #116
86design
Attack By Demons
86design's Avatar
Drives: 2022 BRZ (pre ordered)
I agree with most of you for the car only being a in line 4 you only need one exhaust...the dual is just styling looks...if it was a v6 that's a different story...when I get my BRZ I'm planning on doing a single exhaust then maybe later on down the road I'll get a dual from. Hks or greddy
#attackbydemons #imcomingbackbish
86design is offline   Reply With Quote
Old 02-07-2012, 12:33 PM   #117
jedichimp
OG <FR-S'less> Member
jedichimp's Avatar
Drives: yes
TRD Quad! Weight schmeight...
Flickr // SarapBuhay
merrill.joes@gmail.com
panda cheez
Old 02-07-2012, 12:40 PM   #118
merlin2111
merlin2111's Avatar
Drives: Widebody '94 Miata R-Package
haha i was about to post that but you beat me too it.
In reality though I would go for dual with either single or double tips. I dont like huge exhaust exits so 2 medium sized exits or 4 smaller ones would be my choice.
I <3 my Miata.
But I <3 my new BRZ even more!
merlin2111 is offline   Reply With Quote
Old 02-07-2012, 01:48 PM   #119
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Go big or go home.
old greg is offline   Reply With Quote
Old 02-08-2012, 09:43 PM   #120
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by WingsofWar View Post
Titanium true duals for ballerific status XD
Getting back to the Titanium for a second, some questions for the engineering guys with regards to what kind of fatigue issues a thin (20gauge/.035"wall) 2.500" or 2.750" diameter titanium exhaust would need to worry about.
(please ignore math failure I make about wall thicknesses...)
[u2b]6ei1LfvQv8A[/u2b]
Basically if the 1/16" wall 1" tube can survive that amount of deformation, and titanium has a good fatigue resistance reputation, is it something that I will need to worry to much about, since heat and vibration are different than just being squeezed in a vise?
Because titanium.
Old 02-09-2012, 12:23 AM   #121
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
without watching the whole video, did he ever comment on what grade he was using? I'm guessing Gr5...really common and does well with heat.
Homemade WRX is offline   Reply With Quote
Old 02-09-2012, 01:40 AM   #122
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
I picked dual for aesthetics. If I ever build for track then I'd def want a single.
Old 02-09-2012, 03:29 AM   #123
Quantum
Drives: Infiniti G35
Single full titanium exhaust, including piping. Should be less than 10lbs and I'll guesstimate stock one will be 40-50lbs.
-Hong
Quantum is offline   Reply With Quote
Old 02-09-2012, 05:01 AM   #124
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Thanks for the shout out.
It's "Ah-Crop-Uh-Vich" btw.
Anyway, your test isn't really applicable to fatigue life for a couple of reasons. The big one is that fatigue strength @ half of a cycle is always going to be the same as ultimate tensile strength. The issue you are actually worrying about is that there are little bits of titanium oxide/nitride etc. in the filler and HAZ that are acting as miniature stress-risers in the grain structure of the weld. When you load that material in tension, teeny tiny little cracks start to form. When you load it in tension over and over again those cracks start to grow and, over time, cause the metal to weaken. That's something you can't simulate just by squishing stuff in a vise. The other issue is the way you are loading the material. Bending it along the tube wall isn't really representative of the loads an exhaust will see in service.
The way to test it, imho, would be to have a piece of 1" solid bar, bored out at one end to match your tubing and welded to a ~12" length of the stuff. Clamp the solid end in a vise and have an electric motor with an eccentric weight at the end of the tube to provide a fully reversing load. Then run the motor and see how long it takes for the weld to break. Repeat the test at least once with a different load... maybe just cut away the broken stuff and HAZ, the reweld and test at a shorter length. Load vs. Fatigue Life should be a straight line on a log-log plot.
Failing that, the best thing you can do to prevent fatigue failure is use a flex section. Basically, give the tubing room to move so that you minimize stresses due to expansion and contraction.
Old 02-09-2012, 07:28 AM   #125
Maxim
Dual semi-truck stacks FTW! Just rip out those little fake vents in front of the windows and pipe them straight up!
Old 02-09-2012, 12:00 PM   #126
Dimman
Kuruma Otaku
Dimman's Avatar
The weight used would be proportional to the intended weight of the exhaust? The loading that it's subject to is basically itself moving around from inertial and vibration, right?
We're also hoping that slip-fitting it will reduce some of the expansion issues.
That's part of the problem. It's mystery titanium. ('He' is me, btw...) I'm not sure if it's Commercially Pure or 6 Al 4V (Gr5?) or what. Apparently it was scrap from a company that does fancy heat exchangers. On Burns' website it sounds like CP2 is what they use. I'm still trying to sort out all the different terminology for the grades, as it doesn't seem to be as universal as aluminum or SAE steel yet. Some are the 'Grade' as you mention, some refer to the alloy, 6-4 for example, aircraft stuff has Alpha, Beta, and whatever the C stands for, with a minimum yield number, C100 for example.
Also for Serialk1llr, aluminum exhaust stuff on Burns' site:
http://www.burnsstainless.com/yieldstrength.aspx
Because titanium.
ft 86 exhaust dalli Scion FR-S / Toyota 86 GT86 General Forum 11 09-08-2010 11:16 PM
Brake override system in the FT-86? mrKiKaZ Scion FR-S / Toyota 86 GT86 General Forum 10 02-22-2010 12:33 PM
