#113 |
So elite I'm 1338
Drives: WRB Subaru BRZ
@SuperDave is right, but (There is always a but), the engine has to maintain all of the factory emission equipment. I don't think this kit will do that.
-Jack Burton |
#114 |
Drives: 2015 Subaru BRZ - DGM 6MT
Getting by BAR and CARB with this type of swap is more than just emissions equipment. Factory cats have to be in the same "position" (distance from the motor/turbo within a certain range...I forget the margin they let you work with) as it is on the factory car it came out of. This kit might not be able to do that, but wouldn't be hard to change if there is space in the proper areas. I also am not sure on the smog legality of the FMIC vs the factory TMIC. I would personally be willing to run a hood scoop with a functional TMIC, but I'm sure some would not be. I'm still interested in the viability of this swap in California. Plus OEM Turbo setups are generally much more reliable and consistent than aftermarket (and that twin scroll turbo).
#115 |
I doubt the modified intake system, ie the front mount intercooler will pass a visual inspection. So I ask again, why would anyone do this at this point in time? When there are thousands of these engines in the wrecking yards and the prices come down maybe but right now, no.
#116 |
I think a lot of this is somewhat of a preparation for when that does happen. Give it a 2-3 years and there will be 2015+ WRX's getting wrecked left and right. Even if the cost of the swap was more than an aftermarket kit, I would still prefer this route. I have at least 2 years left on my warranty...after that it is game on.
#117 | |
Drives: 2015 Series.Blue
This. A ref would take one look at that and fail it. It's a nice idea, but when there's bolt on CARB approved supercharger kits out there, it simply doesn't make sense cost wise. |
#118 |
So elite I'm 1338
-Jack Burton |
#119 |
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
@Dipstik-sportech & @Poodles
Why would it fail visual inspection when you could have CARB'd SC kits with front mount ICs or heat exchanger? You guys are not making any sense at all. There are a lot of guys with LSX swapped cars getting BAR'd in CA, so it is not impossible nor as hard as some people believe it to be. |
#120 |
Snow Don't Hurt!
The FA20DIT is purpose-built to handle more power over the NA FA20, so what makes "sense" might differ from person to person. One is made to take more power, while the other isn't, but is just cheaper to trial and error, thus making it seem proven.
Plus the FA20DIT is exciting to most, while slapping on some aftermarket turbo kit to an FA20 just doesn't sound as exciting. Thus why these are TUNER cars. There are plenty of mods that don't make sense to me, but I don't crap all over them.
#121 | |
Because the entire kit went through the certification process. It's not cheap to do and it's not fast either. California has some really stupid and shitty laws when it comes to car modifications. I've known people to not pass because they changed their vacuum lines to a different color... |
#122 | |
http://forums.nasioc.com/forums/show....php?t=2474323 http://www.ls1lt1.com/forum/4th-gen-...nspection.html If you can't retain entirely OEM equipment from the donor car then you need to have the setup tested in a lab which costs thousands of dollars and this will be done each and every car that does the swap. |
#123 | ||
So elite I'm 1338
Once you get that vehicle inspection sticker, the "visual" inspection you guys keep referring to is a different matter. The visual inspection is based on YOUR car and not the model your car is based on.
-Jack Burton |
#124 | |
One caveat - WRX engines, specifically EJ205s that AREN'T JDM non-avcs, forced obso engines are not cheap and currently, are appreciating in value. Their value currently is at least 50% more than, going off personal observations here, 3-4 years ago when one could buy a rex 205 in decent condition for around a grand and some change. The common value is now north of $1.5k |
#125 | |
Yes the referee that you linked is an easier process as engine swaps are normal and California actually has pretty fair principles imo (engine same age or newer than chassis, all emissions intact). If any emissions part doesn't fit into the bucket of either OEM or CARB approved modification off to lab testing you go. You're right, once you get your sticker they just check to make sure everything is in working order and that you're not obviously gaming the system. As long as you're not fucking around your once every two year inspection will be a breeze. |
#126 |
Drives: Toyota
Sucks for you guys, but stop bashing, because for other it might be better and make a lot more sense.
Here in Europe the car culture is quite different. STOHL is based in Germany, I'm from Germany, so that is perfect for me. Supercharger and turbocharger kits just are not common here in Europe and hard to get. If STOHL can get this conversion FA20DIT kit done and TUV legal in Germany, that is much for me than any other 'bolt'-on kit. The Twin don't sell here in Europe, they can be had new for EUR 25K, when list price is above EUR 30K. They can be bought used low kilometers for under EUR 20K. Now if the conversion costs EUR 10K all included, this means I can get a used Twin and with conversion get 300 PS engine for EUR 30K. This basically means I pay the same price for as for a dealer new Twin, but WRX STI (JDM) engine. It just cannot be better than that. So haters, just get the f*ck off if you are not interested. |
| FA20DIT vs FA20 D4-s? | hmong337 | Forced Induction | 31 | 07-26-2020 02:11 AM |
| *** Feal Suspension, Megan Racing, BC Racing, KSport, ISIS Coilovers - ON SALE!!! *** | Sonic Motor | Brakes, Suspension, Chassis | 489 | 07-29-2016 02:15 PM |
| Convert NA FA20 to FA20DIT in the WRX | SunkenFRS | Forced Induction | 21 | 03-15-2015 08:59 PM |
| FA20DIT parts | glorydays | Forced Induction | 8 | 03-14-2014 05:03 PM |
| FA20DIT vs EJ25 - 2015 WRX and STI get dyno tested | kbye | Other Vehicles & General Automotive Discussions | 7 | 02-27-2014 09:40 AM |
