Old 09-13-2015, 12:00 AM   #113
twag4
Drives: frs
Originally Posted by civicdrivr View Post
When you purchased your tune, you purchased a license with it, correct?
If so, do the following (taken from http://blog.perrinperformance.com/ec...-installation/ ):
Sent from my XT1095
Thanks, this was the fix!
twag4 is offline   Reply With Quote
Old 09-20-2015, 02:58 PM   #114
dj2020
Delicious Tuning Q & A - FlexFuel BlueTooth Kits for EcuTeK ProECU RaceROM
Need some advice here: I'm installing the DW700cc injectors along with my DT flex fuel kit. I upgraded to the fuel injector adapters that connect between the DW injectors and OEM connectors. But now I can't fit the drivers side metal cover over the injectors because the adapters are in the way. Is it okay to leave the the metal cover off? Should I trim the metal cover (which would be a bitch I imagine)? Or have I angled the injectors incorrectly. I feel like I tried every combo. The passenger side metal cover was a tight fit but I managed.
dj2020 is offline   Reply With Quote
Old 09-20-2015, 11:21 PM   #115
dj2020
Never mind. I ended up sucking it up and just notching the metal covering on one spot for the passenger side and two areas on the driver's side for fuel injector adapter clearance. I probably went through 4 dremel attachments. It was a bitch but it's done. If the metal covering exerts any pressure on the adapter/fuel injector combo, you get a spray of fuel all over the place. Don't ask how I know!
@sales@delicioustuning.com: The FnG with FlexFuel Tune on my JRSC seems to be running awesome! Cold and warm starts are no problem. AC running no problem. I'm actually getting less idling rpm fluctuation than the CARB and OEM tune. More importantly, I'm enjoying the new found power. I'll send you some logs later in the week for you to double check things. Thanks again for answering all my questions before making this purchase.
Old 09-21-2015, 01:55 PM   #116
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
We're glad everything ended up well! We'll look into adding some photos for installation that show exactly where covers need to be trimmed for future reference on those injector connector adapters. Looking forward to your logs
Sincerely,
Zach
Old 09-23-2015, 12:25 PM   #117
dj2020
Originally Posted by brianhj View Post
Do you have a laptop? You can read it that way if you're parked. Or do you honestly need a way to check it constantly? I have the app and used it the first time i filled up but after that it was once in a blue moon.
How do we read the ethanol content with the Ecutek software on our laptop? For the life of me, I couldn't find it while I was creating logs for DT to review.
Old 09-23-2015, 01:11 PM   #118
DeliciousTuning
You can find this after expanding the "All Parameters" section and checking the line marked "Custom Map P Result"
Sincerely,
Zach
Old 09-24-2015, 05:53 PM   #119
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Hey Zach, is there a way to troubleshoot the Bluetooth content analyzer? Not sure if it's the problem but it runs way better on e85 than 91. Bill has replaced it before and I want to be sure before I continue to troubleshoot. Thanks!
Sent from my SAMSUNG-SM-N920A using Tapatalk
texasbound972 is offline   Reply With Quote
Old 09-24-2015, 09:32 PM   #120
DeliciousTuning
Hey Aaron,
Try connecting with the Android app and seeing what it displays (I don't remember if you have an Android or iPhone). If something is wrong, it should default to 0.00%. Make sure to use the app with the car on of course!
Sincerely,
Zach
Old 09-25-2015, 03:00 AM   #121
solus
Drives: 2014 Scion FRS (Ultramarine)
Originally Posted by sales@delicioustuning.com View Post
Hey Aaron,
Sincerely,
Zach
or check the parameter custom map P in ecutek...
my box burned out due to corrosion and water issue lol
solus is offline   Reply With Quote
Old 09-25-2015, 01:14 PM   #122
DeliciousTuning
That too. "Custom Map P Result" in EcuTek is going to be a direct result of the ethanol percentage the ECU is reading.
Sincerely,
Zach
Old 09-25-2015, 02:10 PM   #123
texasbound972
USMC
Hey Aaron,
Sincerely,
Zach
The app said it was connected but there were no numbers. It just showed -_-
Old 09-25-2015, 02:48 PM   #124
DeliciousTuning
What does Custom Map P result show?
Sincerely,
Zach
Old 09-25-2015, 03:55 PM   #125
DeliciousTuning
Aaron,
I forgot you'd been tuned by Church! Typically we setup our Flex Fuel tunes to read ethanol content through "Custom Map P Result". More than likely, Shawn has his setup on a different custom map. Your best bet is going to be to ask Shawn which map he setup ethanol content to read through so you can view ethanol content.
When our App displays "-.-%", that typically means the Bluetooth device is not properly connected, or that Bluetooth has been turned off. In the event of a failure, the app would actually resort to reading a flat "0.00%", and your vehicle would run best on 91.
Hope this helps!
Sincerely,
Zach
Old 09-25-2015, 03:57 PM   #126
texasbound972
USMC
Thanks Zach! I'll ask.
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
200+ WHP Completely Stock Vehicle, E85 and EcuTeK ProECU RaceROM Only (VIDEO) DeliciousTuning Software Tuning 156 07-01-2014 08:37 PM
Delicious Tuning - 200+ whp E85, Stock Headers, EcuTeK ProECU DeliciousTuning Software Tuning 19 12-07-2013 12:01 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
