#113 |
Drives: 2013 BRZ Premium Dark Gray Metallic
Installed
Here's mine installed with my 1/2" check valve. Thanks for the Pre-sale. Can't wait for the Pre-sale for the 2nd Catch Can.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler Last edited by zoth; 01-16-2015 at 10:09 PM. |
| The Following 4 Users Say Thank You to zoth For This Useful Post: |
#114 |
Drives: 2013 Subaru BRZ
#115 |
Drives: Asphalt FR-S
Received my kit less than an hour ago!
Very happy with the quality ![]() ![]()
#116 |
#117 | |
Drives: 2014 BRZ
John, how important is it to run a 'check valve'? I just installed my kit a few minutes ago. I plan to install the oil cooler kit tomorrow now that we have some nice weather down here. |
#118 | |
Got it here. http://www.boombaracing.com/check-valve-12-mm-1-2/ If your boosted a check valve would be a good idea I don't NA will benefit from it.
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
| The Following User Says Thank You to zoth For This Useful Post: | DAEMANO (01-16-2015) |
#119 |
Drives: white-out FR-S
question?
what are u guys using to open the catch can? I notice opening it out of the box it is on incredibly tight. 2nd there is a hex alen key hole on the bottom of the can. what is this used for?
#120 | |
Mines not tight at all. Bottom hex would be for draining if that's the way you want to drain. But I think opening the can would be easier.
#121 | ||||
The allen key hole is a port for emptying the can. You can either drain it by removing the entire base, or by removing this plug. Additionally, we are working on a drain valve kit which will thread into this port. This will be an add-on item for the catch can in the near future. Thanks! |
#122 | |
update.
hey guys disregard; Yes it is on VERY tight and found someone with good hands to twist it. overall easy install. thanks guys will keep you guys updated on how much it catches.
#123 |
#124 |
Drives: 86 GT MT
Do you think the bracket will clear the brake lines on a RHD car?
#125 | |
Drives: Exige S 240
@Mishimoto, will your UK distributor http://www.mishimoto.co.uk/ sell this product soon?
#126 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
Anybody notice any noise coming from the can after install? I cant tell for sure, but feel like I'm hearing some kind of noise coming from that area when the engine is under load.
| Mishimoto Compact Baffled Oil Catch Can Build Thread! | Mishimoto | Engine, Exhaust, Transmission | 81 | 08-21-2019 09:05 PM |
| Mishimoto Build Thread: BRZ/FR-S Silicone Induction Hose | Mishimoto | Engine, Exhaust, Transmission | 23 | 11-29-2018 12:35 PM |
| Mishimoto Build Thread: BRZ/FR-S Performance Cold-Air Intake | Mishimoto | Engine, Exhaust, Transmission | 90 | 12-03-2016 07:22 PM |
| FS:WA- ADD W1 REd Baffled Universal Aluminum Catch can | glamcem | Engine, Exhaust, Bolt-Ons | 0 | 07-05-2014 08:15 PM |
| Win a Mishimoto Oil Catch Can! | Mishimoto | Announcements, Contests, Giveaways | 68 | 10-23-2013 06:27 PM |
