Old 09-07-2013, 05:52 AM   #113
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Why not simply disconnect the drl?
448hpsti is offline   Reply With Quote
Old 12-26-2013, 11:26 PM   #114
jeremy86
Drives: Whiteout FR-S
does anyone have the picture of the steps?
jeremy86 is offline   Reply With Quote
Old 01-10-2014, 08:50 PM   #115
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
does anyone have the pictures to show the location of the DRL resistor? I think the pictures were removed from the first post.
Old 01-18-2014, 12:25 PM   #116
stueck9356
Drives: 2015 VW GTI SE
Originally Posted by Hardrock4445 View Post
Napa relay part # AR6034.
IMO this is the best way to do this. It costs about 25 bucks, but there is no modding, taping, or whatever. Just go into the fuse box, pop the current one out and put this on in there. Everything still works 100% but the DRLs never turn on. Easier to reverse too.
stueck9356 is offline   Reply With Quote
The Following User Says Thank You to stueck9356 For This Useful Post:
Hardrock4445 (01-18-2014)
Old 02-11-2014, 01:51 AM   #117
Target70
Target70's Avatar
25 bucks here and there can add up.
finally found it in fsm. For those who want to do this, the DRL resistor is located behind the bumper cover on the passanger side, just underneath the horn. big heatsink block according to the picture in the FSM, instructions are to remove bumper cover to access the resistor.
Old 02-11-2014, 11:50 AM   #118
tennisfreak
Drives: 2018 BMW M240i
I unplugged my resistor about 6 months ago and am so glad I did.
Its super easy. I did not even need to jack the car up or undo any clips/bolts like the original instructions said.
Just slide under front bumper, find little rectangle access panel and remove it, reach in and unplug resistor, tape and zip tie up, put access panel back on. DONE!!!
Old 02-25-2014, 08:14 PM   #119
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Anybody willing to post up pictures to match the guide? For some reason I'm not seeing them anymore.
Manic is offline   Reply With Quote
Old 02-25-2014, 10:58 PM   #120
Target70
Target70's Avatar
I don't have pictures, but look at my post above for location.
after I got my car off the ground I saw what tennisfreak was talking about in the post above yours. There is a small rectangular panel about 3 inch X 4 inch, that you can pop out with a flat head screwdriver. Inside you can easily grab the connector to the resistor (black heat-sink). Put tape over the connectors, and zip tie them up to the harness and you are done. Hope that helps.
Old 04-13-2014, 05:36 PM   #121
dragonboy221
Drives: n/a
Originally Posted by FRSFirestorm View Post
Disregard the red circled. I borrowed this picture from another thread. Working from memory but I'm pretty certian its located in the spot circled in yellow. Anyway it is clearly located by using the schematic underneath the lid to this fues box. Looking for DRL Relay
So all i have to do is remove the fuse (yellow circle) and then tape off that area???
also, as other people have mentioned, are there anymore pictures to confirm this?
dragonboy221 is offline   Reply With Quote
Old 04-26-2014, 11:49 AM   #122
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Hmm... I noticed FR-S owners posting in here exclusively.
Anyone with a BRZ actually remove the DRLs? Truth be told I never really looked at the fog light bezels that closely... my car is too far to check. hah
I was thinking of linking the boomerangs to the DRLs (as seen below), then deleting the DRLs
unsurety is offline   Reply With Quote
Old 05-17-2014, 07:12 PM   #123
D_Thissen
D_Thissen's Avatar
Could you post some pics please of what we are looking for? OP pics aren't there any more
Old 05-18-2014, 03:47 AM   #124
crouchingpinoy
crouchingpinoy's Avatar
Drives: Firestorm 6MT
Here you go! DRL is turned off but high beam function stays intact. Sorry for the poor iPhone 4 (not even an S!) pic.
@jeremy86 @Manic
Rick
crouchingpinoy is offline   Reply With Quote
The Following User Says Thank You to crouchingpinoy For This Useful Post:
Manic (05-18-2014)
Old 05-19-2014, 10:33 AM   #125
tennisfreak
I did the resistor as well and it the way to go, less than 5 minutes and no adverse side effects.
When I did mine I wrapped the ends in electrical tape just in case water splashed up under there.
Old 05-19-2014, 11:28 AM   #126
D_Thissen
D_Thissen's Avatar
Thanks!!!
