Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 03-12-2015, 04:09 AM   #113
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Let's not talk about getting panties in a knot. These "tjooner" wars are getting stale and most of them are just making themselves look bad.
@FT_86_SM_GP I thought we were over it now, why create more drama?
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 03-12-2015, 04:58 AM   #114
Dammod
Dammod's Avatar
Drives: .
Back on topic:
Stock Engine BRZ with AVO turbo kit at 0.9bar...THAT SOUND
[ame="https://www.youtube.com/watch?v=Hj0GwdS7kUI"]AVO Turbocharged BRZ sets a record at Okayama Circuit! - YouTube[/ame]
@AVOturboworld
"Some will follow your footsteps, easier than they will your advice."
Dammod is offline   Reply With Quote
Old 03-12-2015, 10:06 PM   #115
FT_86_SM_GP
FT_86_SM_GP's Avatar
Drives: Lawn moweR
Haha I could not resist/had a slip, the ex-VW driver inside me was missing the drama...
Apologies,
On that (drama) note, The Avo Kit does sounds wicked, and at 1m47s through that video....
FT_86_SM_GP is offline   Reply With Quote
Old 04-02-2015, 05:06 AM   #116
Jacques Blom
Turbo 86
Jacques Blom's Avatar
Drives: Toyota 86 Turbo
Still wonder if having a turbo at the bottom of the road is such a good thing.. I explored both options for Top or bottom mount and ened up with the top version :
My concerns are
1. .. water and clean air
2. The distance for the air flow to the intake ..
any thoughts ?
Jacques Blom is offline   Reply With Quote
Old 04-02-2015, 10:18 AM   #117
Dammod
Dammod's Avatar
Drives: .
My concerns are
any thoughts ?
Good questions Jacques.
1. A turbo generally runs more efficiently the hotter the exhaust side of the turbo (up to a point), hence turbo blankets having a dual function of both containing the heat inside a turbo for efficiency purposes as well as for stopping latent heat from escaping into the engine bay.
Having said this, the natural flow of air through the 86 engine bay is through the grill area and under the engine, right through where the turbo sits.
AVO have not had any issues with any of their BRZ/86 turbo kits and water and they have sold MANY kits.
2. The distance from the engine/exhaust ports to the turbo is possibly one of the (if not THE) shortest out of all the turbo kits, the piping on the intake side is thus slightly longer due to the turbo being closer to the exhaust.
AVO turbo kit being known for being extremely responsive partly due to the short distance between the exhaust and turbo.
The new WRX and Forester XT have the turbo kit in almost exactly the same position straight from the factory.
Old 04-09-2015, 11:42 AM   #118
Shadeslayer
Shur'tugal
Shadeslayer's Avatar
Drives: Toyota 86 Galaxy Blue Silica
If I may add... It's also beneficial to have longer compressor-intake piping because, the more the compressed air volume, the lesser the lag plus there's more surface area to cool the compressed air, especially if a small turbo is used (faster spooling).
Don't judge a man until you've driven a mile in his 86.
Shadeslayer is offline   Reply With Quote
Old 04-09-2015, 12:07 PM   #119
sav
sav's Avatar
What takes longer to pump up, a big balloon or a small balloon?
95RON SAV Tuned
Old 04-09-2015, 12:08 PM   #120
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Depends if it's you blowing
Ryan86 is offline   Reply With Quote
Old 04-09-2015, 12:12 PM   #121
sav
sav's Avatar
Your sister. So which takes longer?
95RON SAV Tuned
Old 04-10-2015, 03:06 AM   #122
Shadeslayer
Shur'tugal
What takes longer to deflate?... a big balloon or a small balloon?
Old 04-10-2015, 03:39 AM   #123
sav
sav's Avatar
have a read here:
http://rusubaru.com/intercooler-efficiency/
I know it relates to the turbo subarus but the same basics will apply. Look at the piping length on a stock one - it's minimal and for a good reason - less lag.
95RON SAV Tuned
Old 04-10-2015, 06:06 AM   #124
Shadeslayer
Shur'tugal
have a read here:
SAV, this is different. Yes, fitting a bigger intercooler and extra piping will increase lag, and this is mostly due to piping losses. AVO setup in principle, does not increase piping length, they chose to rather have turbo closer to the exhaust than compressor closer to the intake.
In case of AVO setup
The distance between the exhaust manifold and turbo inlet is very small and considering how big is the diameter of the compressor outlet pipe, piping losses are negligible. Bigger volume, is really not a problem too. Its like having a bigger reservoir vs a smaller one or not having it at all. you will still have the same mass flowrate between the inlet manifold and the compressor discharge. I might also argue that you get better massflow rate with a slightly bigger reservoir because you get slightly cooler compressed air. Not to mention the ability to run turbo more efficiently with exhaust manifold mounted turbo.
Old 04-10-2015, 07:23 AM   #125
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Phew, either you type too fast, or I read too slow
I just took a good look under my bonnet to have a look at what really works well... (because it does!!)
Here ya are: It's a "very short" distance from manifold to turbo (12cm), a "very short" distance from turbo to intercooler (25cm), a "very short" distance from intercooler to intake (7cm), a small(ish) turbo, and not excessively thick pipes. Simple - QED. Minimal lag.
You can weight each aspect differently, but the reality is that you can't get better than everything being "very short" and no bigger than necessary.
Oh, I didn't say under which of my bonnets it was...
It's this one.
Fish Eagle is offline   Reply With Quote
Old 04-15-2015, 03:33 AM   #126
Dammod
Dammod's Avatar
Drives: .
Originally Posted by AVOturboworld View Post
Ross of AVO Japan wins the 2015 Hypermeet 5 Lap Battle!
You can see how fast he reels them in from the reverse grid start, thanks to the power of the AVO Turbocharger kit!
[ame="https://www.youtube.com/watch?v=m8ElzEvIQjI"]2015 Hypermeet at Tsukuba - 5 Lap Battle - YouTube[/ame]
Jees, AVO's turbo GT86 kicking ass!
Feeler: Dyno Tuning Session via Jamesm @ HRI tuning sw20kosh Northern California 27 11-28-2014 07:53 PM
R/T Tuning & R/T Tuning Speed Shop Review Thread R/T Tuning User/Vendor/Sponsor Reviews, Feedback, Comments 37 10-03-2014 02:23 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 03:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
