Old 12-11-2014, 01:37 AM   #113
SonnyBRZ
SonnyBRZ's Avatar
Drives: 15 WRX 6mt (DD), 13 BRZ Sports Tech
Originally Posted by kiichiro View Post
The v2 is hella more stout than a v3
I beat the snot out of mine
13/14 psi
The v2 has no issue where the v3 would cook its 4oz of fluids
I concur, it can run hotter if you will, it does share engine oil, but I'm not sure about more load
Make sure you vent your v2 or foaming can kill it. Ask me how I know, just always warm up your car to prevent that initial start up foam!
I love my v2 just wish I wouldn't snap belts with the 2.87" pulley buy have found no solution, running the 3.33 I can run a belt and track it all summer long, and that's saying lots here in hell, aka phx
Is your belt on the V2 hella tight and tensioner pretty much all the way ? My car runs fine but the tensioner position with the belt on just doesnt seem right to me. When it was stock or with V3, the tensioner was way more relaxed.
06 Infiniti G35x - Black 5AT (DD)
13 BRZ Sports Tech - White 6spd (June 18, 2012!) - Vortech SC
15 WRX Sport - ISM 6spd - Ordered May 3, 2014
SonnyBRZ is offline   Reply With Quote
Old 12-22-2014, 04:49 PM   #114
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
which belt and pulley combo?
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 12-23-2014, 12:34 PM   #115
Enalband24
Drives: Subaru BRZ Limited MT
Hey guys, just wanted to throw up some updated info. @marcoaferrer
I believe JDL has revised their long tube EL catted header as mine is about an inch away from the SC bracket as opposed to a few mm. It *may* even be compatible now with the V-2 unit...I'm not sure though...it would be incredibly close.
Regarding the V-2 unit, I was thinking, instead of welding a bung to the valve cover and running a line across the front of the engine, could we just run a braided (or solid) return line straight to an aftermarket oil pan (such as MAP's), provided the proper brackets/fittings to keep the line from getting in the way of moving parts?
I mean, people are doing the same thing from turbos in roughly the same location...also, it would be less work in my opinion, and the extra capacity of the aftermarket oil pan couldn't hurt either...
Enalband24 is offline   Reply With Quote
Old 06-18-2015, 03:30 PM   #116
surfuxalot
Drives: Toyota Frs
For a 2.87 pulley on a vortech v2 kit, do u need a new tune. I saw people run a smaller pulley with the same ecutune, but it doesnt seem right to me lol. And were could i get a 2.87 pulley tune for the vortech v2 kit, and is it carb legal?
surfuxalot is offline   Reply With Quote
Old 06-18-2015, 03:35 PM   #117
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
New Tune for Sure. I bought the 3.25" Pulley, but ended up going back to the stock one, because I didn't have enough octane on 91 pump to use more boost.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
The Following 2 Users Say Thank You to Gopherboy6956 For This Useful Post:
CSG Mike (06-19-2015), surfuxalot (06-18-2015)
Old 06-18-2015, 04:53 PM   #118
surfuxalot
Drives: Toyota Frs
ah, i see. Thanks
Old 06-18-2015, 11:21 PM   #119
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Anyone use a JDL UEL header with Vortech kit?
http://jdlautodesign.net/shop/ft86-u...length-header/
I am wondering whether it will fit if I got the $4000+ base kit and if I upgrade it in the future. ( Cuz I saw that JDL EL will not fit the V2 upgrade).
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 06-19-2015, 02:16 AM   #120
Gopherboy6956
That will fit. It doesn't encroach on up the front of the engine like the EL one.
The Following User Says Thank You to Gopherboy6956 For This Useful Post:
Figo (06-19-2015)
Old 06-19-2015, 09:56 AM   #121
Figo
Figo's Avatar
Thank you!
Old 07-16-2015, 04:07 PM   #122
Figo
Figo's Avatar
So I assumed that for the V3 kit, there is no new and old version right?
I think the model number is 4TF218-114L.
The price is different on different website so I am not sure whether it has older&cheaper and newer&more expensive version or not.
Old 07-23-2015, 10:26 AM   #123
Figo
Figo's Avatar
Will it be a problem to run V2 upgrade kit in cold winter here in New Jersey?
I am thinking to get the V2 but do not know whether there is any drawback of this upgrade kit? Is there any?
Old 07-23-2015, 12:01 PM   #124
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
hey guys so I was hoping someone could shed some light on this situation and give me a sound reason on why these things happened. Installed the vortech on my AUTO. The install was done perfect except for one thing, in the instructions it says that the bov for MANUALS ONLY should tape into the brake booster line. And for AUTOMATICS uncap and tap into the intake manifold othe drivers side as stock it is capped for autos. I started the car up and it quickly bogged down and stalled on me I got it towed to my tuner and got it dyno tuned. After that it ran great for a week but always a little boggy with the rpms, now before you say it's the tune think about the bov and tapping into the wrong line and the intake manifold still being capped. The car then a week later bogged really bad about three times and stalled on me. Got towed to my mechanic and they changed my battery bc it was shit and then I fixed the bov and tapped into the intake manifold mechanic said all parameters while driving were within normal ranges and the car didn't bog down on him and stall at all. You could hear the bov opening and closing.
Now I'm sure vortech did this for a reason for manuals and autos and tapping into a different line but I don't know how this would affect bogging and stalling. This car is all electrical and it's always a mystery but idk I'm hoping someone could explain why they do this and or why this happened and now the car runs perfect
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 08-13-2015, 07:28 PM   #125
Figo
Figo's Avatar
Finally.
Old 08-13-2015, 07:32 PM   #126
sissupr
sissupr's Avatar
Drives: 2014 BRZ Premium - SWP
Awesome. Now plan on 8h of bitching putting it in... lol. Good stuff..
Vortech SC V3 // 3.12 Pulley // Moto-East Tune (93oct,e40-50,e85)
sissupr is offline   Reply With Quote
New Vortech Maxflow Blow-Off Valve Upgrade for FT86 Supercharging Systems Brian@Vortech Forced Induction 168 08-08-2018 12:45 PM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 03:05 PM
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 04:42 PM
Vortech Supercharging Systems Now Legal On 2 Continents... Brian@Vortech Forced Induction 27 01-22-2014 02:33 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 06:49 PM
