Old 05-08-2014, 06:06 PM   #113
gramicci101
Off Topic
I put mine on my recliner so I could still have that "in the car" feeling while I watched tv.
Old 05-09-2014, 08:16 PM   #114
midnightfrolic
Drives: Scion FRS A/T raven
Originally Posted by gramicci101 View Post
If you put the car in reverse and floor it, you can go backwards quickly.
But the question is: "Can it drift in reverse?"
midnightfrolic is offline   Reply With Quote
Old 05-09-2014, 09:55 PM   #115
BRZnut
Drives: BRZ DGM Limited
any hidden feature to raise the passenger seat?? Wife feels it's too low for her!
Old 05-09-2014, 10:08 PM   #116
gramicci101
Off Topic
Old 05-10-2014, 12:10 AM   #117
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Mine too. She just sits on a pillow.
I've been thinking about taking the seat out and putting spacers to lift it up.
Old 05-10-2014, 12:34 AM   #118
KenTK808
Drives: White 2014 Scion FRS
On both driver and passenger door jambs there is a small square metal loop that sticks out of the side opposite the hindge. This is car manufactures way of saying "have a cold one on us". If you guessed bottle opener then youd be correct. Drink and drive responsibly my friends.
KenTK808 is offline   Reply With Quote
Old 05-10-2014, 01:57 PM   #119
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
Originally Posted by extrashaky View Post
This is less of a hidden feature and more of a silly joke, but I just discovered that there are actually floor mats under the seats, as if anybody sitting on that ridiculous back seat will actually be able to put their feet on the floor.
is that in the BR-Z only? You know if those werent there the car would be that much cheaper
Old 05-10-2014, 02:12 PM   #120
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
The glovebox has a secret compartment.
If you put things to far in, they fall out the back and into the dashboard area. I thought I lost my insurance/registration cards a few months ago until I found them sitting back there.
subiestyle is offline   Reply With Quote
Old 05-10-2014, 02:17 PM   #121
Ben_G
Drives: Blue BRZ
That's where I learned about the hood mount. The other handy thing I learned there was that there's a built-in pass through in the firewall for gauge lines.
Also, for those who are interested in adding an oil gauge but don't want to add a sandwich plate under the oil filter, there's a handy oil gallery hole right next to the throttle body where you can plug in your sender. See this thread for pics:
http://www.ft86club.com/forums/showp...95&postcount=8
That is awesome...didn't know about that...
Ben_G is offline   Reply With Quote
Old 05-10-2014, 02:36 PM   #122
NemesisPrime909
NemesisPrime909's Avatar
Drives: 91 Toyota Supra 16 Nissan Versa
Originally Posted by ZOMFGAARON View Post
Shit I have to try this
famous last words....
The FRS/BRZ was not meant to be a world beating car, it was not meant to be an extremely fast car, nor a powerful car, but a well balanced fun car.
NemesisPrime909 is offline   Reply With Quote
Old 05-10-2014, 02:47 PM   #123
jkr
jkr's Avatar
Drives: '13 frs
Originally Posted by Floggin Tires View Post
I believe some Scions will apply to this.
At least the ones with door handle lock unlock sensors.
On Limited BRZ's
Factory settings:
When you touch the inside of the handle to unlock the door,
it unlocks the drivers side only. If you want both driver and passenger
side to unlock with a single touch of the handle, do as follows.
Open The driver door,
Leave the car off,
On the key fob Hold down both Panic and Lock buttons for ~5secs.
When you let off you should hear a beep.
all toyotas have this as well.
jkr is offline   Reply With Quote
Old 05-12-2014, 05:52 PM   #124
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
If you own a lizard of some sort, you'll be glad to know that after 300 miles or so, the car provides you free crickets.
I'll see myself out.
Manic is offline   Reply With Quote
Old 05-14-2014, 11:00 AM   #125
pascalbrax
pascalbrax's Avatar
Drives: Toyota GT86
Originally Posted by Haeb View Post
So... on a 2014 with the Smartkey / push button starting theres a way to leave your keys in your pocket and lock the car door without pushing the lock button switch on the interior door panel. On both the driver and passenger side exterior door handles you'll find these two little dashes....close the door, press on the dashes and your locked If ya toss the key in the car and try locking it you just get a beeeeeeep....it wont lock from the outside with the key on the inside
Is that a hidden feature? This is exactly the first thing the car dealer told me before giving me the keys of my new car.
Also, he told me there's a way to lock the car even if you left the key inside (but you need the second backup key).
pascalbrax is offline   Reply With Quote
Old 05-15-2014, 03:24 AM   #126
Maowc
EndlessClouds
Maowc's Avatar
Drives: 2013 Scion FRS
Originally Posted by Mikem53 View Post
- Turn on the car. The car must be FULLY warmed up. You must do the entire sequence within 30 seconds of starting the car.
- Pull the e-brake 3 times. Hold/lock the e-brake on the 3rd pull.
- Press the brake pedal 3 times. Hold it down the third time.
- Pull the hand brake 3 more times. Hold/lock the hand brake on the 3rd pull
- Press the brake pedal 2 more times.
- On the last press of the brake pedal, two yellow lights should have come on.
Best used ONLY for track use!
Followed by the controller; up, up, down, down, left, right, left, right, A, B, L, R, START, SELECT.
You should hear a weird bell chime.
Take your dreams and smash it!
Maowc is offline   Reply With Quote
scion brz hidden features
Ideas for a hidden magnetic phone-mount. MmmDieselFumes Cosmetic Modification (Interior/Exterior/Lighting) 40 05-09-2016 01:14 PM
Bespoke A/V Hidden Option UbSaMrC Electronics | Audio | NAV | Infotainment 58 12-13-2015 11:14 PM
FS: Custom Stainless Lightweight Hidden Hitch that_guy Canada Classifieds 3 06-11-2014 07:13 PM
Hidden Rusting issue FRSHunter Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-07-2014 05:02 PM
DIY: access hidden menus on BRZ head unit robot DIY (Do-It-Yourself) Guides 0 10-22-2013 11:59 PM
