Old 05-20-2014, 11:41 PM   #113
xZAMx
Drives: '13 FR-S - Hot Lava
Because the stock setup seems to be reliable, there has yet to be someone completely stock with a broken axle. If you'll notice every single post in this thread is on some form of aftermarket suspension and/or has made significant changes to the power output.
The ticking/clicking may just be a loose axle nut allowing some slop in the assembly, lubricating and torquing the nut should fix the noise.
Okay that makes sense, but even so one goal the developers had in this car was for the consumer to tune and customize it to their liking. IMHO, this seems like a serious limitation suspension wise.
xZAMx is offline   Reply With Quote
Old 05-21-2014, 12:53 AM   #114
strat61caster
strat61caster's Avatar
As has been said before and will be said many more times: you have to pay to play.
If it's any consolation there are many cars on aftermarket suspension with no issues, it seems to be more prevalent with cars that have 1" or greater drop and changes from the OEM geometry.
ineedyourdiddly
Old 05-21-2014, 10:26 AM   #115
ShutterSpeed
Drives: Olive Drab/Army FRS
I personally think it could be. Iwould only hear the ticking from the axle when i had some riding with me, thus putting more weight on that side. my noise also only seemed to be audible when i was downshifting or slowing down in gear. not so much when accelerating.
QUALITY OVER QUANTITY
ShutterSpeed is offline   Reply With Quote
Old 05-21-2014, 12:47 PM   #116
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
So you want to have your cake and eat it too
As others have said, pay to play. If you plan on adding additional power over stock or modifying the suspension, go ahead and pay extra for new axles. I read in another thread, that whatever your budget is for modifying the car, go ahead and double it.
Eurasianman is offline   Reply With Quote
Old 05-21-2014, 12:50 PM   #117
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Originally Posted by BlaineWasHere View Post
I don't think so. My clicking noise was loud and only noticeable while accelerating from a stop, not cruising at speed.
Same here mine was only happening in first from a stop. I was only on a 20mm drop when it happened. But lots of autox launches.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 05-21-2014, 10:12 PM   #118
xZAMx
Yeah I mean a guy can dream can't he?
Old 05-22-2014, 12:48 PM   #119
Eurasianman
Chief
Old 05-23-2014, 02:16 AM   #120
chermo12
chermo12's Avatar
Drives: 2013 SSM BRZ
Originally Posted by wheelhaus View Post
It's possible but not likely. If you hear a faint ticking while the wheels are turning, and it changes speed with wheel speed (not loading, accel, etc), you probably just have a rock (or nail) stuck in the tire. A dying CV joint would typically make the most noise under load (accel) and deflection (in our case, compressed or lowered suspension; or in a FWD platform when the front wheels are turned), not just spinning freely with the wheel like when coasting or cruising at low throttle.
Thanks for the replies. I guess I was a bit paranoid. Drove around yesterday and noticed the ticking went away. So I'm guessing it was something stuck to the tire which probably got dislodged. I will keep an eye on this thread going forward.
chermo12 is offline   Reply With Quote
Old 05-24-2014, 12:30 PM   #121
Droegs2
I have had my brz in over 6 times for issues that lead me to believe its a control arm or axle problem. Subaru has given me free alignments/tire rotations. They have replaced the bushings and the car still always pulls right w/ vibration in steering wheel and gas pedal. (Never jumped curbs)...... Anyone else having this issue or have an idea how to fix it.....
I can't drive over 80 mph without my car wanting to jump lanes of traffic (always right and gets worse the faster you go)
If I drive for over 30 min the tpms always comes on and the vibrations begins to get worse. Almost like something is heating up and expanding to the point of it hitting other metal.
Droegs2 is offline   Reply With Quote
Old 05-24-2014, 01:10 PM   #122
Annahra
Annahra's Avatar
Drives: 2014 WRB BRZ LTD
In the shop six times? I would start talking lemon law. That's inexcusable.
Annahra is offline   Reply With Quote
Old 05-24-2014, 06:28 PM   #123
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
That doesn't sound anything like an axel issue. Sounds like a bent suspension link if alignment is accurate.
Old 05-25-2014, 04:12 PM   #124
Powersfrs
Drives: Frs
Just found this thread! I had the clicking noise (driver rear tire) NA power with kws lowered bout 2 inches on 255..the click only came on when first pulling away from driveway or if reversing..now with the innovate supercharger on the click comes on (same side) everytime I acceladate
Powersfrs is offline   Reply With Quote
Old 05-29-2014, 12:25 PM   #125
Rinn310
Drives:
New axles are definitely going to find their way into your budget. Personally wanting to SC mine with OEM suspension And i am allowing for axles .
Rinn310 is offline   Reply With Quote
Old 06-12-2014, 05:41 AM   #126
gonzo
Drives: frs
I got the clicking about 6-8 months ago and it's getting worse. Stock suspension and only a tune. Changed from stock tires to michelin pilot super sports also around 6 months ago but no hard launches or autocross since the new tires.
gonzo is offline   Reply With Quote
more money than brains, stance bro
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 07:34 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
