Old 11-21-2013, 11:02 PM   #113
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Probably should add a water reservoir in the trunk and mount the constant flow pump (or an upgrade to that pump) there. That'll add water mass to flow through the system that is not anywhere near being heated by the engine and is after the heat exchanger. That should help in the high heat environments like us desert dwellers.
^GT5 Replay Photo Mode^
Old 11-23-2013, 06:22 PM   #114
y2janz2
Drives: Whiteout
Hi guys, so I found 1 leak today...anyone else ran into this problem?
[ame="http://youtu.be/0Kz00-0dP_M"]http://youtu.be/0Kz00-0dP_M[/ame]
y2janz2 is offline   Reply With Quote
Old 11-23-2013, 11:24 PM   #115
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Is that coming from your throttle body?
Ryan86 is offline   Reply With Quote
Old 11-24-2013, 12:44 AM   #116
y2janz2
Drives: Whiteout
It is coming out of that clear tube, I am not sure what is it called, but I heard waste gate.
Old 11-24-2013, 01:09 AM   #117
sw20kosh
Drives: 2013 Black FR-S
that just sends a vacuum signal to the bypass valve. a tiny leak isn't a huge problem there. i would still try to stop it
The Following User Says Thank You to sw20kosh For This Useful Post:
y2janz2 (11-24-2013)
Old 11-24-2013, 02:15 AM   #118
y2janz2
Drives: Whiteout
Thanks. Hopefully stopping it will clear my P0171 CEL.
Do you happen to know if I have to take off the manifold to fix it/try to stop it or how to stop it? The shop that I took it to didn't want to touch it, they just told me to call Innovate or take it back to where I got it installed.
Nevermind it is connected to the throttle body.
Old 11-25-2013, 04:00 PM   #119
brianhj
Drives: 2017 Camaro 1SS
Originally Posted by Innovate Motorsports View Post
We are proud to announce that the Innovate Motorsports intercooler systems are now available for preorder!
Dyno graph
Standard 75mm pulley, stock exhaust and 91 octane fuel.
Any other mods?
brianhj is offline   Reply With Quote
Old 11-25-2013, 11:01 PM   #120
Ryan86
Road Warrior
Ryan86's Avatar
I removed the TB and sealed the grey plastic L connectors and put back together, took car down to the dyno.
Previous run with suspected leak
211whp180ftlb
Leak fixed
233whp185ftlb
The above made on 91 Oct 75mm pulley
The Following 4 Users Say Thank You to Ryan86 For This Useful Post:
CK_Bladesmith (11-25-2013), Lawnik (11-25-2013), normancw (11-25-2013), whataboutbob (11-26-2013)
Old 11-25-2013, 11:03 PM   #121
brianhj
211whp180ftlb
Leak fixed
233whp185ftlb
Any other mods? What is your baseline stock dyno?
Old 11-25-2013, 11:13 PM   #122
Ryan86
Road Warrior
Ryan86's Avatar
My base line was 155whp 141ftlb
I added AFE DIF, Borla Header, decatted 3" performance exhaust.
I still have the stock overpipe, I seriously think it needs to go???
At 233whp the car is truly insane.
The Following User Says Thank You to Ryan86 For This Useful Post:
SirBrass (11-25-2013)
Old 11-25-2013, 11:16 PM   #123
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
The stock OP is a pretty big restriction. Even though I have no numbers to prove it, when I replaced mine I noticed a world of difference. The butt dyno doesn't lie!
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 11-25-2013, 11:26 PM   #124
Ryan86
Road Warrior
Ryan86's Avatar
OP is on my list, just trying to figure out which is the best to get.
I have the worst Butt dyno, truly not in sync with my car. When I think Booom I get terrible numbers and then I think the car is not pulling I feel no difference, whaaam 20whp gain.
Having a dyno down the road, I have put every item installed in the dyno and understood what it has done, so when OP is fitted I'll share.
Old 11-25-2013, 11:29 PM   #125
brianhj
That's awesome. Question.. when it comes time for inspections, what do you do about having no cat?
Old 11-25-2013, 11:33 PM   #126
Ryan86
Road Warrior
Ryan86's Avatar
Our laws don't require a vehicle inspection until 5 years old if I'm not mistaken.
I have due to sound of the Borla and decatted being just too crazy, fitted a HPC to the front pipe to reduce sound, but over here its Africa rules...
Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! Innovate Motorsports Forced Induction 577 10-15-2014 12:49 AM
Innovate Motorsports BRZ/FR-S/GT86 Supercharger System Available from Moto-East! Xero-Limit Forced Induction 12 03-10-2014 08:56 PM
Innovate Motorsports FR-S/BRZ traction control state modifier module... mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-13-2013 01:06 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 09:14 PM
FS: Innovate Motorsports OT-2 pixel67 Engine, Exhaust, Bolt-Ons 0 01-05-2013 10:13 AM
