Old 07-10-2014, 10:10 AM   #113
kanundrum
Drives: 2013 Whiteout FR-S
It's a note3!! Hahaha
Old 07-10-2014, 12:58 PM   #114
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Sorry phablet.
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
Old 09-28-2014, 03:00 PM   #115
nataku
Negative Mass
nataku's Avatar
Been a while since I posted here. Got a bit of an update lol.
Car died mid-autocross. I was topping out 2nd gear and the gas pedal stopped working. Came to a stop near some course workers and stalled. Car wouldn't start back up. We pushed it off the lot and disconnected the battery hoping it was fuel-cut and would reset. Reconnected battery and car still wouldn't start.
Pulled some fuses and found the 15A EFI CTRL fuse was blown. Put the spare 15A fuse in and tried to start car. Blew the fuse again.
Car has been towed to the dealer to have the electrical system looked at. Hopefully it's not a wire melted by the turbo, maybe some possibility at warranty then. Either way I'll post updates when I have them...
This thread shows folks having a similar issue with various places where the fuel electronics might short to ground. If it's a melted insulator I'm probably SOL on warranty lol. Hopefully not too much $$
Edit: Unrelated but I just realized how good my paint looks in that picture...
Old 09-29-2014, 01:22 AM   #116
Pete156
I like to eat!
Sounds like a grounding issue. I installed the 86 Cusco grounding kit early on to try to avoid issues like this. I have read several other owners having issues with motor electrical grounding. Hope everything works out and the problem is identified early by the dealership.
Pete156 is offline   Reply With Quote
Old 09-29-2014, 10:56 AM   #117
Timmy_Jones
Spun
Drives: 23' Supra
Any updates on what happened?
Timmy_Jones is offline   Reply With Quote
Old 09-29-2014, 12:25 PM   #118
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
From what I understand, there are no wires close enough to be melted by the high-heat elements of AVO kit..wonder what caused this.
Best of luck man.
Old 09-29-2014, 12:40 PM   #119
protpibe
protpibe's Avatar
Best of luck man.
Yeah the only "hot spot" is above the turbo, but there's a heatshield there.
From what I read, it's a fuel injector wire coming in contact with the metal cover. Here's a solution:
http://www.ft86speedfactory.com/name...lack-1744.html
Old 09-29-2014, 12:42 PM   #120
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Jeez, that wire must really be jostling around
Old 09-29-2014, 12:47 PM   #121
protpibe
protpibe's Avatar
If it actually is that, I wonder if it's early production models having the potential issue. There's a ton of foam padding underneath my injector covers and I don't see how a wire would melt or become damaged under there.
Sounds like a perfect opportunity to move to Radium fuel rails and a Nameless injector ECU mount
Old 09-29-2014, 05:02 PM   #122
nataku
Negative Mass
nataku's Avatar
Apparently my drive belt was rubbing on the wiring harness. Shop said the wire got rerouted due to turbo kit installation. They're repairing the wires, I'll get more details in a bit.
My kit didn't have a heat shield. It was either left out during installation or not in the box. I have a turbo blanket installed. The service guys said that this wasn't a melting issue. They're re-routing the wire so it won't happen again.
Edit: My car is from the first round of production, but given the fact that the wire was moved I'm not sure if that has anything to do with it.
Old 09-29-2014, 11:12 PM   #123
Pete156
I like to eat!
Look to the installer!
Last year you posted : Thanks to @Pure Automotive for a fantastic installation!
Well, Sounds like they forgot to install your heat shield AND left your wires vulnerable. Good thing you didn't have an electrical fire. It sounds like they are responsible for this failure from what you have told us. I would at least let them know. Am I wrong?
Old 09-30-2014, 03:01 PM   #124
nataku
Negative Mass
nataku's Avatar
Last year you posted : Thanks to Pure Automotive for a fantastic installation!
While your logic is sound you are indeed wrong in this case. Yes the heat shield was missing, and I got a turbo blanket installed because of that. I had been driving for months without issue lacking that heat shield.
In this exact case I am at fault. PTuning had redesigned my intake and secured the wiring harness to the MAF against a piece of hose near where my AOS lines needed to route. I had cut the zip-tie holding the wires in place and nothing seemed to be wrong with it at the time. Turns out the drive belt ate its way through the wires. Lesson learned.
Got my car back and everything runs fine.
Old 09-30-2014, 06:11 PM   #125
kanundrum
Yays. Back in business
Old 11-22-2014, 12:04 PM   #126
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@nataku How's your replacement header going? Has it been leak free at the flanges since the new one went on?
Fizz is offline   Reply With Quote
so boost much car, such orange wow blue
PTUNING: FR-S/BRZ/GT86 Spec-SS Turbo System (Now Shipping) ptuning Forced Induction 151 09-23-2016 10:48 AM
Toyota GT86 TURBO vs McLaren MP4-12C TIE Pilot FR-S / BRZ vs.... 20 09-05-2013 01:56 PM
New Toyota GT86 TURBO vs McLaren MP4-12C pascalbrax FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 08-28-2013 02:36 PM
Race prepped GT86 + turbo vs McLaren MP4-12C tanner FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 08-27-2013 05:05 PM
Non USDM BRZ oil weight BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-21-2012 02:55 PM
