Old 03-14-2012, 02:44 PM   #113
BPAuto
BPAuto's Avatar
Drives: GT-R, S2000, Evo VIII-X, BRZ, FRS+
Great post thanks!
We officially placed our deposit and signed the paperwork for a BRZ yesterday, so this gives a time to get ready for delivery!
BPAuto is offline   Reply With Quote
Old 03-14-2012, 02:49 PM   #114
bestwheelbase
Drives: 1985 P-Type
Originally Posted by Draco-REX View Post
The one with the regular key (not the small brick) works like a regular key and fob system, and is NOT proximity based. You have to hit the Unlock button and turn the key in the ignition like normal.
This is still such a giant leap forward for me, that I cannot imagine ever needing anything more. Who remembers the first time they remote-unlocked their car? Oh it feels so good.
Old 03-14-2012, 02:55 PM   #115
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by lpnnlp View Post
Why such gloom about the AT?
Because it downshifts when you lug it? When is this likely to happen to you? Most likely you were driving around the city in a high gear (because you were watching the real time consumption on the display), you slow down but forget to shift, and as soon as you are giving it some gas, you are lugging it badly. With a manual box, as soon as you realize this, you will need to get off the gas and shift (again, talking about lugging it badly.) There is a good chance that the AT will detect this faster, do the shift faster, and into the correct gear for your speed. This is user error pure and simple. This is a good and smart thing to do.
And the upshift? Only when you are redlining it *AND* the AT is already boiling. Really, how likely is this? If you are a track-rat, you are not going next to the AT even when they are about to hammer the nails into you on the cross, so in a realistic situation, I highly doubt you will see this even on your occassional frisky track day.
Bottom line:
This looks like a great choice for DD with an AT that doesn't have a mind of it's own. If you run into the lugging downshifts, then just keep the tranny in "D" and enjoy the vehicle dynamics, and call it a day. If you run into the second situation above, then you are spending a lot of time on the track, so congrats, you have now graduated to a more capable car, in which case the FRS/BRZ fulfilled it's mission.
He is a track guy and the oil temps will likely be high enough for it to auto up-shift, which defeats the point of a "performance automatic".
I'm sure he doesn't give a crap about the auto downshift.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-14-2012, 02:56 PM   #116
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
All the more reason to get a manual. See Subaru is making it easy for those who can't decide AT vs. MT.
tranzformer is offline   Reply With Quote
Old 03-14-2012, 03:16 PM   #117
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Does anyone know if the IS-F's transmission upshifts as well?
No idea but I don't see the relevance anyways since this is NOT an IS-F transmission I don't consider the IS-F as a car I'd ever buy simply because of the transmission either.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-14-2012, 03:24 PM   #118
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
■ Changing the REV indicator settings
The engine speed at which the REV indicator turns on at and
whether a buzzer sounds or not when the light turns on can be set.
Engine speed setting range: From 2000 to 7400 rpm (r/min)
Press the “DISP” switch repeatedly until the setting screen is
displayed. (→P. 195)
Press and hold the “DISP”
switch.
“REV.” and the thousandth place
flash. After flashing, the number
changes each time the button is
pressed and held.
Press the “DISP” switch.
The hundredth place flashes.
pressed and held.
A buzzer sounds once, and setting of the engine speed value is
complete.
nice
on the DRL's
Daytime running light system
●Vehicles with an automatic transmission: To make your vehicle more visible to other drivers, the daytime running lights turn on automatically
whenever the engine is started, the select lever is shifted out of P and the
parking brake is released. Daytime running lights are not designed for
use at night.
●Vehicles with a manual transmission: To make your vehicle more visible
to other drivers, the daytime running lights turn on automatically whenever the engine is started and the parking brake is released. Daytime
running lights are not designed for use at night.
●Compared to turning on the headlights, the daytime running light system
offers greater durability and consumes less electricity, so it can help
improve fuel economy.
■Headlight control sensor
Headlight control sensor is located on the
passenger's side.
The sensor may not function properly if
an object is placed on the sensor, or anything that blocks the sensor is affixed to
the windshield.
Doing so interferes with the sensor
detecting the level of ambient light and
may cause the automatic headlight system to malfunction.
Spark plugs
Spark plug
Make - DENSO ZXE27HBR8
Gap - 0.031 in. (0.8 mm)
CAUTION
■Iridium-tipped spark plugs
Use only iridium-tipped spark plugs. Do not adjust gap when tuning engine.
Gasoline
Unleaded gasoline (93 AKI [Research Octane Number 98] or higher)
If unleaded gasoline with an octane rating of 93 AKI (98 RON) is not available, unleaded gasoline with an octane rating of 91 AKI (95 RON) may be
used with no detriment to engine durability or driveability.
There is an option I think for the "16 wheels (I think)
Wheel Size
Type A
Type B
Free play Less than 1.2 in. (30 mm)
Tire size P205/55R16 91V, T135/80D16 101M
Tire inflation pressure
(Recommended cold tire
inflation pressure)
Front: 35 psi (240 kPa, 2.4 kgf/cm2
or bar)
Rear: 35 psi (240 kPa, 2.4 kgf/cm2
or bar)
Spare: 60 psi (420 kPa, 4.2 kgf/cm2
or bar)
Wheel size
16 × 6 1/2J, 16 × 6 1/2JJ, 16 × 4T (compact
spare)
Wheel nut torque 89 ft•lbf (120 N•m, 12.2 kgf•m)
Tire size 215/45R17 87W, T135/80D16 101M
inflation pressure)
or bar)
or bar)
or bar)
Wheel size 17 × 7 J, 16 × 4T (compact spare)
Snoopyalien24 is offline   Reply With Quote
Old 03-14-2012, 03:31 PM   #119
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by Snoopyalien24 View Post
nice
And it'll turn on again (not sure if it will beep or not) when you hit the red zone on the tach. A built in shift light w/ beep is a great thing to have.
Old 03-14-2012, 03:40 PM   #120
MrBRZ
Originally Posted by tranzformer View Post
Yes there are pics on here of the premium interior. Just have to look around. Will see if I can find you anything.
Here are some pics:
Thanks buddy. Man, not gonna lie, disappointed a bit. The best part of the BRZ interior are those awesome toggle switches.
Looks like im going Limited now hahahaha.
MrBRZ is offline   Reply With Quote
Old 03-14-2012, 03:40 PM   #121
Snoopyalien24
Mr. Sarcasm
K updated post with more important things for those TL;DR's
http://www.ft86club.com/forums/showp...&postcount=120
Lemme know if I'm missing something else important
Old 03-14-2012, 03:47 PM   #122
tranzformer
Drives: Zoom Zoom
I agree the ACC is very nice looking. However the only real thing I wanted were the seats. I don't want the spoiler and I don't want the fog lights. Rumors of $2-3k price increase was a lot for me to justify getting the limited mostly for the seats and proximity key.
Old 03-14-2012, 04:42 PM   #123
TOMIMOTO
TOMIMOTO's Avatar
Drives: MY00 Impreza 2.5RS
The original link is dead. Was there another one listed?
TOMIMOTO is offline   Reply With Quote
Old 03-14-2012, 04:45 PM   #124
OrbitalEllipses
Drives: Attitude
Originally Posted by Marrk View Post
Why don't thank the great Fascist State of America for EDR. Now, with this kind of Big Brother surveillance technology, insurance companies can download your driving and assess liability to you (deny your claim) in an accident, and LEOs can charge you with violations of the law (unsafe speed, etc.). You only have to be going 46 mph in a 45 mph zone to lose the case.
I don't disagree with you, but what the fuck does that have to do with the conversation ahausheer and I were having about octane?
See:
Originally Posted by dropbox
Error (509)
This account's public links are generating too much traffic and have been temporarily disabled!
You guys broke it.
Old 03-14-2012, 04:47 PM   #125
MrBRZ
Yeah the leather looks amazing. But cloth these days looks pretty sharp. My buddy has a GTI and the cloth is pretty nice and cool looking still.
Old 03-14-2012, 04:51 PM   #126
Giccin
Giccin's Avatar
Awesome awesome awesome!!
Now I have something to read. lol
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Should i get manual or AT? mistax Other Vehicles & General Automotive Discussions 98 02-28-2013 06:25 PM
GT86 UK preview brochure download 2800GT EUROPE 2 02-23-2012 09:19 AM
Will Scion/Toyota and Subaru (AS1) owners be united or divided? Mess11 Scion FR-S / Toyota 86 GT86 General Forum 66 12-29-2011 09:31 PM
Beautiful FT-86 wallpaper for download (hi-res available) Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 43 02-22-2010 01:16 AM
