Old 08-08-2013, 03:48 PM   #113
Hotchkis
Hotchkis's Avatar
Here's ours:
- HRE C106 18 x 9 +35 (All 4)
- Dunlop Z2 255/35R18 (All 4)
- No Rubbing, No modification
Additional Info:
- Due to smaller aspect ratio, the 255/35R18 overall diameter is the same as 255/40R17 on the Direzza ZII, so gearing is the same. Good to know for guys that are on the fence about 17" vs 18" with using these tire sizes. 18" tires are more expensive, but sexier
- We are running Koni single adjustable shocks, so this fitment is good for stock style strut perches. Our camber plates include OE crash bolts which are set to full negative camber. So they are set to the least amount of tire to perch clearance.
- Front camber is -2.8°
Hotchkis is offline   Reply With Quote
Old 08-08-2013, 04:41 PM   #114
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
I've just purchased a set of 17x9, e42 Rota Grids for my meaty ride. Not real light, but with 245/40 Conti DW tires it'll be reasonable. Wife (her daily driver car) didn't like thin spoke wheels, so the Rotas were really the best option.
So, question - if I go with say Race Comp Yellow springs and crash bolt/camber kit, I'll end up losing some gap between the spring perch and rim/tire compared to stock springs and no camber/crash bolts? What about JUST springs? Will the gap get narrower? Thanks for any feedback y'all may have!
boarder1995 is offline   Reply With Quote
Old 08-09-2013, 01:39 AM   #115
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
255/40/17 ZIIs on 17x9 RPF1s.
Sooty for the shirty phone pics but I just had then mounted. I'll have more pics after autoX this weekend.
Old 08-12-2013, 10:08 AM   #116
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
are you talking about inside clearance between the perch and rim? if so camber would in theory actualy put you closer to it. the perch and diameter is still the same size. and whats getting lower it the top. the bottome of the purch will stay the same level with the wheel. just try to picture that, perch is connected to the hub, and whats dropping is the top. either way you should be okay, the offset is aggressive enough to give you some clearance. however i'd ask @King Tut about stock perch questions.
Jive Turkey is offline   Reply With Quote
Old 08-12-2013, 10:35 AM   #117
djdnz
1337
Drives: 2013 BRZ WRB S/C
You're going to have to dial camber out, I have this exact same spec with the same tires at stock height. You can find my thread in the wheel section, there is 3mm clearance from the perch to the tire. When lowering it's not going to fit unless you remove a lot of camber. Either remove camber, don't lower it, add spacers, or get coilovers - pick one.
djdnz is offline   Reply With Quote
Old 08-12-2013, 11:10 AM   #118
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Nope. The lower spring perch is in a fixed location. It does not move at all relative to the wheel, so if you want to keep it, you need to size your wheel/tire to accomodate.
Old 08-12-2013, 11:38 AM   #119
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Not sure if these are meaty enough or not.
17x8 RPF1, 245/40/17 DIIs.
Eibach Sportlines.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 08-15-2013, 01:42 AM   #120
Captain Insano
Originally Posted by WolfsFang View Post
Sorry if i'm jacking, just don't want to clutter the forum with the same question again and again. I have super stretch tires, these came with my wheels and I never intend to keep on running them. Im looking to go meaty tires but I can only seem to find 245 (I have 16's) and the two best ones I found are Nitto NT01 and POTENZA RE-11. Iv never really searched for sticky tires so im like a deer in headlights. Im fine with 245 up fronts but hopping to find 255-265/40-50/16 fpr the rear or even all around, any help would be greatful.
This thread is so win... WolfsFang, do you have pics of this setup?
Old 08-15-2013, 01:47 AM   #121
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
http://www.ft86club.com/forums/showthread.php?t=38680
I can take pics of the stretch tomorrow if that is what you are referring to.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 08-15-2013, 01:55 AM   #122
Captain Insano
That's gonna look tough when you get the new tires.
Old 08-18-2013, 01:22 AM   #123
DAMotorsports
Drives: 2013 Scion FRS "Raven"
:So does 275/35/18 Hankook RS3 all the way around and tracked count.
DAMotorsports is offline   Reply With Quote
Old 08-18-2013, 11:36 AM   #124
ImAwesome
Drives: 99' M3, 13' SWP Brz
only if you post it
ImAwesome is offline   Reply With Quote
Old 08-18-2013, 11:53 AM   #125
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Let us see and we will tell you.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 08-18-2013, 11:59 PM   #126
DAMotorsports
As you wish, I am pulling a photo from the camera that we took at the 86 fest while in the Turn 14 booth.
WedsSports Wheels 18x9.5
Hankook RS3 275x35x18
**will post better pics of the actual tires,, rear view,, tomorrow**
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
