Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
View Poll Results: Heel Toe around town? | |||
ALWAYS RACECAR |
97 | 35.79% |
Sometimes, for fun |
78 | 28.78% |
Almost never/don't know/don't care for it |
78 | 28.78% |
Drive an Auto |
18 | 6.64% |
Voters: 271. You may not vote on this poll |
#113 | |
i didnt miss the context, i know how to heel-toe, and im not even playing devils advocate. needing to heel toe is needing to downshift but needing to down shift isnt needing to heel toe. |
The Following User Says Thank You to fatoni For This Useful Post: | strat61caster (06-07-2013) |
#114 |
#115 | |
Drives: Scion FR-S 2013
True, but are you going to rev match to do it? If you heel-toe, you're saving time.
This I agree with, but you will be in better control of your car if you do heel-toe since you are constantly in the correct gear for power, should you need it. Do you agree? |
#116 | |
#117 | |
okay. i just assumed that since you quoted a post that was quoting me that was the intent. no harm done. |
#118 | |
Drives: 2015 Sti Launch Edition
No need for everyone's panties to get into a bunch.... If you enjoy doing it, go for it... if not, no one is forcing you. Do what you will and what puts a smile on your face. ![]()
#119 |
Drives: 2013 FR-S Ultramarine
Not rev matching requires you to slip the clutch quite a bit, or be jerky. If we're talking about reducing wear on the clutch that is the single worst option.
The Following User Says Thank You to SubieNate For This Useful Post: | SkullWorks (06-07-2013) |
#120 | |
Drives: SSM LT MT BRZ
OK now atleast we understand what you are missing, If you choose not to rev match it adds wear to your clutch, I guess we were all having this conversation assuming you had an understanding of WHY we were having this discussion since the wear on the clutch has been brought up and discussed, so you have now been informed DIRECTLY and can quit claiming there is NO benefit, because the benefit is less wear and tear on the clutch/flywheel/pressure plate Do you start in second gear "because it isn't mandated that you don't?" |
#121 | |
wut? So when you drop a gear you let the car jerk till the engine matches the transmission... I feel sorry for your car and your passengers. ![]() |
The Following User Says Thank You to Luis_GT For This Useful Post: | SkullWorks (06-07-2013) |
#122 | |
Drives: '13 FR-S Argento
If you have the brakes applied and want to be in the correct gear approaching a corner or stop, down shifting is required. The two ways you can down shift with the brakes applied: 1. Release the clutch pedal slowly without rev matching the engine. 2. Rev match the engine with the clutch in neutral. (Heel Toe) Both of these techniques will put you in your desired gear. 1. Using the clutch to match the engine speed to the transmission speed will cause engine braking. If the clutch pedal is release rapidly, the engine braking effect could lock the drive wheels. If the clutch pedal is release carefully, the balance of the car can be maintained. 2. Heel toe down shifts prevents you from upsetting the balance of the car during braking. Fatoni is right, being in the correct gear is not the main reason to heel toe down shift. Maintaining the balance of the car during braking and down shifting is why you would choose to heel toe. I choose to always heel toe when I drive because I feel it is the most effective method I can use to brake and down shift in a smooth and controlled manner. Last edited by DM7; 06-07-2013 at 07:03 PM. Reason: Spelling |
#123 | |
#124 | |
under normal driving (which is what this thread is about), the engine speed between gears is small. at these speeds there isnt really a discernable between the stress of an upshift and downshift. so unless you are rev matching your upshifts you should probably save at leas half of that pitty for your car and its passengers. |
#125 | |
When you upshift you don't "rev match", the engine will drop rpms the moment you release the clutch which automatically compensates for the RPM difference between gears, that's why you release the throttle when you upshift... when you downshift without tapping the throttle to compensate for the difference in RPM's when you drop a gear the engine will most likely fall to idle before you re-engage the clutch causing a big difference between engine RPM and the transmission gear |
The Following User Says Thank You to Luis_GT For This Useful Post: | SkullWorks (06-10-2013) |
#126 | |
Everyone I know rev-matches on upshifts (i.e., releases the throttle between upshifts) unless they're deliberately powershifting/FFS. The reason you release the throttle between upshifts is to match revs for the next gear.
2022 BRZ Build 2013 FR-S Build |
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post: | Luis_GT (06-08-2013), SkullWorks (06-10-2013) |
Do NOT Drive Your BRZ Through This Town... | White64Goat | BRZ First-Gen (2012+) -- General Topics | 14 | 06-01-2013 08:58 AM |
e town road course april 7th | Grip Ronin | NY / NJ / CT / PA | 7 | 04-04-2013 10:04 AM |
Crappy gas in my town help | Trobinson | CANADA | 4 | 03-24-2013 09:49 PM |
Car Town FR-S | CSSM | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 01-21-2012 03:22 PM |
Heel and Toe | ichitaka05 | Other Vehicles & General Automotive Discussions | 13 | 04-02-2010 02:28 AM |
