Old 08-18-2013, 10:01 PM   #113
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by mike the snake View Post
So, I'm planning on getting FI soon. Anything I should tell my tuner to do, or check, to make sure I don't have any DI issues?
If i go with this tuner, I believe this will be the first FRS/BRZ that they have done a turbo install/tune on, so I want to be armed with as much info as possible. I've already noted things like the fuel pump install (O-rings and spacer) but if there's anything else they should look for, or avoid, I'd love to know before hand.
I would go with a tuner that knows this car
The Following 2 Users Say Thank You to whitefrs For This Useful Post:
mswhong (08-18-2013), Sportsguy83 (08-18-2013)
Old 08-18-2013, 10:19 PM   #114
mike the snake
I'm new to the tuning thing. Would a tuner be offended if I wanted to have my car dynoed by them but tuned by someone else remotely?
The tuners near me that I know of are WORKS and Fine Line Imports. So far I've only talked with FLI. They say they'll tune from scratch, taking it incrementally.
Are the base tunes locked? Can a tuner take the base info from another tuner's tune and work from there? Do tuners share info or work together?
Old 08-18-2013, 10:26 PM   #115
xjohnx
Grip>Slip
xjohnx's Avatar
DeliciousTuning is in cali, although i have not clue whether they're in norcal or socal. they would be able to take care of you though if you want someone in person.
Old 08-18-2013, 10:52 PM   #116
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
of course they wont get get offended. just tell them that the guy who is selling the kit offer to tune the car for free.
u also dont need a dyne, you can start with the kit baseman, do datalogs and send them to the tuner for a revised map
Old 08-19-2013, 11:29 AM   #117
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
LJ's Full Blown basemap is the only EcuTek tune I know of that is not locked. All the other tuner's tunes will be locked. I would say there is about 0% sharing of knowledge between tuners at this point, and I think that sucks for us as the consumer. One tuner figures something out and holds on to it like it is gold.
The Following User Says Thank You to King Tut For This Useful Post:
mad_sb (08-19-2013)
Old 08-19-2013, 11:32 AM   #118
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
True
Old 08-19-2013, 12:07 PM   #119
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
Any recommendations for tuners up in Minnesota (St. Paul and surrounding)?
shiro is offline   Reply With Quote
Old 08-19-2013, 12:11 PM   #120
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Full Blown Motorsports??
The Following User Says Thank You to Sportsguy83 For This Useful Post:
shiro (08-19-2013)
Old 08-19-2013, 12:28 PM   #121
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
You got the best @FullBlown
The Following User Says Thank You to whitefrs For This Useful Post:
shiro (08-19-2013)
Old 08-19-2013, 12:38 PM   #122
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Not sure if SRS. LJ @FullBlown for sure.
shiro (08-19-2013)
Old 08-19-2013, 01:07 PM   #123
FAER
Drives: Silver BRZ
So not to start anothr fire but...
We all know visconti tunes "lean" for more power
Lean conditions increase cylinder temps
Increased temps melts injector seals
So .... If a=b, and b=c, and c=d does a=d
FAER is offline   Reply With Quote
Old 08-19-2013, 01:21 PM   #124
King Tut
NASA SpecE30 Racer
King Tut's Avatar
So not to leak flexfuel on the fire, but you might have a point.
The Following 4 Users Say Thank You to King Tut For This Useful Post:
NickFRS (08-22-2013), NotSoJDM (08-19-2013), Sportsguy83 (08-19-2013), suaveflooder (08-19-2013)
Old 08-19-2013, 01:43 PM   #125
shiro
shiro's Avatar
Thanks guys! I'm told Fullblown is one of the best and hear they are a Master Tuner. I will have to talk with them soon.
Old 08-19-2013, 05:19 PM   #126
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
You cant go wrong with LJ
shiro (08-19-2013)
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 04:26 PM
Brake fluid leaking from pistons/seals normal? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-06-2012 02:54 PM
Bad window seals? Dzeremijs Issues | Warranty | Recalls / TSB 18 10-26-2012 03:24 PM
