Old 03-23-2014, 08:14 PM   #113
Malt
Drives: 2015 WRX
Originally Posted by tonystewart View Post
I wish it was that easy
Do you have an aluminum driveshaft? I assure you it works the majority of the time baring issues in the balance from the factory.
Malt is offline   Reply With Quote
Old 03-23-2014, 09:27 PM   #114
jack43
jack43's Avatar
Drives: Sterling Silver BRZ Limited MT
Driveshaft Shop Carbon Fiber Shafts Explained
Another one here who had a noisy aluminum one, rotated it and now it's quiet.
jack43 is offline   Reply With Quote
Old 03-24-2014, 09:09 AM   #115
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Carbon
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 03-25-2014, 12:30 PM   #116
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I ordered mine a few days ago. Hopefully it'll be coming in this weekend. Veddy excite!
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following User Says Thank You to Anthony For This Useful Post:
radroach (03-25-2014)
Old 04-10-2014, 04:13 PM   #117
tonystewart
This question is for Drive Shaft Shop
What is the warranty policy on the carbon fiber drive shafts?
What is the return policy for a carbon fiber drive shaft you built and were unable to repair, in order for the car to be quiet and vibration free, after "MULTIPLE" returns and shipments which the buyer pays for?
Old 10-21-2014, 04:43 PM   #118
ProjectD
ProjectD's Avatar
Drives: '04 350Z/ 2013 LR BRZ (LM)
Originally Posted by GOT FR-S View Post
I just threw in the Aluminum one this weekend. It is awesome!
Do you remember the torque specs you used to tighten the 4 bolts, or did you just use the good ole "gud-n-tite" method? Also, were the stock bolts long enough to cover the thicker flanges of the alum ds? I thought i read somewhere that other had to use special types of bolts (longer) and replaced the stock ones....
Originally Posted by mixcorp View Post
I dont know if it has been tackled here already but may i know the torque spec for this? and will i still need a locktight for it ?
^ this been answered?
Originally Posted by ahtais2000 View Post
I got my Alluminum Shaft from my Hong kong Seller, the result is very bad , it generate very very large virbration at 160KM or about, I feel danger and restore the stock one already.
Fortunately i dont have the Vibrration issue that some has reported but i do hear a "metal to metal" clunk noise as i shift gears/ release clutch. Do you have that as well?
Originally Posted by Driveshaft Shop View Post
Just a head up, the Auto shafts are a go..........
As stated above - luckily i dont have the Vibration issues, but i do hear a "metal clunk" type of noise when I shift/ release clutch. has anyone else reported similar issues? I didnt notice it on the day of the install when I ran some test laps, but not its more obvious (windows down/ radio off). Thoughts?
ProjectD is offline   Reply With Quote
Old 11-13-2017, 09:12 AM   #119
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Pulling this from 6ft under; will - 20f be a problem for this carbon shaft? Someone else asked and went unanswered. I need to know!
Also, any other experience stories explaining the difference you felt? I'm staying n/a, will have lwcp, light wheels and hope for a responsive car. I'm traumatized by my 3000gt VR4.
Old 11-13-2017, 12:27 PM   #120
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I can give you my personal experience, I got the first AT CF driveshaft from Drive Shaft Shop. I sent them my stock one to use as a template. I personally felt it made lots of thing all around a little better. Acceleration, and breaking both a little smoother and a little better. I fully acknowledge this could all be in my head. It’s not an amazing difference, maybe not worth the money depending on your budget.
BTW I no longer have my BRZ but I do still have the AT CF driveshaft. If anyone is interested let me know I have no need for it with a forester LOL.
Old 11-17-2017, 12:26 PM   #121
e_lunatic
Drives: 2015 Scion FR-S
i dont have the drive shaft shop driveshaft on my personal car BUT the Formula D teams I have been a part of since 2011 have all used their driveshafts and axles and can 100% say they are second to none.
the last 3 seasons the car I worked closely used the carbon driveshaft. the car has over 1000hp and 1000ft/lbs of torque and we had 1 minor issue (also the driver was a little extra hard on the equipment so we didnt blame DSS at all).
would always trust their product and they have great customer service as well.
e_lunatic is offline   Reply With Quote
Old 11-17-2017, 12:57 PM   #122
Real carbon fiber such as used in drive shafts will not be effected by the cold at all. Hoods, wings, etc are very rarely made of 100% carbon fiber and it is the other materials used that are affected by low temperatures not the so much the CF.
DarkPira7e (11-18-2017)
Carbon Fiber Mirrors - Shark fin Antenna - Carbon Fiber Accessories-PRICES LISTED!!! F-T Exterior Parts - The Rest 285 08-24-2015 05:42 PM
Carbon Fiber dash like a BMW? (pictures of M3 carbon fiber interior included) master345 Cosmetic Modification (Interior/Exterior/Lighting) 56 05-04-2014 12:10 PM
The Driveshaft Shop Custom Axles and Shafts Sportsguy83 Engine, Exhaust, Transmission 26 01-11-2013 05:55 PM
Automatic Carbon Fiber Driveshaft? Yes! RallySport Direct Engine, Exhaust, Transmission 13 12-15-2012 01:40 AM
