| View Poll Results: Would you buy an aero Kit designed by me? | |||
| Yes, I would if i was considering a kit. |
79 | 40.72% |
| No, I would not buy a kit from you if i was considering a kit. |
15 | 7.73% |
| No, I am not considering a kit. |
37 | 19.07% |
| Undecided, Not Sure if I want a kit or not |
21 | 10.82% |
| Undecided, I am considering a kit but I would like to look at my options first. |
42 | 21.65% |
| Voters: 194. You may not vote on this poll | |||
#113 | |
MODERATOR-SAMA
Drives: Swagtron Scooter
Venting dry hot air from the engine bay angled at the high pressure zone of the windshield is bad juju. Venting warm moist air from the radiator towards the high pressure zone of the windshield is more ideal. Something that aids radiator efficiency is a well shrouded eletric fan which is typically effective enough to not need such a wide air dam. A clutch fan for the radiator as seen on most stock cars is effective, but isn't aerodynamically efficient because it pulls too much air into an already high pressure area, which unfortunately is also dry and hot. eg back half of the engine bay. So with a well shrouded radiator fan that pulls at least 2500cfm of air, we can actually decrease the air dam for more pass through velocity towards a vented low pressure area at the bottom or ideally..the sides of the car. If we want to vent the high pressure hot air that accumulates in the engine bay to aid cooling, and aid aerodynamics we need to shoot that air towards low pressure areas of the sides of the hood/fender towards the A pillar so it wraps around the car aiding the velocity of airflow towards the spoiler. ---sorry i just rambled--- I think the mistake we average guys make in tuning aerodynamics in cars is we always target the problematic areas of drag rather than looking to optimize the airflow from front to back. looking at the big picture is hard without a visual aid from CFD.
![]() Last edited by WingsofWar; 01-23-2012 at 02:51 PM. |
#114 |
Kuruma Otaku
I think mostly the point of the hood venting is downforce/lift reduction. The low pressure area is the source of lift. Venting the hood at low pressure areas allows the high pressure built up in the engine bay to 'neutralize' it. Then when we have less high pressure in the engine bay that also allows more flow through the rad/intercooler.
Because titanium. |
#115 | |
MODERATOR-SAMA
Aid down force Reduce top side Lift Reduce bottom side lift Aid heat exchange from Radiator Aid engine bay temps to a minimum. Reduce engine bay pressure .. unfortunately just adding vents and flaps without considering its function like what most designers do **myself included** can have ill effects on performance. For example, I believe that this hood by J's Racing is non-functional aero dynamics. ![]() Here is why i believe this , -The shape of the open vent is square non-taper -the location of the vent is smack right at the center of the hood. -There is a lip at the opening that stops any sort of speed built up from the low pressure zone -Now theres a awkward high pressure air zone at the front of the hood, in front of a vent that already shoots high pressure hot engine bay air into a high pressure zone at the edge of the hood. -that floating high pressure area above the hood wont aid additional cold air to flow through which would probably resulting in no engine bay temp changes from stock. -Also resulting in unwanted drag, in the form of non-productive downforce. Im sure effects on performance are not extreme. But still if your going to buy a $1500 hood, it needs to be functional AND stylish. i think im pretty correct in this analysis. ---- Also lets remember that as long as the boundary layer stays attached at low pressure zones, we don't see lift forces that negate performance. but we also have to remember that heat changes the characteristic of air. **some footnotes to myself** -Warm moist air is light and less dense resulting in low pressure air. Its the least stable form of air. -Dry hot air is heavy, resulting in high pressure and can have the worst effect on drag. -Cold Moist air is dense but still light, ideal kind of air for cooling and heat exchange. -Cold Dry air is extremely heavy and dense, and results in high pressure. this is the kind of air you want to use for down force. ------------ I think im ready to try my hand at designing a hood that could be functional.
#116 |
Kuruma Otaku
I actually disagree with the J's hood being non-functional.
- The shape I don't really know about, so not sure. But louvers do the job, and an opening is an opening. So it may not be optimal, but it is at least functional. - The location looks to be where the natural low-pressure area will be forming - The lip is going to form only a slight high-pressure area in front, but also enhance the low pressure zone behind it. Right where the vent is. - So because of the above, there is vented low-pressure that can 'suck out' the high-pressure bay air. - Lift reduction probably is more positive than the drag increase is negative. My .02
Because titanium. |
#117 | |
Drives: '06 AM V8V Coupe
About the top of the car, well completely altering the angle of the rear windshield isn't really possible without completely rebuilding the body, so this is pretty hard to work with. Typically people add wings and stuff but those cause some pretty bad drag. Now on the front of the car, the base of the windshield is certainly a problem of sorts, but not nearly as big of a problem as the back. One thing you could do is to fabricate a piece that slightly fills in the gap right above where the windshield wipers are, this would direct airflow above them and improve things a little. |
#118 |
Drives: FRS :D
*waiting for FRS design*
Out of the FRS game
#119 |
Response for the first post update:
Ooo... so my answers did get considered. :P After you pointed out the details you've created I can see it a better now. :P
I am the Ice Queen.
Logic > Emotion ┬──┬◡ノ(° -°ノ) Yashio Factory Pink adds +10HP to anything. TOYOTA FT-86 ![]() |
#120 |
(ノಥ益ಥ)ノ
Drives: 2015 Series Blue BRZ
Legit bro, you've got serious skill and an eye for aesthetics without going over the top. It's simple, clean, and wide enough to accommodate conversion spacers (even though personally I'll probably go with the full hub conversion and wider wheels). You'd definitely have some of "doll-hairs" I set aside for modification funds. BUUUUUUUUT, like you said it's Form vs Function and seeing as I tend to lean more toward the functional side I'd say I'd buy one of your kits but not this particular one (even though I seriously like the way it looks).
In other words, I like your style; were you to put together a function oriented kit my money would be yours. |
#121 |
Hey Dimman,
Your friend? 's roof uhhh "wingtip covers" would actually work on the rear window I think...the air traveling around the side of the car sees a sharp transition over the rear window which in most cars will create a rather large vortex coming off the 2 edges of the rear window. I'm thinking a rubber extension that is taped onto the rear window and attaches to the trunk would work. I'm not 100% sure but I think it would reduce the pressure difference across the edge of the window since the air meets a higher speed stream of air further from the rear window. Ideally the car's ass should be a little higher and the rear window should "cave in" a little. See Pagani Zonda for reference. EDIT: okay so apparently it's worth about 4% drag reduction if you extend C pillar correctly...that's not bad if it's easy to just tack on a triangle of ABS plastic (wouldn't look too bad if it had a matte finish too). Admittedly the trailing vortices do help airflow adhere to the rear window, but they come at a very high induced drag cost, so it's probably better to block off the rear windshield from the sides and then use vortex generators at the roof. Trailing vortices are probably also the reason why spoilers have those ugly sections coming out the sides sometimes. Last edited by serialk11r; 01-30-2012 at 06:30 PM. |
#122 |
FT86Club.com O.G.
Drives: Gunmetal Gundam Wing Zero Custom
let's see it!!!
#123 | |
Kuruma Otaku
I must be getting old...
Because titanium. |
#124 |
On the hood hmmm that would be of limited use, because the hood angle generally is not very steep. Hey if you check out the NSX concept, you'll see my C pillar extension idea on the rear. A pillar vortices are weaker than the C pillar ones.
#125 |
Kuruma Otaku
Guy is (was?) apparently a lead engineer at the MIRA wind tunnel in England and the car was for him and his daughter to compete in time trials or hill climb. It was a Rover hatchback. They closed up the front grille significantly, had a deep airdam/splitter, deep side skirts, a pretty much open hood, those 'fences' along the entire length of the hood, nothing on the roof (argh...) and a rear spoiler at the back of the roof.
Because titanium. |
#126 |
Ah hatchback changes things. I think fastback design has the greatest induced drag due to the C pillar angle.
| New photos of aero kits for 86/FR-S! Nur, ings, TRD, Modellista | ttknf | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 84 | 04-14-2014 05:00 PM |
| Breaking: standard Scion FR-S / Toyota FT-86 model and aero kits revealed | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 234 | 08-19-2012 08:33 PM |
| WingsofWar Aero Kit Design | WingsofWar | Cosmetic Modification (Interior/Exterior/Lighting) | 127 | 05-29-2012 07:51 PM |
| How do you buy aero kit / TRD parts? | scwewywabbit | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 03-17-2012 10:45 PM |
| NA engine kits? | Levi | Engine, Exhaust, Transmission | 36 | 11-17-2011 11:45 PM |
