#113 |
Drives: 2014 Argento FR-S
My FRS has been at the dealer for a few days to deal with a finish issue so I haven't had the opportunity to check out the ideas posted in this thread to make 2nd gear a smoother transition until yesterday.
Driving it yesterday and today, I can say that shifting into 2nd gear is not helped at all by double-clutching, or by putting it in neutral and pausing there for a moment. If my FRS is cold, 2nd gear can be totally disagreeable, period. When warmed-up, it's better, but dicey. I need to put some miles on it (only have 600 miles now) to really determine if there's an issue, or if it's just a temperamental FRS tranny. |
#114 |
Getting to know my FR-S better, I'd say it's totally a cold tranny issue. Once warmed-up, it's virtually flawless in all gears, including 2nd.
When cold it can shift perfectly from 1st to 2nd as I pull away in the AM, and the second time I try 1-2nd 30 seconds later at the end of my street it simply won't go into 2nd. So I skip into 3rd. Again, double-clutching, pausing in neutral, rev-matching - nothing works. If it doesn't want to go into 2nd when cold, it doesn't go into 2nd! |
#115 |
Drives: 2017 Series.Yellow + Perf Package
Try double-clutching between 1 and 2 when fluid is cold. It helps, learned this from MK1 GTI back in the day. That was another performance oriented car with a wonderful gearbox. It nothing to be concerned about, just work around it until warm, have mechanical sympathy!
#116 | |
Double-clutching does not have any affect, for me, at least. In fact, nothing other than getting a warmer gearbox helps. Weird thing is, sometimes, on the coldest of AM's, it'll work perfectly the first time I shift from 1st to 2nd. Then, the very next time, 30 seconds later, will not work. |
#117 |
Here are my responses in another, related thread. I've copied the content over here as a PSA in the event it might help others.
____________________________________________ Originally Posted by billyk_____________________________________________ Update: I'd say I've got my technique up to 100% now. For those first couple of shifts from 1st on a Winter morning... Accelerate slowly and stay in 1st for 4-5 seconds.For me, works every single time. Getting into 2nd is like butta. Stock gear oil. |
| The Following User Says Thank You to billyk For This Useful Post: | tobin (01-26-2015) |
#118 |
Drives: FRS RS 1.0
i think you guys might be double clutching wrong :P lol
my 2nd gear hates the cold, especially when its cold cold.. like -20C and such. but double clutching it works fine, no matter how cold it is. |
#119 | |
Minus 20 or plus 30 mine shifts as easy as can be now with no double required.
#120 |
#121 |
#122 |
Just under 24K. I have not had to fight it once since the temperature dropped.
| The Following User Says Thank You to Tcoat For This Useful Post: | billyk (01-23-2015) |
#123 |
Drives: 2015 Scion FR-S Release 1.0
I'm in the "new gear oil made it worse" camp. I actually didn't notice any problems with the stock oil, it just didn't shift very smoothly. I replaced it with royal purple and now 1st/2nd are terrible until it warms up. I'm about to switch the purple out for motul 300. I'll update with my findings if anyone's interested.
| The Following User Says Thank You to Loetke For This Useful Post: | Tcoat (01-23-2015) |
#124 |
Drives: '14 GT86 project, '13 GT86 DD
I am soon going to be rebuilding my tranny after having all the gears and synchro hubs superfinished. I'll let you all know if this mod makes things better??
#125 |
Alright, the switch to motul 300 has been made. I haven't done a lot of driving yet but the difference is night and day. The motul shifts much more smoothly than the royal purple. I waited until driving it on a cold morning (as cold as we can expect in Georgia) to post to make sure there actually is a difference, and there definitely is. Even from a cold start I was able to shift into 2nd without trouble. It was a little stiff, but it went right into gear. No more forcing it in, and more importantly, no more of my wife glaring at me for spending $30k on a car that won't shift like it's supposed to!
#126 |
Drives: 2015 AOZORA EDITION
Mines a 2015 my second gear is super smooth when cold goin from 1st to 2nd. When fully warmed up I get a clunk noise when going from 1st to 2nd is this normal?. I have just about 5000km I get zero noise when down shifting to second what so ever. I will change out my tranny oil at my next oil change at 10,000km to see if that's help. Also I'm from Canada and it's really cold out here so don't know if weather has anything to do with it.
| New manual driver - SPEED BUMPS! | eifer | Engine, Exhaust, Transmission | 47 | 06-16-2015 02:27 PM |
| FS: Toyota 86 GT! 6 Speed Manual ! Black ! [VIC] | os86 | Australia Classifieds | 0 | 12-19-2012 06:01 AM |
| Whiteout 6 speed manual (Raleigh, NC) | low trq | Southeast | 3 | 10-29-2012 04:57 PM |
| Hard shifting into 2nd gear when cold | BMWDavid | BRZ First-Gen (2012+) — General Topics | 35 | 06-24-2012 03:22 PM |
| Another reason to buy a manual transmission car... | xantonin | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 08-10-2011 12:30 PM |
