#113 | |
OEDC
Drives: Vortech 8.5psi 274WHP 2013 BRZ
http://en.m.wikipedia.org/wiki/Decibel It's a exponential scale, -1db @12v (volts and amps go thru the same conversion, unless you take skin effect(AC) http://en.m.wikipedia.org/wiki/Skin_effect into play) is .12~ volt loss. 5v is .05~ both are such a small value that it could be meter error. |
#114 | ||
Drives: Perrin/VORTECH Supercharger TestBRZ
No Doubt!
| The Following User Says Thank You to Huehuecoyotl For This Useful Post: | Calum (03-22-2013) |
#115 | |
Drives: GT86
#116 | |
OEDC
#117 |
Drives: FR-S, NA8, S13
do want
#118 | |
1337
Drives: 2013 BRZ WRB S/C
There's the incredible amounts of heat generated, which is a concern for things surrounding (cables, lines, plastics etc), as well as IAT's. I had turbo'd my previous car, which had come NA from the factory. The downpipe was close to a power steering line, but not touching. I was always concerned about it, tried moving the power steering line a bit, and also heat wrapped the downpipe. Well needless to say, my concern was warranted, as one day I was 5 hard laps into a track day, three quarters of the way down a long straight all the sudden my cabin filled with smoke and I lost steering. It was truly terrifying as I was at pretty much full speed at that point. Thankfully I managed to get it under control and pull off. The fluid in the PS pump had boiled and blew through one of my seals. So there's the heat issues. There's the exhaust leaks that you are possibly introducing. Bolts working their way loose, bad fitting gaskets, faces that aren't perfectly machined all are risks for exhaust leaks, and breathing in exhaust fumes used to drive me crazy (probably litterally). A new setup is usually going to be fine, but with time those joints, and pipes that get minor cracks in them (due to the thermal expansion and internal/external stresses) will EVENTUALLY leak. It's honestly a matter of time with an aftermarket turbo setup. Then there's the rattles and squeaks. Honestly if not for these, I would still have my previous car. I can't stand these noises, and there is no way I am going to induce more noises and make my brand new car feel like an older car. When you're dealing with exhaust, you need to consider that with the extreme temperatures, the pipes are going to expand and contract. If you have any tight clearances between two things in the engine bay - something is going to start rubbing. You're introducing more piping into the engine bay which is more risk for rattles and squeaks. Granted, a poorly designed supercharger setup can be at risk from this as well - though you are talking about 50% less piping, 50% less risk. The one pipe in the vortech kit DOES scare me - being so close to the supercharger pulley and hood, but I am going to trust the amount of testing Vortech has done. There should be less thermal expansion when you're only dealing with charge piping, particularly on the cold side of the intercooler. There are other complaints with turbo's, transient response being a big one, but in the end I am determined that supercharger fits the bill for me and for this particular car. Given the lengths they went to to make it a fun drivers car, I think supercharger makes a whole lot of sense as far as a power adder is concerned. You don't need ungodly noises that you would from an NA setup, and you don't have to deal with as many headaches as the comparable, yet more powerful turbo setup can bring. I am confident the guys at AVO know what they are doing, it looks like an amazing kit, but having been down the turbocharging road before - supercharger for me. |
| The Following 3 Users Say Thank You to djdnz For This Useful Post: |
#119 | |
Add lightness!
Drives: 17' WRX
It seems like your background is audio. Audio signals in general are extremely sensitive compared to raw DC voltage from something like a MAF sensor. Do you solder your battery wires to the battery? Do you solder your ring terminals to your amps? I mean, every single one of those connections is a solderless connection. There is nothing wrong with a good mechanical connection unless you are talking about very sensitive signals. Bottom line is… solder does not make sense on a “bolt on” product like the vortech kit. Will it work? Yeah sure but an extension harness is a sensible request given how friendly the rest of the install is. |
#120 |
I dont think this should be a consideration to the extent its being presented, nor do I think its a show stopper in any way. Solder it crimp it get 'er done and go drive it up the canyon
| The Following 6 Users Say Thank You to Huehuecoyotl For This Useful Post: | Calum (03-22-2013), Coheed (03-22-2013), gosaints420 (03-22-2013), industrial (03-22-2013), RedAlert (03-22-2013), Sonolin (03-22-2013) |
#121 | ||||
I Love custom Turbo kits
Drives: Limited BRZ
^^^ I have this exact same opinion. Quote:
Dyno chart is a big part of the value of the kit. NOT the only one!!! But definintely plays a big part. We are paying thousands of dollars for performance! I fail to see how a properly installed Turbo kit from a proven company with off the chart reviews is a potential for bad reliability. Quote:
I don't intend to argue, I respect each and all opinions and choices and don't intend at all to change everyone's mind. Just offering a different point of view. Thanks to everyone for reading, I'm happy we all have such different likes/concerns for the car and so much different kits to choose from. Happy modding guys!! I'm looking forward to ride a Vortech charged car!!
#122 | |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
This is one worry I have about the centri SCs. If they dump pressure, the intake piping will need to be recharged. But it's not as big of a deal since the SC is always spinning. But if they use a WG tobleed excess, then it shouldn't be as big of a deal. But another reason why I REALLY want the twin screw is because it should lend itself to a little compound-charging idea I'm kicking around for a future project.
#123 | |
I do have a few comments 1-what are you talking about oil changes every 7500 miles?huh???SC does not need its fluid changes 7500 where are you getting this? 2-I've never had a turbo last 230K miles, you know?I dunno what conditions you drive in but certainly sounds different than mine 3-you are on the wrong thread since you want to buy a AVO turbo, how many times you gonna tell us that you think AVO is better? We hear you. Loud. and. Clear. 4-I've got 3 years rom Vortech with unlimited mile warranty, ymmv. 5-not dealing with oil, exhaust can mean alot to the home installer, it can also translate to fewer things for me to keep an eye on while on the track, example, my car will not get any guages, my afr will be stable, all I want to watch is my oil temp, which doesnt get used to cool any FI bearings and probably will run cooler as a result. |
#124 |
@Draco-REX, Turbos are always spinning too. Unless you have an enormous wastegate, some exhaust gasses will always pass through the turbo.
#125 |
That Guy
Drives: 2013 asphalt FRS MT
Solder will always make a connection more brittle. Personally I use a proper splicing technique, self adhesive heat shrink, and depending on the environment, hockey tape or loom for abrasion resistance.
Skin effect does begin to come into play until you reach the RF range, which this signal doesn't come anywhere near. And I to, am disappointed that this kit requires the stock harness to be cut. It just seems unprofessional and thus sticks out like a sore thumb. |
#126 | |
OEDC
It is a sensible request, but the statement crimps are better is flawed , a micro/mini (2m) tech knows when to solder, just like the link said, solder small, crimp large. The new crimps with the ability to be heated up to create a bond is soldering, well for the masses... So as soon as you apply heat to it it stops being a crimp and turns into a solder joint... And I'm all for that. As for my background I'm a true ET (everything tech) if it has electrons flowing and it's not breathing, I can fix it. I also program and R&D on robotics (current job.) my navy back ground is 10 years of communications, Radar, circuit board repair and programing. Oh and all the shit sailors buy and then break while out to sea. |
| Questions and Discussion on Vortech Supercharging Systems | Brian@Vortech | Forced Induction | 1462 | 01-27-2017 03:05 PM |
| New Vortech Supercharging System Information... | Brian@Vortech | Forced Induction | 306 | 11-08-2012 06:49 PM |
| aFe Power/Takeda Air Intake System and Exhaust | aFePower | Engine, Exhaust, Bolt-Ons | 10 | 08-06-2012 04:03 PM |
