Old 12-27-2011, 06:45 PM   #113
gamma6
Drives: 03 ep3
K20A3.
I agree with the rest.
Umm how long did the engine last? Or was it rebuilt? Cuz 320whp is about the breaking point on a k20a3 reliably as a dd... for those numbers must have been a different k20 and not the a3... kinda confused tho cuz if that dyno results r for the turboed ep then im pretty sure its not a a3
gamma6 is offline   Reply With Quote
Old 12-27-2011, 08:43 PM   #114
fatoni
Originally Posted by NA_T View Post
Am I the only one thinking about ITB's with a carbon airbox redirecting air from right behind the front bumper? Just dreaming.. sound would be epic and redline would definitly be alot higher! Woop!
Probably. I, for one, dont want to spend four figure dollars for one figure power
Old 12-27-2011, 08:52 PM   #115
ryude
Drives: Volkswagen GTI
The ep came with a k20a3, which has been proven to hold up to 400whp stock.
ryude is offline   Reply With Quote
Old 12-27-2011, 08:57 PM   #116
old greg
Rocket Surgeon
Drives: PSM GGA OMG
No, it wouldn't. That's not how it works.
old greg is offline   Reply With Quote
Old 12-27-2011, 08:59 PM   #117
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Not my car, I was replying to homemade who asked if it was a B20... I was just replying with the proper engine code for an EP3.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-27-2011, 09:01 PM   #118
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Sound would be different than using an IM for sure, it's love or hate though.
But WTH does ITBs have to do with redline?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-27-2011, 10:06 PM   #119
himbo
Drives: Lightening Red BRZ Ltd.
ITB's would bewbiez. BUT, I'm not sure how they will work with the DI. Plus, a lot of work is involved in setting up ITB's- the tuning would probably prove to be a nightmare.
I'd totally love it though...
himbo is offline   Reply With Quote
Old 12-27-2011, 11:03 PM   #120
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Originally Posted by Max Schnell View Post
The intake side of this car looks pretty efficient already. The air box looks like it is a vertical panel facing the front with a large intake pipe from the bumper area, K&N panel filter probably would be it. The elbow may be replaceable with a smooth elbow but does not pinch anywhere that I can see. Plastic composit manifold already has better resistance to temperature change.
DI may be able to open up some tuning possibilities though with leaner air fuel ratios without detonation. I don't know if the motor can rev any higher, that would be a easy tunable mod if the valve springs and rotating mass can handle it to push another 500-800 rpms out of the motor.
If the headers are already equal length I doubt there is much aftermarket headers will do.
High flow cat will be on my list because it will be usable either NA or turbo. Exhaust may help with the high flow cat combo but if the main restriction pre-exhaust is not removed it probably won't do much.
Power drops off after 7000rpm. Why would you want to increase redline unless you had other supporting mods to make it worthwhile?
tranzformer is offline   Reply With Quote
Old 12-28-2011, 05:35 AM   #121
Sully
Drives: In the market for something fun
I'm actually wondering about the difference ITB's would make. Normally they don't free up any power until supporting mods are done. But with 12:5:1 compression right out of the box? I'm curious.
Sully is offline   Reply With Quote
Old 12-28-2011, 08:10 AM   #122
Levi
Drives: Toyota
This thread starts being really worthless. It is meant to discuss HP-gains on NA engine. Everything is possbile, but the point is at what costs, and until we do not know anything concrete on the engine we won't know. So stop saying this engine can't be any better (and needs FI).
Levi is offline   Reply With Quote
Old 12-28-2011, 02:46 PM   #123
fatoni
while i do think that itbs arent going to be cost effective, i was largely referring to the the huge carbon housing that would negate the cool factor of itbs, cost more and possibly just negate any benefit of itbs in a car like this
Old 12-28-2011, 03:52 PM   #124
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You can put a filter assembly right over the ITBs. That's what I've used in the past. Carbon housing are just fancy, I'd rather either run just the filter with ducting going to it or just weld up an aluminum duct/box for them..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-28-2011, 04:11 PM   #125
fatoni
if i were to run itbs thats how i would do it but the op is talking about some carbon housing running all the way to right behind the bumper
Old 12-28-2011, 09:15 PM   #126
Max Schnell
Drives: Lexus GS350 F-sport
This is why I mentioned ECU tuning for DI and revs in the same paragraph. There are any number of reasons that may have the power drop off after 7k. If the car can be tuned to continue to make power then raising the rpms makes sense.
Max Schnell is offline   Reply With Quote
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 06:04 PM
Mods? Bruninho8 Scion FR-S / Toyota 86 GT86 General Forum 3 12-06-2011 06:11 PM
Estimated Price.. SLeRoux92 Scion FR-S / Toyota 86 GT86 General Forum 44 05-25-2011 11:58 AM
