Old 06-12-2015, 10:55 AM   #113
JozhGoober
Drives: 2020 718 GT4, 2013 FR-S (Turbo)
Originally Posted by TRAKRAVN View Post
Hey everyone, just looking to get opinions here.
I'm prepping my car for HPDE, track and autoX events which is the main reason I got the car.
So far here's what I have prepped before hitting out the first time.
Mishimoto oil cooler
Koyo rad - running water + Mocool
5w-40 300V - engine oil
Gear 300 - transmission oil
Gear 300 LS - diff oil
RBF660 - brake fluid
Ferrodo DS2500
Stainless brake lines
Stainless clutch line
Brake stopper
Aim Solo DL
Is there anything else I should have done to the car before hitting the track for the first time?
I wouldn't run water in your cooling system unless you're planning on changing it often. The cooling system is more than capable and you're loosing the anti-corrosion additives in the normal coolant. And if you forget about the water and temps go below freezing...new engine block.
The oil cooler is smart, but unless you're forced induction, the 40-weight oil probably isn't doing you any favors. 5W-30 is probably more appropriate.
300LS is only needed if you have a clutch-type LSD, if you have the stock Torsen diff regular Gear 300 is fine. You should be fine with it for now though, it's just convenient only needing one type when doing fluid changes.
The DS2500 are more of a hybrid pad I believe, if you're really tracking hard you may want to upgrade to a better track pad. There are any number of opinions/options on that. I use the PMU Club Racers, lots of folks use Carbotech XP10/12, etc.
JozhGoober is offline   Reply With Quote
The Following 2 Users Say Thank You to JozhGoober For This Useful Post:
CSG Mike (06-12-2015), TRAKRAVN (06-12-2015)
Old 06-12-2015, 11:03 AM   #114
TRAKRAVN
Drives: 2015 Scion FRS - Raven
I'm going to be using the stock tires would the XP10's be too aggressive?
TRAKRAVN is offline   Reply With Quote
Old 06-12-2015, 11:57 AM   #115
sickmint79
Drives: bmw
i used xp8 front ax6 rear with upgraded fluid and was happy. today i have a stoptech bbk up front and do xp8/ax6 still. i will be getting temp info for the first time at a new track on monday (unless it's rainy) - 5/6 of my track days this year have rained...
particularly being first time out, and i don't know how aggressive you've played around on the street or elsewhere, i wouldn't think you would be needing xp10.
i have oil posts here but a consolidated post using track data and the forester oil cooler is here - http://www.bobistheoilguy.com/forums...topics/3739658
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
The Following User Says Thank You to sickmint79 For This Useful Post:
Old 06-12-2015, 12:00 PM   #116
OkieSnuffBox
Drives: '23 BRZ Limited
- All sockets that I need to work on the car (ONLY the sockets needed)
Just curious if you've determined what sockets you take, or do you just take a full compliment of 3/8" and 1/2" metric sockets?
I want to put together as small as possible kit for HPDE and AutoX.
Old 06-12-2015, 12:09 PM   #117
jvincent
jvincent's Avatar
You definitely don't need a full set of sockets. I think you can get away with about 5 or 6 starting at 12mm. That will let you tackle pretty much anything brake or wheel related.
Old 06-12-2015, 02:10 PM   #118
JozhGoober
Maybe a little. If you're on stock tires you can try the DS2500 for a track day or two (they'll be just fine for street/autox). I'm less familiar with the Carbotech line but if you're going to upgrade tires in the future, it doesn't hurt to have some overhead in the brakes. I'd recommend same compound front/rear.
I would at least start at 10mm, and bring a 12, 14, 17, and 19. I'd also bring at least an adjustable wrench. That covers pretty much the entire car minus the axle nuts.
I have a small tool bag always in the car with these: [ame="http://www.amazon.com/gp/product/B005G5263I?psc=1&redirect=true&ref_=oh_aui_detailp age_o09_s00"]Craftsman 8 pc. Metric Dual Ratcheting Wrench Set - Combination Wrenches - Amazon.com[/ame] (plus an adjustable wrench), air gauge, tread gauge, multi-screwdriver, and mechanic's gloves.
I also keep this in the car (originally bought to do the springs/struts): [ame="http://www.amazon.com/Kobalt-Xtreme-Access-drive-socket/dp/B008A24EES/ref=pd_sim_469_1?ie=UTF8&refRID=088CJ0804J87382A8Q 5A"]Kobalt Xtreme Access 14 pc 3/8 in drive socket set - Socket Wrenches - Amazon.com[/ame] and leave my large ratchet set at home.
I have a separate, larger "track day" tool bag where I keep a spare set of brake pads, unopened bottle of brake fluid, a quart of oil, and some random other stuff.
The Following User Says Thank You to JozhGoober For This Useful Post:
TRAKRAVN (06-13-2015)
Old 06-12-2015, 02:57 PM   #119
Not at all, but you will need a few runs to get used to the additional bite. If you street drive with them, then you'll get used to it before you autox.
Old 06-12-2015, 02:59 PM   #120
I take these:
1/4
5.5, 7, 8, 10, 12, 14
3/8
10 12 14
1/2
14 17 19 21 27 32
I have a few others that are not FRS/BRZ specific as well, but these will cover 99% of what you need on the car. You may want to carry multiple versions (shallow/deep), extensions, swivels, and wrenches.
dp1 (06-21-2016), OkieSnuffBox (06-12-2015)
Old 06-12-2015, 03:32 PM   #121
OkieSnuffBox
Awesome, thanks for the info.
Old 06-13-2015, 07:25 PM   #122
TRAKRAVN
Thanks for the advice.
The diff already has the LS oil, since the shop just put it in when they looked up the car had an LSD. Either way I'm sure it will be fine for the season.
I'll run coolant instead of water to see how the temps hold up. If they are still a little high then I will swap over to water and Mocool.
I'm going to run XP8's front and rear to start off.
For those with a BBK why did you upgrade over stock?
Old 06-13-2015, 08:54 PM   #123
churchx
churchx's Avatar
Drives: 2014 GT86
Upgrade to BBK happens for two main reasons: 1) to get extra heat capacity before fading when one does long sessions on track, 2) for looks (yes, because of this reason too - "OH NOES, still small brakes with not red painted non brand 8-pot calipers in my new shiny 20" wheels?!!"). Twins stock brakes are rather good, they held on track for upto 10min just fine, so for mostly daily driving with slight track usage one should be fine with just brake pads and fluid change. With steel lines & airducts - even better.
There are other reasons two, but imho of less importance in purchase decision. Eg. most aftermarket BBKs of NOT insane rotor size are lighter then stock, for some BBKs consumables, such as pads & rotors, are cheaper then stock.
The Following User Says Thank You to churchx For This Useful Post:
TRAKRAVN (06-14-2015)
Old 06-13-2015, 09:02 PM   #124
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
The BBK will have slightly better economics when looking at consumables for track heavy users
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
Old 06-13-2015, 10:27 PM   #125
sickmint79
Drives: bmw
i don't recall if i had any fade or not oem, i'm not the greatest at modulating them i think either. in any case,
1. got the stoptech kit for a steal
2. buddy made carbon ceramic rotors for mountain bikes, wanting to see if he could for car, this kit had 2-piece rotors to try (never did though)
and really, probably the biggest,
3. i can glance down and see how much pad is left. even taking off the wheel with the oem calipers, this is a bitch.
Old 06-13-2015, 10:34 PM   #126
Reduced unsprung weight, reduced rotational inertial, reduced long term cost for heavy users.
FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel Pekingduck Interior Parts (Incl. Lighting) 7 02-12-2014 06:59 PM
prepping for winter Celica00 Scion FR-S / Toyota 86 GT86 General Forum 24 09-27-2012 09:17 AM
Prepping for rear spoiler install? zooki Cosmetic Modification (Interior/Exterior/Lighting) 2 09-02-2012 04:56 PM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-21-2012 12:33 AM
Clean & Dirty trueno86power Other Vehicles & General Automotive Discussions 1 02-07-2012 01:54 PM
