Old 11-26-2012, 08:13 AM   #113
Ingen
Drives: Ultramarine FR-S 6MT
Originally Posted by RiskyTrousers View Post
I'm running the UEL headers and their cat back with the stock mid pipe. Not loud at all, perfect volume IMO. Sounds amazing when you open her up!
Sent from my HTC One X using Tapatalk 2
Check engine light status? Did you do any supporting mods? and does it bolt right in or did you have to do any custom fiddling with pipes to make this work?
I'd very much like to do the headers and axle-back just to get the sound, and drop the mid pipe and such in at a later date maybe. Too much cash right now, of course. Stupid Christmas, making me spend it on others :P
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 11-26-2012, 08:43 AM   #114
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by nashsnazzy View Post
So if we put this UEL on the car with a stock exhaust or another exhaust with a single cat will we get a cel? Does the use of this UEL leave some sensor disconnected?
Like with most cars if you get rid of the CAT in front of the O2 sensor you will get a CEL unless you apply a mechanical fix to move the sensor back out and "trick" it, or apply an electronic fix through the ECU to ignore the emissions CEL. We have not had this header yet on our car but are looking to do so VERY soon, and we can provide more information then, but I see a mechanical fix being needed at this time to stop a possible CEL.
You cannot remove emissions control devices before the sensors and not expect a CEL, it will happen.
This isn't a mod for everyone. This item is perfect for someone building a N/A track car or someone that is okay with CEL issues/fixes, along with taking full responsibility for the emissions side of things.
A header with a CAT will more than likely be developed by other manufactures. It will take a lot longer though for those to appear on the market as R&D is much more involved and costs would be close to double what you see here on this guy. Also HP/TQ gains will not be as large with a restrictive CAT in the header.
Cliff Notes:
Worried about warranty, cops, and emissions laws? Keep the stock header in place.
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
ngabdala (11-26-2012)
Old 11-26-2012, 08:56 AM   #115
Zadkiel
Drives: CBS BRZ Limited 6MT
Cliff Notes:
From what I hear, the stock header isn't a bad one to begin with, right?
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Old 11-26-2012, 03:36 PM   #116
RazBRZ
Cones are bad
RazBRZ's Avatar
Drives: 2013 BRZ Premium
The stock header is good, but I have a subaru and want it to sound like a subaru and not a toyota.
I personally want UEL
RazBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to RazBRZ For This Useful Post:
nashsnazzy (11-26-2012), number1Tango (11-27-2012)
Old 11-26-2012, 07:43 PM   #117
nashsnazzy
Drives: 2013 Scion FR-S White Out
That is really the deal. I want sound and if I pick up power that is great. The emission stations seem pretty laid back so I'm not to worried.
nashsnazzy is offline   Reply With Quote
The Following User Says Thank You to nashsnazzy For This Useful Post:
RazBRZ (11-27-2012)
Old 11-26-2012, 07:47 PM   #118
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
I have a Toyota...
But it has a Boxer, and I like the customary boxer rumble.
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
The Following 2 Users Say Thank You to seven For This Useful Post:
ngabdala (11-26-2012), RazBRZ (11-27-2012)
Old 11-26-2012, 08:41 PM   #119
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Excuse me but some of us like to buy impulsively without thinking
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
The Following 3 Users Say Thank You to ngabdala For This Useful Post:
BoostinIX (01-18-2013), FT-86 SpeedFactory (11-26-2012), RazBRZ (11-27-2012)
Old 11-26-2012, 08:47 PM   #120
ngabdala
Any droning?
Old 11-26-2012, 08:54 PM   #121
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
Originally Posted by ngabdala View Post
Any droning?
No drone when I had just the cat-back and no drone with the UEL headers and stock mid pipe.
RiskyTrousers is offline   Reply With Quote
The Following 2 Users Say Thank You to RiskyTrousers For This Useful Post:
ngabdala (11-26-2012), RazBRZ (11-28-2012)
Old 11-26-2012, 08:59 PM   #122
RiskyTrousers
I did get a CEL for two days then it turned off. I assume its from not having the first cat but wont know for sure until I pull the code.
In terms of supporting power mods I only have the headers and cat-back, running stock mid-pipe w/cat, not intake etc.
All Borla pieces fit right up to stock. Basically you can mix and match all you want.
The Following User Says Thank You to RiskyTrousers For This Useful Post:
Old 11-26-2012, 10:28 PM   #123
DarkCard
Drives: Asphalt Scion Frs 6MT
Can we have some pics installed? Im curious to see how it looks
DarkCard is offline   Reply With Quote
Old 11-26-2012, 10:34 PM   #124
ngabdala
Here are some reasons according to Super Sprint that makes their own catless EL Header as to why there is a CEL. I plan on getting a guide from them with some pics if they will supply it to me.
*TO AVOID CEL ERROR:
-The secondary O2 sensor wire must be extended to connect after the cat. A full guide to this procedure is available.
Alternative solutions:
- Deactivation of the secondary O2 sensor through ECU reflash
- Mini-cat (connected between the sensor and the bung on the headers)
Old 11-27-2012, 09:01 PM   #125
seven
Tells it like it is
seven's Avatar
So, can I just have a reflash done? I'm gonna want one done once I put on the header/exhaust anyway.
Old 11-27-2012, 09:03 PM   #126
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Yes.
TomR
ABQautoxer is offline   Reply With Quote
Stealthbox for 2013 Scion FR-S/Subaru BRZ sure74 Electronics | Audio | NAV | Infotainment 54 01-10-2015 07:57 PM
**EIBACH PRO-KIT SCION FR-S & SUBARU BRZ 2013** Evasive Motorsports Brakes, Suspension, Chassis 15 09-26-2012 02:17 PM
Takeda Releases Exhaust for the 2013 Scion FR-S/Subaru BRZ H4-2.0L aFePower_indika Engine, Exhaust, Bolt-Ons 2 08-29-2012 06:08 PM
2013 Subaru BRZ and 2013 Scion FR-S: A Study in Comparison and Contrast Zgrinch Scion FR-S / Toyota 86 GT86 General Forum 124 02-21-2012 02:43 AM
