Old 01-23-2013, 06:29 AM   #113
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
Originally Posted by DSOmegaX View Post
any chance we can revive that group buy for the AT one?
Originally Posted by RallySport Direct View Post
We closed them down due to the lack of committed buyers in the group buy. I feel like the timing was off due to the Holidays and Winter. We will start up another Group Buy thread for the AT drive shaft later down the road. I'm thinking this one will go much better due to more cars being on the road, and generally more interest all around. We will keep you posted.
Thanks,
Rick
I'd like to add that having the CF driveshaft you have one less u-joint and bearing to wear/fail creating unnecessary friction and power loss. I've actually had to replace a ujoint for our Tacoma truck due to wear in saltwater + muddy enviroment. It's just one less to worry about.
Xanatos is offline   Reply With Quote
The Following User Says Thank You to Xanatos For This Useful Post:
RallySport Direct (01-23-2013)
Old 01-23-2013, 10:25 AM   #114
fr-sTony
Happy Camper
fr-sTony's Avatar
Drives: ultram 2013 FR-S, 1985 Merkur XR4Ti
I hope so. I wanna buy one soooo bad! All we need is 10 people to encourage them to make them. Right Rick?
fr-sTony is offline   Reply With Quote
Old 01-23-2013, 11:23 AM   #115
Captain Insano
Actually it was five people in the last go around. I was one of the two people that was signed up.
Old 01-23-2013, 12:51 PM   #116
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
@ RallySportDirect
Silly question I know but what are the operational temperature limits? That is, at what ambient temperature is there a reduction in the strength of the shaft?
@RallySport Direct
Fixed that for you.
Heat tolerance is almost entirely up to the resin used to make the shaft. The carbon fibers themselves can withstand relatively high heat with absolutely no issues as long as they're not exposed to open flame.
There are many different resin systems with different heat tolerances and glass transition temperatures, I'm sure that PST has chosen a resin that can withstand the typical temperatures found underneath a car.
Nathan
SubieNate is offline   Reply With Quote
The Following User Says Thank You to SubieNate For This Useful Post:
Old 01-23-2013, 01:58 PM   #117
milenko11
Drives: no
I want this but I can't justify the price yet
milenko11 is offline   Reply With Quote
Old 01-23-2013, 07:35 PM   #118
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Hey guys!
So recently we have been getting quite a bit of requests for the AT Carbon Driveshaft, and while I will not open up another thread right now, if you are genuinely interested and could commit to a 50% non-refundable deposit, please Email or PM me and we can get a list going. I was thinking about starting up a new thread in about a month, but if we can get at least 5 people committed earlier than that, we can collect payment info and get the order in to PST.
Thanks!
Rick
RallySport Direct is offline   Reply With Quote
Old 01-23-2013, 07:42 PM   #119
RallySport Direct
Indeed! Not that I would worry too much about the stock U-joint or carrier bearing failing, but I figure anything you can do to make the system more simple is always a great idea. Plus the performance gains from this mod make it even better
Originally Posted by SubieNate View Post
@RallySport Direct
Fixed that for you.
Nathan
Thank you for this! And yes, these can withstand very high temperatures as they are designed to cope with the harshest racing conditions. We have yet to see any Carbon Shaft fail or fatigue due to heat.
Yeah I felt the same way too, but once we put these on our shop cars and I had a chance to experience the before and after, I am a true believer in the benefits of a Carbon Driveshaft. If you have any one local to you that has a Carbon Driveshaft installed, I would ask them to let you drive the car, or at least take you for a ride. It really makes a very nice difference
Thanks,
Rick
Old 02-22-2013, 09:01 AM   #120
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Hi Rick,
Do you guys ship to Australian customers? I am in Perth, Western Australia.
stevo_12v is offline   Reply With Quote
Old 02-22-2013, 02:28 PM   #121
RallySport Direct
Originally Posted by stevo_12v View Post
Hi Rick,
You bet! PM me if you would like a shipping quote.
Thanks,
Rick
Old 08-28-2013, 05:09 PM   #122
mixcorp
Drives: brz
May i know the torque spec of the bolts? How tight? Thanks. Do we have to put locktite on it?
mixcorp is offline   Reply With Quote
Old 08-28-2013, 07:37 PM   #123
RallySport Direct
The torque specs are 54.6 ft/lbs and we did not use loctite on ours, but if you were worried about it, I don't think it would hurt. Just make sure to use a lower strength version incase you need need to remove the bolts at a later time.
Thanks,
Rick
Old 08-28-2013, 11:43 PM   #124
mixcorp
Drives: brz
Thanks
Sent from my iPhone using Tapatalk - now Free
Old 10-01-2013, 06:50 PM   #125
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
So people that have the pst shaft any vibe issues, nvh or such? They don't appear to be externally balanced like DSS cf shafts so I'm curious. Not based on rpm range but rather when you get up into the 60-100mph range. What's peoples thoughts on PSTs now they been out awhile?
Old 10-04-2013, 10:36 PM   #126
OICU812
Just a dude
OICU812's Avatar
Bump***
PST Carbonfiber Drive Shaft In Stock and Ready To Go!! RallySport Direct Transmission and Driveline 27 11-18-2012 01:39 PM
Carbon Fiber Hoods. Asterisked Accolade Cosmetic Modification (Interior/Exterior/Lighting) 17 09-25-2012 04:44 PM
HELP...Drive Shaft/Rear Tire Shutter UM FRS Issues | Warranty | Recalls / TSB 11 09-05-2012 11:14 AM
Does FRS come with Carbon drive shaft? STi88 Engine, Exhaust, Transmission 30 07-30-2012 01:40 PM
