#113 | |
Drives: Toyota GT86
I have always liked 949 stuff as well. I ran there wheels and lugnuts on my Mx5s without issue and bought them again for my gt86proparts like Karcepts are also from the autox world lol. Thanks for the rundown !
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
| The Following User Says Thank You to autoracer86 For This Useful Post: | RedReplicant (05-01-2023) |
#114 | |
Drives: FRS
https://community.drivenasa.com/topi...clarification/ |
| The Following User Says Thank You to JimV For This Useful Post: | RedReplicant (05-03-2023) |
#115 | |
Drives: None
![]() I'm going off what Emilio said when I asked over here, unfortunately: https://www.ft86club.com/forums/show...2&postcount=23 I'd be happy to hear there was a misunderstanding though. edit: I just emailed 949. edit2: They said 43mm again edit3: ....Digging intensifies.... it has a 16mm shaft internally
#116 |
FT86Club Official Vendor
Drives: Miata, GT350, FR-S
NASA strut diameter rule
Update and clarification: Internal shaft diameter on 86 Xida strut is 16mm so not subject to the specific NASA rule.
Sorry for the confusion.
| The Following 2 Users Say Thank You to 949 Racing For This Useful Post: | RedReplicant (05-05-2023), villainous_frx (05-06-2023) |
#117 | |
Drives: None
| The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | Brock H. (05-13-2023), villainous_frx (05-06-2023) |
#118 |
Drives: None
Car is back together and ready for the last event for a few months. The 12mm bolts in the top of the strut seem to allow for a rough -5.5* camber, I dialed it back to about -4.75* via the camber plates for now and I'll validate with the pyrometer.
Replaced the stock rear 14mm bar with a Mann Engineering I bought from the previous owner (MobiusTFS) of my Hyperblue, he found it wouldn't fit his second gen BRZ, unfortunately. ![]() ![]() ![]() I did some rough measuring and came up with something like: Max stiff - ~82lbin Mid matching holes- ~67lbin Full soft - ~51lbin I've seen varying numbers from other people, so who knows what is actually correct. I put it in the middle for now, which I think is something like half? the rate of the stock 14mm.
| The Following User Says Thank You to RedReplicant For This Useful Post: | Brock H. (05-13-2023) |
#119 | |
btr.life
Drives: 2022 GR86
| The Following User Says Thank You to justinco For This Useful Post: | RedReplicant (05-06-2023) |
#120 | |
Drives: None
I pulled the steering lock out of the car today, what a pain in the ass. ![]() I've just left the thing out of the car for now rather than putting it back in with the lock pin removed. The security light blinks when the car is running, no idea if this will be a problem or not. ![]()
| The Following 3 Users Say Thank You to RedReplicant For This Useful Post: |
#121 |
Drives: 2022 BRZ, Red
| The Following User Says Thank You to Brock H. For This Useful Post: | RedReplicant (05-13-2023) |
#122 |
Drives: None
At this point, the car has been swapped for almost a full year. Today I wrapped up what is effectively the first track season after being swapped for this car - August 2022 to May 2023; we take a break for the summer months out here in Arizona. Actual NASA season runs Jan-Dec like normal, so the season championship is still ongoing.
I ended up driving the car to the track today since I couldn't drop it off the night before, it reminded me pretty much exactly of my old S2000 that I drove to pretty much every single event. Cabin noise is more than tolerable with the Perrin, not much vibration, and the same banging noise as all of my gear goes flying in the trunk when I hit a large dip on the highway. Car felt bang on balance wise with the bar at Wild Horse Pass East, took the TT5 record by about half a second. Unfortunately, the track is being torn down for freeway widening next month so I won't get another chance at pushing it down further. ![]() Ran the VS5RS in the front and the EC7R in the rear. I think I like how the EC7R looks better on the car, but the 5 is a couple of pounds lighter and still in production. Soooo... calling the first "season" done: Ran 21 Total Events 10 NASA TT5 Wins Set 5 NASA AZ / NASA SoCal TT5 Lap Records - Chuckwalla CW (NASA AZ / NASA SoCal) - Chuckwalla CCW (NASA AZ / NASA SoCal) - Arizona Motorsports Park CCW (NASA AZ) - Attesa CCW (NASA AZ) - Wild Horse Pass East (NASA AZ) The car never broke causing it to fail to finish an event, which is pretty awesome for a fresh build / swap. Things that I broke over the season: - Three throttle body bolts, one taking a throttle body adapter with it - 1x OEM 65mm BRZ throttle body - 1x Bosch 74mm throttle body - 1x front Timken wheel bearing - 1x Jack's built BRZ Transmission - 1x MAP sensor wire - 1x Wiring harness power wire - 1x Exhaust gasket - 1x Experimental Valve Cover Baffle - 1x Coilover strut bearing - 1x Coilover strut bearing to spring hat ... thing All in all, pretty legit. I do think that I cracked the header this event, so I'll be pulling that tomorrow to see what is up. I bought 600/600 Xidas - those will be going on when they show up, so begins off season refinement -- the focus will mostly be on improving heat shielding / heat management and simplification of the car.
| The Following 4 Users Say Thank You to RedReplicant For This Useful Post: |
#123 |
Drives: 2013 Subaru BRZ
Wish I went with Xidas. I've been waiting on a set of Nitron R1s since March with no ETA still. Looking forward to the development of the car!
| The Following User Says Thank You to clu For This Useful Post: | RedReplicant (05-21-2023) |
#124 |
Drives: 2023 BRZ
What an outstanding post. I wish I could like it more than once. Great job gettin' after it!
Director of Rocky Mountain 86CUP
| The Following 2 Users Say Thank You to Pat For This Useful Post: | RedReplicant (05-21-2023), villainous_frx (05-22-2023) |
#125 | |
| The Following User Says Thank You to 949 Racing For This Useful Post: | RedReplicant (05-21-2023) |
#126 |
Drives: Toyota GT86
wow congrats and sounds like the car is very reliable, usable and fast. Looking forward to hearing about the Xidas
| The Following User Says Thank You to autoracer86 For This Useful Post: | RedReplicant (05-21-2023) |
| Silviacrazed's FR-S adventure | Silviacrazed | Member's Car Journals | 52 | 06-01-2021 11:20 PM |
| Harrop 2015 TVS kit image.. | FT86_AU | Forced Induction | 255 | 07-25-2016 03:50 AM |
| SubieBuis BRZ Adventure | subiebui | Member's Car Journals | 13 | 12-06-2015 05:57 PM |
| Off The Grid Adventure | m.box.design | Northwest | 8 | 03-22-2014 01:05 PM |
| What would you consider an adventure trip in your FRS/BRZ? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 47 | 04-07-2013 06:54 PM |
